Tout de façon ca ne sert à rien de revenir la dessus on verra bien quand le jeu sortira
![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
Tout ce que j'espère c'est qu'il sera mieux optimisé sur PC que les derniers
Assassin's Creed. D'après ce que j'ai lu le moteur est différent de celui utilisé pour AC donc on croise les doigts.
CONFIGURATION SYSTÈMEMINIMUMSupported OS: Windows Vista SP2 64bit, Windows 7 SP1 64bit, Windows 8 64bit
Processor: Intel Core 2 Quad Q8400 @ 2.66Ghz or AMD Phenom II X4 940 @ 3.0Ghz
RAM: 6 GB
Video Card: 1024 VRAM DirectX 11 with Shader Model 5.0 (see supported list)
Sound Card: DirectX 9 compatible Sound Card
This product supports 64-bit operating systems ONLYRECOMMENDEDProcessor: Core i7 3770 @ 3.5Ghz or AMD FX-8350 @ 4.0Ghz
RAM: 8 GB
Video Card: 2048 VRAM DirectX 11 with Shader Model 5.0 or higher (see supported list)
Sound Card: Surround Sound 5.1 capable sound card
Supported Video Cards at Time of Release:nVidia GeForce GTX460 or better, GT500, GT600, GT700 series;
AMD Radeon HD5850 or better, HD6000, HD7000, R7 and R9 series
Intel® Iris™ Pro HD 5200
Pour
Assassin's Creed 4 par exemple c'était ca la configuration recommandée :
RECOMMENDEDOperating System: Windows Vista SP2 or Windows 7 SP1 or Windows 8 (
both 32/64bit versions)
Processor: Intel Core i5 2400S @ 2.5 GHz or AMD Phenom II x4 940 @ 3.0 GHz or better
RAM: 4GB or more
Video card: Nvidia GeForce GTX 470 or AMD Radeon HD 5850 (1024MB VRAM with Shader Model 5.0) or better
Additional Notes: Supported video cards at the time of release:Nvidia GeForce GTX 260 or better and GeForce GTX 400, GTX 500, GTX 600 and GTX 700 series. AMD Radeon HD4870 or better and Radeon HD5000, HD6000 and HD7000 series.
Note: Latest GeForce drivers tested: 327.23 for all series. Latest Radeon drivers tested: 13.1 for Radeon HD4000, 13.4 for Radeon HD5000, HD6000 and HD7000 series on Vista and 13.9 for Radeon HD5000, HD6000 and HD7000 series on Win7 and Win8.
On voit bien déjà que
Watch_Dogs demande une configuration bien plus musclée que AC4. Après ca ne vuet pas du tout dire que ca va être optimisé (au contraire même
![:lol:](https://www.homecinema-fr.com/forum/images/smilies/icon_lol.gif)
), mais on peut s'attendre à un très belle version PC
julianf > sauf que non dans les derniers trailers qu'on a vu c'était la version PS4 qui était utilisée (donc forcément pas la meilleure version vu que la version PC est au-dessus). Par contre pour celui de Chicago je ne sais pas mais je ne serai pas étonné que ca le soit aussi. Par contre les mouvements de caméras sont vraiment mais vraiment bizarre.
