quelqu'un connait cet ampli qui serait une bombe atomique, rivalisant avec des amplis mini 5x plus cher?
Des revues/tests dithyrambiques sont consultables sur le net.
Prix 1700 dollars
![Image](http://www.jobsys.com/JOB225small.jpg)
http://www.jobsys.com/job225doc.htm
http://www.6moons.com/audioreviews/job/1.html
POWER
Nominal Power: 125W on 8 Ohms per channel
Power RMS (Goldmund FPP Standard): 210W on 8 Ohms each channel
Nominal line voltage: 117 V
Input voltage range: +/- 15 %.
FREQUENCY RESPONSE
These figures are valid for any level between 0 and nominal power.
+/- 0.5 dB, 10 Hz - .1 MHz.
+/- 3 dB, 2 Hz - 0.9 MHz.
INPUT SENSITIVITY
Nominal level : 0.75 V.
Unbalanced only (RCA).
51k input impedance.
GROUP DELAY LINEARITY
Propagation delay < 80 ns stable with frequency from 2Hz to 200 kHz.
DISTORTION
Figures valid for all levels from 0 to 25 V / 8 Ohms.
Dynamic : TID < 0.01 % (- 80 dB).
Static : THD < 0.01 % (- 80 dB).
SPEED
Slew rate : > 60 V/m s.
Rise time : < 200 ns.
NOISE
Weighted ASA A : > 100 dB.
OPERATING TEMPERATURE
Room temperature : -30 to +40 degrees Celsius ( -22 to +104 degrees Fahrenheit).
Internal temperature : +45 to +65 degrees Celsius ( +113 to +149 degrees Fahrenheit).
POWER SUPPLY
Nominal line voltage : 117 V.
Toroidal Power Transformer to minimize radiated noise
2 separated power supplies (left and right)
Maximum power consumption : 450 W.
SIZE AND WEIGHT
36cm (11.8") W x 24.5cm (11.2") D x 8.8cm (2.4") H. - Weight : 7kg (15.4 lbs) net.
