Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 86 invités
Conseils, Guides et Tutos pour le stockage et réseau
[Synthese] Réseau: Choix, Configuration Support WiFi/CPL/Eth
Message » 19 Nov 2014 17:38
il y a pas une histoire de VLAN aussi car ts mes ports appartiennent au VLAN1 mais bon ça m'étonnerait
Field Attributes
System Identity
• System Name – Name assigned to the switch system.
• System Location – Description of the switch location.
• System Contact – Contact information assigned to the switch.
• Number of Ports – Number of built-in ports.
• Hardware Version – Hardware version of the main board.
• Software Version – Version number of the code.
• Serial Number – The serial number of the switch.
Address Information
• Management VLAN – ID of the configured VLAN (this is set to 1 and
cannot be changed) all ports on the unit are members of VLAN 1. The
management station must always be attached to a port on VLAN 1.
• IP Address – Address of the VLAN to which the management station
is attached. (Note that the management station must always be on
VLAN 1.)
• Subnet Mask – This mask identifies the host address bits used for
routing to specific subnets. (Default: 255.255.255.0)
• Gateway IP Address – IP address of the gateway router between the
switch and management stations that exist on other network
segments.
(Default: 0.0.0.0)
• MAC Address – The physical layer address of the switch.
Port Information
• Port – Indicates the port number.
• Type – Indicates the port type (10/100/1000T or M).
• Link Status – Indicates if the link is Up or Down.
2-6
Using the ProCurve Web Browser Interface
Web Configuration
Browser Interface
• Speed/Duplex Status – Shows the current speed and duplex mode.
– 10HDX
– 10FDX
– 100HDX
– 100FDX
– 1000FDX
• Flow Control Status – Indicates whether flow control is enabled or
disabled.
• Auto-negotiation – Shows if auto-negotiation is enabled or disabled.
• Frame Type – Either “Tagged” or “All”. “Tagged” means that the port
will only send and receive VLAN-tagged packets. When set to “All”,
the port will also send and receive untagged packets.
• PVID – The VLAN ID assigned to untagged frames received on the
interface. (Default: 1)
Trunk/LACP Information
• Trunk/LACP – The trunk label. “T1” through “T12” on the 24 port and
“T1” through “T4” on the 8 port are used as trunk labels.
• Type – Displays the trunk type as "Static" or "Dynamic".
• Trunk/LACP Status – Indicates the speed and duplex setting of the
trunk.
– 10HDX
– 10FDX
– 100HDX
– 100FDX
– 1000FDX
• Ports – The ports that are members of the trunk.
VLAN Information
• VLAN ID – A number in the range 1 - 4094 which identifies the VLAN.
• VLAN Member – A list of the ports that are members of the VLAN.
By default, all ports are members of VLAN 1.
piqachu
Inscription Forum: 05 Juil 2004 20:40
Message » 19 Nov 2014 20:03
bon j'ai interverti les 2 switch le 1400 et le 1800
le 1800 à la place du 1400 fonctionne correctement :o :ohmg:
le 1400 qui fonctionnait toujours bien à l'étage ( branché à la prise RJ45 du mur) ne fonctionne plus au cul de la sfrbox, donc meme pb, ça me dédouane dejà le 1800 d'une erreur de config ou panne.
la seule diff entre les 2 install c'est un cable environ 7-10m en cat 5 ( simple, e ou 6; je me rappelle pas) et une prise au mur legrand en RJ45 :o
donc je decide de confectionner un cable ethernet croisé pour comparer, nada.
je coupe un autre cable ethernet et le branche sur une prise RJ45 "en volant", je la configure en cat A et puis B, j'essaye dessus differents cable ethernet droit et croisé en cat 5+,5e,6 = nada
franchement c'est à ne rien y comprendre
piqachu
Message » 20 Nov 2014 20:09
toujours en train de trouvé une soluce, je commence par desespérer :grr:
j'ai acheté un cable blindé en cat6 pour relier la box au procurve ( pour simuler la même distance qu'il y a entre la sfr box et l'étage ou les 2 switch fonctionnent bien sur une prise RJ45 en cat B): toujours pas de LED allumée :cry:
j'ai aussi remarqué autre chose mais c'est peut etre une coïncidence
quand je branche le 2eme procurve ( le 1er etant en ligne) cela me fait ralentir la connexion ( pourtant le 2eme n'a pas la led allumé au cul de la sfrbox): simple hasard ( trop de monde du quartier sur les lignes) ou réel conflit ???
j'ai aussi essayé de debranché le switch qui fonctionne à l'étage et ne brancher que le procurve au cul de la box, toujours rien.
donc le soucis est bien entre la box et le switch
quelqu'un a une idée car là je suis preneur de toute info.
piqachu
Message » 20 Nov 2014 20:43
As-tu essayé de brancher le deuxième switch sur le premier plutôt que les deux switchs sur la box ?
Michel
MLill
Inscription Forum: 08 Déc 1999 2:00
Message » 20 Nov 2014 21:41
salut Michel
je viens d'essayer et encore un mystere :siffle:
j'ai branché le procurve 1800 sur la box et le 1400 est toujours à l'étage (mais au lieu d'être directement sur la box, je l'ai branché sur le 1800 comme l'a sugéré Michel) et bien toujours pareil, la led ethernet est eteinte au niveau de la box.
en gardant cette config si j'appuie et je maintiens cette prise avec une pression dessus(celle allant de la box au 1800), la led ethernet s'allume donc je me suis dis c'est une histoire de cables ou plutot de fiche RJ45, je relache la pression et ça s'éteint.
par contre si je branche le cable allant directement (via la prise legrand RJ45 à l'étage) sur le 1400 des le clic se fait entendre, ça s'allume :zen: :wtf: :wtf:
mystere donc et boulle de gomme
piqachu
Message » 20 Nov 2014 23:02
Si tu branches l'un des deux à l'étage sur la prise murale et l'autre sur le premier cela fonctionne ?
Michel
MLill
Message » 21 Nov 2014 3:57
Voici un petit CR de ma dernière acquisition : Un routeur Wifi ac ASUS RT-AC87U que j'ai installé dans le salon, planqué derrière la télé :
Premier contact physique : Il est énorme... :o
4 Antennes, un port USB servant à partager du contenu ou rajouter une bascule automatique sur une clé 3G/4G...
un bouton WPS, un port WAN vers la box Internet, quatre ports Gigabits, un bouton reset, un bouton ON/OFF et la prise pour le transfo.
Comme j'avais parfois des lenteurs et parfois carrément la perte complète du SSID pendant de longues secondes, et que je n'arrivais pas à savoir qui de mon routeur ou de ma carte Wifi ac intégrée à mon PC portable était fautif, j'ai aussi acheté une clé Wifi ac Asus USB-AC53 :
Mais je ne peux pas vous la conseiller plus que ça... Vous verrez après pourquoi... ;)
[Edit] Je viens d'apprendre l'existance d'une clé Asus USB-AC55 qui cumule le débit Wifi ac + Wifi N... ;)
Je teste en premier lieu le débit de ma carte réseau intégrée à mon PC Asus ROG G75VW, une Broadcom BCM43XAC_NT62 avec le driver 7.12.34.0...
Et là, j'hallucine... Des débit moyens supérieurs à 50 Mo/s... Avec des pointes à 63 Mo/s... :o
Plus de 500 Mbit/s sur du Wifi ac... Je rêve... :o
Voici une copie d'écran d'une copie de fichier depuis mon PC vers le Syno :
Et du Syno vers le PC :
A ce moment là, je me dis qu'avec la clé AC53 je vais peut-être dépasser ce résultat hallucinant...
Et bien pas du tout... Après d'innombrables bidouillages et reboots du PC, impossible d'égaler la vitesse de la carte Wifi interne...
Quelque soit mes tests, j'ai un débit moyen de 34 Mo/s, ce qui fait tout de même pas loin de 280 Mb/s, qui m'auraient parfaitement convaincu si je n'avais pas su ce dont est capable ma carte interne... :roll:
Donc vive le wifi ac, oui, mais le wifi ac NATIF... 8)
[Edit] A voir si la clé ASUS USB-AC55 fait mieux... ;)
basthi
basthi
Inscription Forum: 15 Mai 2006 23:12
Message » 21 Nov 2014 8:28
Yo ! c'est le routeur de Batman ?
Super design :bravo:
En tout cas on n'achète pas un tel engin pour le cacher derrière un meuble. :mdr:
antislash
Inscription Forum: 05 Oct 2007 23:18
Message » 21 Nov 2014 10:59
Merci beaucoup pour le C.R. basthi :)
Je suis très intéressé par cette fonction :
La bascule automatique se fait lorsque la liaison par le port WAN est coupée ?
Par ailleurs tes tests de débit ont été effectués à quelle distance du routeur ?
Michel
MLill
Message » 21 Nov 2014 12:57
Oui c'est ça : on active le dual WAN et on paramètre la surveillance : intervalle, délai de réponse, nombre d'échecs...
On paramètre le WAN primaire et secondaire, qui peuvent être chacun :
- le port WAN
- un des ports LAN de 1 à 4
- le modem USB... ;)
Donc typiquement on va paramétrer le WAN primaire sur le port WAN qui va vers la box, et le port USB avec la clé 3G/4G comme WAN secondaire...
Il surveille le port et au bout de x échecs il bascule... ;)
Mais j'ai vu aussi une histoire de partage de connexion 3G/4G directement depuis un téléphone... :o
Comme c'est habituellement ce que je fais quand je n'ai plus d'internet, ça m'intéresse... Je reviens vers toi dès que j'ai trouvé comment faire... ;)
Il y a aussi un mode "répartition de charge" pour cumuler les deux débits... On peut paramétrer le ratio x:y entre les deux WAN... :o
Pour la distance, c'est du canapé à la télé, donc environ 3 mètres... ;)
basthi
basthi
Message » 21 Nov 2014 13:29
Merci pour ces précisions :)
Disposer d'une bascule sur le réseau 3G peut permettre d'arrêter et de relancer la box à distance.
Mon souci avec le Wifi-N - du moins celui que j'utilise - est qu'il n'est exploitable que dans les pièces voisines de l'émetteur.
Je ne sais pas si le Wifi-AC est capable de sauter une pièce avec un débit comparable au CPL-500 c'est à dire 10 à 15 Mo/s.
Michel
MLill
Message » 21 Nov 2014 14:04
A travers une cloison en placo et une armoire, j'ai encore plus de 30 Mo/s de débit... :o
A travers un mur porteur en béton, quand je suis collé au mur j'arrive à 20 Mo/s, mais dès que je m'en éloigne ça descend vite à 15 Mo/s, voire 10 Mo/s... Mais là on a parfois des chutes... Ce n'est plus aussi stable... :roll:
Ma maison n'est peut-être pas assez grande, mais le salon est placé de façon centrale, et dans aucune pièce je ne descend à moins de 10 Mo/s de moyenne... Même si parfois il y a des chutes...
Donc en plaçant judicieusement ton matos, ça peut le faire... A voir... ;)
basthi
basthi
Message » 21 Nov 2014 15:04
MLill a écrit:Si tu branches l'un des deux à l'étage sur la prise murale et l'autre sur le premier cela fonctionne ?
Michel
oui cela fonctionne
et c'est là où je ne comprends pas car le premier est relié à la box avec un RJ45 via une prise RJ45 legrand en cat B via un autre cable ethernet donc meme configuration que si je mets un RJ45 entre à la box et le switch à côté ( surtout que j'ai essayé ttes les longueurs de cables en cat 5,5E,6 et meme confectionné un cable avec une prise legrand en catB)
dans ce cas là cela fonctionne si je maintiens une pression sur la fiche coté box alors que pas besoin dans le 1er cas :wtf: :wtf: :wtf: :wtf: :wtf:
piqachu
Message » 21 Nov 2014 15:18
Mon diagnostic, à prendre avec réserves car ce n'est pas mon métier, est qu'il s'agit d'un problème d'incompatibilité "hard" entre la box sfr et le switch pro que tu utilises.
Ce qui n'est pas trop surprenant car du dois être le seul a jamais avoir envisagé un tel couplage :lol:.
A ta place je changerai le(s) switch(s) ou la box.
Ou utiliserai un vrai routeur entre la box et les switchs.
Michel
MLill
Message » 21 Nov 2014 15:22
basthi a écrit:A travers une cloison en placo et une armoire, j'ai encore plus de 30 Mo/s de débit... :o
basthi
Merci, cela m'éclaire bien.
Plus que beaucoup de tests que j'ai pu lire :).
Reste le problème du peu de PC portables équipés en AC.
Il suffit probablement de prévoir des clefs ad-hoc pour les visiteurs.
Michel
MLill
Retourner vers Stockage et Réseau
