Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: olivier94 et 10 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
Scalers Lumagen Radiance 20XX Darbee/CMS 729 points/UHD
Message » 22 Mai 2013 7:26
Thanks Gordon.
gordon@convergentav a écrit:Lumagen® Announces Three New Radiance™ Video Processors
Beaverton Oregon, May 21, 2013 – Today, Lumagen® is announcing the availability of the three additional Radiance™ 20XX family video processors.
The first, the Radiance 2022, adds analog video inputs, and associated audio inputs, to the previously announced Radiance 2021. The Radiance 2022 has an input complement of four HDMI, two Component, two SVideo, and two Composite video, matching the RadianceXS-3D for video, and audio, I/O.
Lumagen is also introducing the Radiance 2041, and the Radiance 2042, which increase the maximum output rate to 4k at 30 Hertz for the Radiance 2021, and Radiance 2022, respectively.
All Radiance 20XX products include the video calibration and setup features of the award winning Radiance product line, along with integrated Darbee DVP™ technology. Setup and calibration features include 125-point linear-Gamma RGB color palette CMS, 21-point parametric gray-scale and Gamma, a host of setup features, Lumagen’s industry leading No-Ring™ scaling technology, and support for 3D scaling and conversion between 3D formats for displays and projectors that do not support all the common 3D formats
Lumagen’s president Jim Peterson stated, “Our customers have been asking us for a product that they can use to drive their 4k displays and projectors at their native 4k rate so they can use Lumagen’s reference quality NoRing™ scaling to convert standard and high definition sources to 4k. With the introduction of these new products, the Radiance family can now support this request.”
UK Pricing to come, as always, it'll be competitive.
Information émise sur le site de Lumagen: http://www.lumagen.com/testindex.php?module=news
alex_t
Membre HCFR Contributeur
Inscription Forum: 29 Oct 2005 23:04
Message » 22 Mai 2013 7:47
Mise à jour du titre et des premiers messages du topic.
La famille 20xx : 4 produits
Voir le site Lumagen pour la description détaillée: http://www.lumagen.com/testindex.php?module=products
ATTENTION: Tous les matériels ne sont pas compatibles 4K.
Elle se divise en 2 types de modèle : 202x (2K in - 2K out) et 204x (2K in - 2K/4K out):
Radiance 2021 : 2K in - 2K out + 3D
Entrées: 4 x HDMI 1.4 1080P (2K)
Sorties: 2 x hdmi 1.4 1080P (2K) et 1 sortie SPDIF coaxiale
Contrôle: IR + 1xRS232
Disponible
Radiance 2041 : 2K in - 2K/4k out + 3D
comme le 2021 avec (si j'ai bien saisi) l'upscale 4K en sortie.
Sorties: 2 x hdmi compatibles 2K et 4K (@30Hz) et 1 sortie SPDIF coaxiale
Disponibilité annoncée
Radiance 2022 : 2K in - 2K out + 3D
Même nombre d'entrées/sorties que le Radiance XS actuel.
Entrées et sorties compatibles uniquement 2K
Radiance 2042 : 2K in - 2K/4k out + 3D
comme le 2022 mais avec sortie 2K et 4K (@30Hz)
alex_t
Message » 22 Mai 2013 9:27
Le prix de vente recommandé pour ces unités dans l'Union européenne est
MINI3D £ 1,275 € 1,495
2021 £ 1995 € 2295
2022 £ 2295 € 2650
2041 £ 2450 € 2850
2042 £ 2750 € 3195
Ce sont juste prix suggéré. Pour la tarification réelle "rue" au moment de l'achat s'il vous plaît contactez votre revendeur. Le ci-dessus comprennent les taxes de vente dans l'UE, mais excluent expédition.
gordon@convergentav
Pro-Commercant
Pro-Commercant
Inscription Forum: 05 Juil 2012 15:26
Message » 22 Mai 2013 15:57
J'ai réalisé un auto-calibrage avec Chromapure 2.4.1.
Mais le rendu était moins bien que le calibrage usine...
Mon JVC X35 n'a qu'une trentaine d'heures, j'essayerai plus tard.
Remarque:
Sur de la vidéo ou des émissions TV SD, on a pas mal d'artefacts.
Par contre en HD c'est nickel.
Avec mon G90 la SD était bien sur moins définie, mais sans artefacts.
Donc question:
c'est inhérent au X35, au Radiance 2021 ou au couple?
Yves
ysati
Inscription Forum: 13 Mai 2002 12:14
Message » 22 Mai 2013 16:18
De quels types d'artefact parles-tu ?
J'ai le 2021 et le X35 et l'image est quasi parfaite que ce soit en SD (je regarde beaucoup de DVD, pas de TV) ou en HD (720p PCHC, blu-ray, DVHS 1080i).
Pour info je calibre ma chaine vidéo avec Calman 511 et une sonde C6 [ Calibration manuelle du X35 (gamma et échelle de gris) puis calibration automatique 3D LUT via le Radiance.
En SD il faut baisser les réglages sharpness de la VXP : ne pas dépasser 2 ou 3 sur tous les paramètres. Pour Darbee même combat, j'ai néanmoins trouvé un bon compromis en utilisant le mode POP a 20%.
Ne pas oublier aussi de désactiver tous les processings vidéo du X35 (mettre tout à 0)
alex_t
Message » 22 Mai 2013 17:16
Je ne parle que de la TV.
Les DVD pas de problème.
Quand je dis artefacts, c'est un halo autour des personnages ou des objets, comme si on poussait
trop le détail et la netteté...
Cela apparaît surtout sur les images en second plan.
Les arrières plans fourmillent un peu.
Mais c'est uniquement sur la TV non HD.
J'avais paramétré la VXP comme tu le suggérait, 6,6,6 et 7,7,7.
Mais j'ai nettement réduit, car sur des vidéos de mauvaise qualité, ça ne passait pas.
Maintenant le but c'est de regarder de la HD et là c'est top.
Même le G90 n'arrivait pas à ce niveau...
Pour revenir sur la Sd, quand je mets le crystalio 3800 avant le radiance 2021,
ça passe mieux, car c'est le Faroudja du Crystalio, qui prend la relève.
Yves
ysati
Message » 22 Mai 2013 17:29
ysati a écrit:Je ne parle que de la TV.
Yves
OK.
Comment as-tu configuré la source non HD pour ta TV ?
Il faut impérativement réduire le sharpness de la VXP maxi 2 ou 3. Comment as-tu configuré le NR VXP ?
alex_t
Message » 22 Mai 2013 19:32
If you are seeing ringing on SD material that you do not see on the C11 then you have something not set up correctly. Most likely sharpness in scaler. The lumagen upscaling adds no edge enhencement unlike that in the crystalio. So any ringing has to be from sharpness control or is being added by a broadcaster. Sorry for replying in English. In a rush and just wanted to answer quickly
gordon@convergentav
Pro-Commercant
Pro-Commercant
Message » 22 Mai 2013 19:47
Merci Alex_t et Gordon.
je vais vérifier ces paramètres et vous informe.
Yves
ysati
Message » 23 Mai 2013 10:43
Yves
OK.
J'ai mis le sharpness à 2 et 3
Le NR à 3
Maintenant c'est nettement mieux, sur la SD.
Les émissions TV HD ou SD sont émises en 1080i.
Donc le Radiance est en 108i en input et sort en 1080p.
Tu suggères de mettre le Radiance à 576 en input?
Par contre comme j'ai seulement une quarantaine d'heures sur le X35, je n'ai pas encore fait de calibrage.
Yves
ysati
Message » 23 Mai 2013 13:13
ysati a écrit:J'ai mis le sharpness à 2 et 3
Le NR à 3
Yves
Le mieux serait de configurer ta source TV de la manière suivante:
Si SD alors sortir en 576i YCbCr 422 (ou 576p YCbCr 422 et tu actives la fonction reinterlace du Radiance)
Si HD alors sortir en 1080i50 YCbCr 422
Si ta SD sort en 1080i cela signifie que l'upscale est réalisé par la source et que tu perds le No Ring scaling du Radiance. Si c'est le cas il est alors fort probable que tes soucis de double contour proviennent du scaling perfectible de la source. Dans ce cas je te conseille les réglages suivants: sharpness VXP tout à 0, Darbee à ON avec un réglage à ta convenance.
Dans tous les cas, avec le X35, pour la SD (non upscalé par la source) je te conseille les réglages NR suivants:
2D/3D noise : maxi 3
MPEG NR : maxi 2
Mosquito NR: maxi 3
pour la HD, avec le X35, je te conseille les réglages NR suivants:
MPEG NR : maxi 1
Mosquito NR: maxi 5
alex_t
Message » 23 Mai 2013 15:09
Le NR à 3
Yves
MPEG NR : maxi 2
Mosquito NR: maxi 3
MPEG NR : maxi 1
Mosquito NR: maxi 5
Merci alex_t.
J'en attendais pas moins de toi.
Je vais suivre tes préconisations et je t'informe.
Yves
ysati
Message » 24 Mai 2013 9:23
gordon@convergentav a écrit:Le prix de vente recommandé pour ces unités dans l'Union européenne est
2021 £ 1995 € 2295
2022 £ 2295 € 2650
2041 £ 2450 € 2850
2042 £ 2750 € 3195
Merci Gordon,
Le 2ieme post du topic est mis à jour.
alex_t
Message » 24 Mai 2013 11:08
YSATI: je ne connais pas ta source TV mais avec mon ADSL SFR (boitier gris Netgem) le signal sort en 1080i RVB.
jazzliberator
Inscription Forum: 10 Mai 2008 21:24
Message » 24 Mai 2013 12:06
jazzliberator a écrit:YSATI: je ne connais pas ta source TV mais avec mon ADSL SFR (boitier gris Netgem) le signal sort en 1080i RVB.
Oui j'ai la même résolution en TV SD, 1080i RVB.
J'ai un HUMAX TN5050HDR, ça marche bien.
Yves
ysati
Retourner vers Processeurs Vidéo
