Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Bing [Bot] et 12 invités
Lecteurs Blu-Ray
[BD_3D] [upscal 4K] Pioneer BDP-LX58
Message » 04 Sep 2014 8:55
Petit frère du lx88, il devrait proposer également des prestations vidéos de haute volée.
Disponibilité annoncée octobre au tarif de 699€.
http://www.pioneer.eu/eur/newsroom/news ... /page.html
We are proud to present our two newest, high-end Blu-ray/Universal Disc players: the BDP-LX88 and the BDP-LX58. Both players are the legitimate successors of our DV-AX10 (2000) and BDP-LX91 (2008) legendary optical players. Our rich tradition of producing reference grade optical players guarantees perfect pictures and high quality sound reproduction from any disc.
Heavyweight performance
Both players are true heavyweights and are built like the proverbial tank. The customised, ultra-rigid chassis and the equally rigid, quiet disc mechanism are designed to eliminate vibrations. This results in better signal stability and less jitter. The iron chassis is 1.6 mm thick and is further reinforced with a 3 mm thick iron plate at the bottom. This results in a weight of no less than 13.4 kg for the BDP-LX88 and 9.9 kg for the BDP-LX58. Unique for the BDP-LX88 is the three-chamber construction, in which the power supply section, the digital circuits and the analogue circuits are all housed in separated chambers. This helps to prevent unwanted interference. Furthermore, the main block and the power supply block are shielded (BDP-LX88 only).
4K Ultra HD Video Upscaling
The BDP-LX88 and the BDP-LX58 are compliant with the latest HDMI specs and integrate Ultra HD 4K 60p video upscaling. This means they are equally capable to feed a Full HD display device as well as the latest 4K televisions or projector systems. The integrated video processing circuits allow the best possible image quality, and can also extensively be tweaked and tuned. This way, it’s possible to optimally match the video output signal of the BDP-LX88/BDP-LX58 with the characteristics of the display device.
Audio excellence
One of the most important aspects that distinguish a mediocre digital audio players from a true reference grade players is its resistance to jitter. The BDP-LX88 and the BDP-LX58 are designed to minimise jitter to a great extent. Owners of one of the many PQLS (Precision Quartz Lock System) compatible Pioneer AV receivers can profit from this original technology, which largely eliminates jitter that might occur in the digital connection path between the devices.
In addition to PQLS, the BDP-LX88 is also equipped with a Precision Audio internal clock management system. This to reduce jitter via the analogue audio outputs.
In both players, the nearly jitterless signal can be converted to the analogue domain by means of a sophisticated DAC section. In the BDP-LX88, a high end Sabre32 ES9018 DAC chip design makes sure that the signal is converted to the analogue domain with utmost precision. When playing in stereo, the BDP-LX88 deploys no less than four (!) DAC circuits for each audio channel. The BDP-LX58 uses a Sabre32 ES9011 DAC chip.
Our expert engineers aimed for reference level audio performance by optimally tuning the entire audio path and by selecting the best electrical/mechanical parts, down to the tiniest screws. An interesting add-on, which further improves audio quality, is the special purpose connector port on the back panel. This ‘Zero Signal’ port doesn’t pass through any signals, but is used for extra grounding.
Extensive compatibility
The compatibility list of the Blu-ray 3D BDP-LX88 and BDP-LX58 is downright impressive. For starters, both players read Blu-ray discs (also BD-R/RE-variations), DVD discs (DVD±R/RW versions included), CD discs and even Super Audio CD albums and DVD-Audio discs. The audio file compatibility list ranges from MP3, WMA, FLAC and APE to DSD (2.8 MHz), LPCM, WAV, ALAC and so on. Lossless high-res files (max. 192 kHz/24 bit) in FLAC, ALAC, LPCM (WAV) and AIFF and multichannel files (FLAC, DSD, and WAV) are supported as well. The players also read video files such as MPG, MP4, TS, M4V, AVI, MOV, DivX plus HD, WMV and MKV.
The BDP-LX88 and the BDP-LX58 can obviously cope with the latest surround formats from Dolby and DTS, such as Dolby True HD and DTS HD Master Audio. Audio streams containing the newly announced Dolby Atmos multi-dimensional sound format will be passed to a Dolby Atmos compatible AV receiver.
Connectivity
The BDP-LX88, as well as the BDP-LX58 feature two HDMI-outputs. This offers the possibility to set up a HDMI connection with an AV receiver, while at the same time making a second HDMI connection straight to a display device for the best performance of both audio and video.
Balanced and unbalanced stereo analogue audio outputs are available on the BDP-LX88, as well as optical and coaxial digital outputs. The BDP-LX58 has unbalanced analogue stereo outputs and a coaxial digital output.
Both players also have two USB-ports. One sits on the front panel, while the second port is situated at the back. The LAN port allows connecting the BDP-LX88/BDP-LX58, which are both DLNA compatible, to a home network. This way, YouTube and Picasa can be accessed as well.
The BDP-LX88 is available in black or silver from December 2014.
The BDP-LX58 is available in black or silver from October 2014.
Follow us on:
http://www.facebook.com/pioneerelectronics
http://www.twitter.com/pioneereurope
http://www.youtube.com/pioneereurope
Caractéristiques Pioneer BDP-LX58 :
•Lecteur Blu-ray 3D universel
•Construction : Double châssis, capot supérieur rigide, plateau anti-vibrations
•Processeur vidéo Marvell Qdeo
•Pixel Precise Driver
•Upscaling 4K/60 Hz (4:4:4/24 bits)
•13 filtres de post-traitements : Progressive Motion/ Pure Cinema/Stream Smoother/YNR/CNR/BNR/MNR/
•Detail/Brightness/Contrast/HUE/Chroma Level/Super Resolution
•DAC ESS Sabre 32 bits (ES9011)
•Traitement PQLS
•Mode Pure Direct
•Wi-Fi / Wi-Fi Direct
•DLNA
•Lecture multimédia USB & uPnP
•iControl AV5 (iOS/Android)
•Connectique : x2 HDMI 2.0, analogique RCA, coaxiale, Zero signal, USB, RS-232, Ethernet.
•Télécommande rétroéclairée
Jvc RS2100, Xtrem 1.1gen2, Lg 77g3, chambre 65s95b, sources: pana ub9000 +pchc+chinoppo+z1000pro,atv4k, XSX, PS5/ 3 Arendal monitor 1723S, 4 Divatech diva18, 6 Svs prime elevation atmos/ Denon Avc-a1h/ sub arendal 1723 1S
david555
Inscription Forum: 02 Oct 2005 18:13
Message » 13 Sep 2014 18:06
Vivement un test pour voir ce que cela donne sur le terrain :)
En tout cas, 700 € et une sortie analogique de qualité, ca va sérieusement concurrencer le oppo 103.
Même si une entrée HDMI aurait été le graal....
Affaire à suivre sérieusement ! :wink:
lodesile
Inscription Forum: 14 Déc 2009 15:56
Message » 01 Oct 2014 17:41
Bon on est en octobre là... :zen:
Et toujours rien :siffle:
hamster
Inscription Forum: 21 Avr 2007 19:27
Message » 01 Oct 2014 18:46
Et quand il sera là... faudra encore attendre la première maj ! :siffle:
Ma salle : >>ici<<
Toile 2m50 XS 1.7, VP 4K SONY VW-590, Ampli DENON AVC-X6700H + EMOTIVA BasX A3, Front DAVIS VINCI Signature, Surround DAVIS MIA40, Sub XTZ 12.17
AppleTV 4K + Infuse Pro, DUNE HD Pro Vision 4K Solo, NAS Syno 44To Raid5, Harmony 950
Solitaire555
Inscription Forum: 17 Jan 2002 2:00
Message » 02 Oct 2014 14:36
hamster
Message » 02 Oct 2014 16:50
il est sur le site http://www.cinemotion.biz/a-1-3635/Pion ... lu-ray.htm
je leur est envoyer un mail pour la disponibilité et leur meilleur prix , courant du moi
coxwenart
Inscription Forum: 15 Avr 2005 17:30
Message » 02 Oct 2014 18:18
Vivement les premiers tests :)
Frenshprince
Inscription Forum: 19 Mar 2008 12:30
Message » 02 Oct 2014 18:56
Solitaire555 a écrit:Et quand il sera là... faudra encore attendre la première maj ! :siffle:
Y pas besoin de 36 maj , j'en ait fait qu'une sur ma LX55 depuis que je l'ais eu et tout fonctionne bien ...
No soucis ... :lol:
Urga
Inscription Forum: 15 Mar 2006 14:35
Message » 02 Oct 2014 21:59
Ah oui ? Tu ne lis pas de DVD alors ... Car ils n'ont jamais résolu le problème de désentrelacement à ce que je sache...
Ma salle : >>ici<<
Solitaire555
Message » 03 Oct 2014 9:53
Solitaire555 a écrit:Ah oui ? Tu ne lis pas de DVD alors ... Car ils n'ont jamais résolu le problème de désentrelacement à ce que je sache...
J'en regarde plus sa fait belle lurette mais pour les DVD ont peu contourner le soucis en envoyant du 1080i et pas du 1080p , surtout que mon Kuro a un désentrelaceur de haute voltige est c'est nickel ... :wink:
Urga
Message » 03 Oct 2014 10:45
Ok, tu peux contourner le problème... Cependant, trouves-tu normal qu'ils n'aient jamais corrigé ce bug et surtout... qu'ils ne le corrigeront probablement jamais ? :evil:
Ma salle : >>ici<<
Solitaire555
Message » 03 Oct 2014 19:09
Pas encore vu de tests de la LX58 , mais déja à la vente ici :
8)
Urga
Message » 03 Oct 2014 20:10
Urga a écrit:Pas encore vu de tests de la LX58 , mais déja à la vente ici :
8)
Hello si tu lis plus haut :oops: je leur ai demandé la dispo , reponse courant du moi
Greg
coxwenart
Message » 06 Oct 2014 19:33
pour moi la question sera de savoir si la 58 peut avoir les meme perf que la 88 est ainsi que la 91 en audio hdmi . Ca me surprend qu'au tarif de la 58 , on a un lecteur de 10kg . C'est ce qui me fait pensé quelle est peut etre excellente en audio .
JR24
Inscription Forum: 01 Aoû 2009 22:09
Message » 01 Nov 2014 16:57
Bonjour à tous.
J'ai eu la chance d'en gagner un à un jeu concours, mais je ne suis pas équipé pour en profiter pleinement. Aussi, si quelqu'un est intéressé...
C'est la version noire, je suis en Île-de-France. Je n'ai pas ouvert du tout le carton.
ma_icol
Inscription Forum: 27 Oct 2008 13:46
Retourner vers Lecteurs Blu-Ray
