ModĂ©rateurs: ModĂ©ration Forum Installations, ModĂ©ration Forum Univers TV, ModĂ©ration Forum Home-CinĂ©ma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistrĂ© et 9 invitĂ©s
LightSpace CMS par Light Illusion
Message » 08 Nov 2013 15:31
CR du disque de TED avec Lightspace sur AVS Forum :
Carbon Ft Print sur AVS Forum a Ă©crit:
JJ's Review of Ted’s Cal Disk :
I luv Ted’s LUT CMS Cal Disk! It represents the first steps into a new world of LUT calibration for Home Cinema/Theater with Light Space (LS). Two words describe Ted’s innovative product: Simple and Complete.
1.Simple: 4 Steps:
a.Measure your probe’s max delay time;
b.Set your patch color read interval (DIP);
c.Start the profile run;
d.Verify the calibration LUT and watch a blu ray movie.
2.Complete: Ted’s LUT Cal Disk:
a.Calibrates the complete video signal path from the Blu Ray Player through to the Display Device;
b.Provides a complete set of Patch Colors and visual Reference Images for pre-calibration display and meter/probe set up, the Light Space LUT profile run and verifying the Calibration LUT. The flow of Ted’s main menu (left to right) reflects this workflow order:
i.Pre-Calibration Tools: Ted’s Ref Images for Pre-Calibration Display and Meter/Probe Setup;
ii.Display Characterization: Ted’s 4,934 Patch Colors (max) used for the Profile Run (i.e. Light Space’s Unique “Calibration” Run);
iii.Color Reproduction: Ted’s Reference Images used for visually Verifying the Calibration LUT by examining Reference Image through (eeColor's) LUT onto the display;
iv.Verify Calibration Tools: Ted’s 4,934 Color Patches (max) used to Verify the Calibration LUT via Light Space’s 3D Modeling Tool and traditionally through Chromapure and CalMAN.
Note: As with other Calibration Disks, you’ll need your own flesh tone images for verification.
I use Light Space with eeColor to calibrate my TVs and Epson Projectors. I’ve seen gamma “quirks” introduced by my OPPO 95 blu ray player which only Light Space can correct (i.e. OPPO does not have sophisticated gamma controls) … so Ted’s LUT Cal Disk is absolutely needed.
So, what's Light Space? These are my thoughts and my own words to describe the value of Light Space LUT CMS Calibration Program based on hundreds of profile runs I’ve performed at home with a K10A and PR-670 meters:
5 Ways to Improve the Picture with LS: Light Space can improve one's picture in 5 different ways (see 1 through 5 below). The first 2 are common with many calibration programs. The last 3 are what gives Light Space its WOW factor. I’ve provided links to the Light Space website for further information. This is what I read to learn Light Space Calibration Fundamentals. If I can do it, you can do it :
1.Display Setup: http://www.lightillusion.com/display_calibration.html ;
2.Probe/Integration: http://www.lightillusion.com/probe_use.html ;
3.LS Profile Math: See below for my explanation ;
4.Eye/Visual Feedback for Post Calibration LUT modification (i.e., correcting grn hues in the gray scale shadows). Search for the word "Filters" twice. It's the second one: http://www.lightillusion.com/lightspace_manual.html ;
5.Source (e.g. Blu Ray Movies) modification with Photoshop: http://www.lightillusion.com/lut_image.html .
Light Space's WOW Factors: Of the 3 WOW factors, (3, 4, and 5 above), LS Profiling Math is the dominate factor for calibration. The other 2 factors (4 and 5) are used after the Calibration LUT has been created so one can make visual “tweaks” (minor changes) to the Calibration LUT. All 5 factors collectively have given me a better picture than any other calibration program I’ve used on the market.
Light Space’s “3D Profiling Math”: is a major differentiating quality factor. LS’s mathematical profiling dramatically increases the precision, range and speed of each color adjustment beyond anything the display or any other calibration software package is capable of doing. Speed, Range and Precision are the cornerstones for accurate display adjustments.
1.Range: can be explained as LS's ability to leverage the display’s oversaturated native gamut to mathematically fine tune the accuracy of the targeted gamut (rec709) … especially at the outside walls of the LUT. One could talk about “meat on the bone” here. The LUT walls are the extreme regions of color space which are most prone to error because this is where a display’s design limitations will be encountered.
2.Precision and Speed: can be explained as a one-two combination of high speed (need a K10A) hard reads (4,913) and LS profiling math that takes into account the display’s design limitations in technology, gamma, color temperature, RGB separation and gamut when adjusting colors. The precision and accuracy of 4,913 hard reads for a 17^3 LUT, when coupled with LS math, will produce over 32,000 accurate color control points for a display. From here, one can analyze and fine tune the display’s 3D color accuracy with diagnostic and modification tools within LS. When eeColor image processor is added to the math, the precision is increased by LS to over 274,000 accurate color control points. These 274,000 accurate color points will control the accuracy of 16.77 million colors for an 8 bit color depth display. LS’s increased range and precision of over 32,000 color control points affects the color adjustment of each of the mini3's 125 control points. The fact the LS is fast allows a professional calibrator to run a 4,913 point calibration (33min) with mods and verification within 1 hour (need K10A). If you use Ted’s LUT CMS Calibration Disk, the total time to collectively generate a calibration LUT(1hr 22min), create mods and perform verification is roughly 1.87 hrs. I would go as far as claiming LS’s range and precision adjustments have produced near perfect shadow grays for my Sony TVs and Epson Projectors where shadow grays are really gray … not grays with slight blue or green or red discoloration. Note: Both THX and ISF classes teach the students to bump Blu Offset a couple of clicks as part of the post calibration workflow to get rid of green!
Item 4, LS Internal LUT Modification Tools: In terms of modifying an existing Calibration LUT, there are 2 sets of tools one can use, for 2 different reasons. Item 4 use LS Filter tools for modifying the gray scale line, particularly in the shadows ... in 3 Dimensions! Visualize the 4,913 LUT cube and a gray scale line extending from the black corner to white corner (it’s a diagonal line going through the middle of the 3D LUT). Light Space provides modification Filter tools that can help keep the gray scale line … gray. The modification tools "tweak" the color and luminance anomalies of the gray scale line and controls the extent to which near by colors are affected by the modification (in 3 dimensions) through range (Low, High), blend and radius settings. I use Relax 0.04, Axis Blend and Smooth Filters, at times. I've had Calibration LUTs where no mods were needed ... but I use Relax at 4% all the time just to be safe. Note: I use mods to imply use of Filters or mods through Photoshop. Generically, they are called mods.
Item 5, LS LUT Modification through Photoshop: permits Photoshop to be used to modify a picture that is imbedded in a Calibration LUT. When you change the picture using Photoshop tools, it automatically changes the Calibration LUT. I’ve done a number of mods for movies. Each Photoshop mod is unique to a specific movie. Not all movies need mods. Not all movies can be mod’d because one has to find ways to limit the extent of the mod to avoid “unintended consequences” in all the scenes. I’ve used Light Space and Photoshop to successfully do this and the changes were noticeable.
The Future of Home Cinema Calibration: The mere existence of both Light Space modification tools (4 and 5) suggests to me that the future of Home Cinema calibration will extend into 3 Dimensional modification of the Calibration LUT and of Source Content, such as Blu Ray movies. My most complicated Blu Ray movie mod took me 2 months to do and resulted in lifting an image of a near invisible space ship without affecting the rest of the “Prometheus” movie.
Wrap Up: So, please consider Ted’s LUT CMS Calibration Disk. It’s very good. Also, consider Light Space (they have 2 offerings for Home Cinema) and eeColor box (or a radiance box if you already have one) as an investment for the future, the future of LUT calibration in Home Cinema. IMHO, Light Space is leading this effort and is, pardon the pun, light years ahead of the competition.
Kind Regards,
JJ
P.S. If you're interest in a consolidated explanation of how to use Light Space: http://www.lightillusion.com/idiots_guide.html
Edited by Carbon Ft Print - Today at 12:00 pm
realzven
Inscription Forum: 13 Mar 2010 15:19
Message » 08 Nov 2013 15:41
un autre CR sur http://www.avsforum.com/t/1454804/teds-lightspace-cms-calibration-disk/180#post_23924609
I had some time to explore the complete disc. It's really an awsome bunge of calibration and verification pattern that I never found on any other disc.
Also I'd run a quick profile with LighSpace DPS and Ted's disc to verify my TV's calibration done with a Radiance as generator and Calman 5.1 with C6 meter. The disc synced perfect with LightSpace.
For that value of money Ted's disc is clearly the best on the market and a must have for every calibrator or enthusiast.
Thank's Ted for Your great work !
realzven
Message » 07 DĂ©c 2013 17:57
Bonjour Ă  tous.
Pour information, je viens de m'équiper d'un PC portable que je vais dédier à la calibration (j'utilisais jusqu'ici mon PCHC qui doit faire au moins 15 kg :lol: ). J'ai donc demandé à Light Illusion de bien vouloir réinitialiser ma licence puisque cette dernière est liée au matériel sur lequel LSCMS a été activé la toute première fois. Deux heures après ma demande faite par email, j'ai pu installer LSCMS sur mon nouveau PC portable à base de windows 8.1 (un peu déroutant comme OS mais on s'y fait). Tout fonctionne à merveille.
a+
alex_t
Membre HCFR Contributeur
Inscription Forum: 29 Oct 2005 23:04
Message » 07 DĂ©c 2013 22:45
Et tu a pu tester LS hcl avec le disque de Ted ?
realzven
Message » 08 DĂ©c 2013 0:32
realzven a Ă©crit:Et tu a pu tester LS hcl avec le disque de Ted ?
Oui je l'avais testé avec un quick profil (plus de 140 points) et c'était parfait.
Je ne vais pas tarder Ă  me refaire une calibration, je te dirai si jamais j'utilise de nouveau le disque de TED.
a+
alex_t
Message » 08 DĂ©c 2013 16:59
:wink:
realzven
Message » 18 DĂ©c 2013 0:15
Salut Ă  tous :D
Un bon plan qui pourrait vous intéresser :
http://www.convergent-av.co.uk/forum/in ... 6889aa18bd
From Gordon Frazer "convergent-av
As many of you know i am using Lightspace to do all my Lumagen 3D LUT calibrations these days. I know it's expensive for most consumers but i've been speaking with LightIllusion and i've managed to persuade them to do a special deal for Lumagen users here.
If we can get 15 folk to sign up for a copy of LightSpace HCC they will reduce the price for those 15 (or more) by 45%. If you want to be part of this special XMAS deal then respond with your interest in this thread and when we hit 15 I'll direct you how to pay to get your licence key.
I'm not making any money on this, I just want lumagen users to get the very best performance possible!
Merry Christmas!
Gordon
Ă€ + ;)
realzven
Message » 18 DĂ©c 2013 10:18
C'est intéressant, même si perso je lorgne plutôt sur Lightspace HCL.
Le HCC c'est "too much" pour mon utilisation mais pour ceux qui en ont l'utilité, c'est une super offre...
PingouMasqué
Inscription Forum: 07 DĂ©c 2007 10:14
Message » 26 DĂ©c 2013 22:16
LSCMS propose désormais une caractérisation sur 21x21x21 points ainsi que la possibilité de créer ses propres mires.
Dispo en version beta il faut envoyer un email pour avoir la version.
alex_t
Message » 01 Jan 2014 12:20
alex_t a écrit:Les résultats sont même excellents !
Mes résultats sont visibles sur le topic calibration X35 à partir de ce message: post177804610.html#p177804610
(réalisé via un profil 3DCUBE 17^3, 3DLUT sur 729 points)
a+
Pour commencer une bonne année à tous... :friend:
Serait-il possible que tu mettes Ă  disposition un fichier 3dlut exploitable par Madvr ?
je suppose que tu as lancé ta calibration avec tous les réglages du x35 à zéro ...
Je suis conscient qu'une calibration s'entend in situ, j'ai le sentiment que certaines dérives chromatiques pourraient être corrigées..
Cela serait l'occasion de tester le 3dlut de madvr au niveau de la rapidité d'interprétation software ...
si le rendu est mieux tant mieux .... je suis en sortie 0.255
merci Ă  toi
boubouamiss
Inscription Forum: 17 DĂ©c 2006 14:54
Message » 01 Jan 2014 12:33
boubouamiss a Ă©crit:
a+
merci Ă  toi
Salut.
J'ai prévu de faire deux 3DLUT dédiées à madVR d'ici la fin du mois : les 3DLUT seront faites depuis un "petit" profil (7x7x7 ou 9x9x9) des chaines vidéo suivantes :
1) PCHC (madVR RVB 0-255) > Lumagen Radiance (RVB 0-255 in / YCbCr 422 16-235 out) > JVC X35 (YCbCr 422 /HDMI standard)
2) PCHC (madVR RVB 0-255) > Lumagen Radiance (RVB 0-255 in / RVB 0-255 out) > JVC X35 (RVB / HDMI Ă©tendue)
A chaque fois le JVC X35 sera pré calibré manuellement pour optimiser au mieux ses capacités. (c'est une étape obligatoire pour obtenir la meilleure 3DLUT possible)
Je ne peux pas enlever le Radiance mais il sait se faire très transparent pour le cas 2).
Je testerai et posterai mes impressions.
alex_t
Message » 01 Jan 2014 13:29
Merci Alex pour ces infos et bonne année :D
realzven
Message » 01 Jan 2014 13:39
merci en core et vivement la fin du mois !
boubouamiss
Message » 01 Jan 2014 13:48
alex_t a Ă©crit:
a+
merci Ă  toi
Salut.
Pour tester madVR et sa gestion 3dlut autant faire une caractérisation en 17^3 (on peut aller au delà) et directement brancher le PC sans Scaler pour éviter les intermédiaires inutiles.
Coxwell
Inscription Forum: 19 Mar 2002 2:00
Message » 01 Jan 2014 16:54
Comme il s agit de faire un test, je n ai pas l intention de chambouler mon installation (je laisse donc le radiance) ni d y passer trop de temps (d oĂą le profil sur moins de points)
alex_t
Retourner vers Les logiciels de calibration
