![:mdr:](https://www.homecinema-fr.com/forum/images/smilies/icon_mrgreen.gif)
j'ai aussi des enceintes gainées en peau de serpent achetées chez Cobra, mais elles sifflent
![:ane: :ane:](https://www.homecinema-fr.com/forum/images/smilies/ane.gif)
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: blam17, boddhidarma, davt94, Patrice75015, pm57 et 121 invités
Mono&Stereo a écrit:For the housing engineers used composite marble created in casting process. Its shape is chosen in such a way that the sound flowing around the speaker encounters no sharp edges. The interior of the chamber is formed to prevent interference of sound waves. The height of the whole cabinet varies between 170 and 200 cm, and is regulated so that it can be adapted to fit the listening room. Height adjustment can be performed by moving two independent chambers relative to each other. In the lower chamber we have are woofers - two 10-inch speakers with aluminum membranes.
The upper chamber also has a 10-inch mid-woofer with aluminum cone, 7-inch ceramic midrange driver and a diamond tweeter. According to the manufacturer, Extreme has an impressive frequency response starting at 20 Hz and reaching 45 kHz. The crossover uses high-quality components. Despite the weight of 250 kg, the speaker appears to be light due to slender shapes. The world premiere of Estelon's latest design is scheduled for this year's Munich High End exhibition.
MickeyCam a écrit:Bonjour,
j'ai des enceintes à base de farine, quand je pousse le volume, le son est croissant![]()
bon, je sors![]()
Michel...
roland_de_lassus a écrit:Aucune idée...
Sur les Grande Utopia, il faut utiliser une petite manivelle...
Et puis, qui dit moteur dit interférences...
