Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Andréiko, Bing [Bot], Gebulon, LE PIRATE et 167 invités
Denon 2013: X2000,X3000 et 4000 (MultiEQ XT32):
Message » 18 Avr 2013 17:26
Je lance le post des Denon 2013.
d'après les dernières rumeurs de AvS , le x4000 (le remplaçant du 3313) on voit l'apparition du la calibration XT32 :love: et le LFC.
pour les modèles inférieurs on reste dans le classique de l'année dernière...Multi eq XT.
AVR- X2000 / Avril 2013/b] =700 Euros
Discrete 7x95w amp, Intense sound tuning (sound upgrade), Audyssey MultEQ XT, optimized bass redirection, 4k video passthrough & scaling, network integration with AirPlay, Internet Radio, DLNA, load. FM, Spotify, Flickr, ALAC, 192/24 WAV / FLAC, 7 HDMI inputs, USB with iPod / iPad / iPhone Direct, 2 zone / 2 sources
[b] AVR-X3000 /Mai
=1 000 Euros
Discrete 7x105 amp, big power amp design for optimum sound, Audyssey MultEQ XT, ready for Audyssey Pro, DTS Neo: X, Audyssey DSX, 4k-video switching, GUI overlay and scaling, flexibility / expandability, network integration with AirPlay, Internet Radio, DLNA, Last.FM, Spotify, Flickr, 7 HDMI inputs m. And Silicon Image, 2 HDMI outputs (1 x HDMI output Zone2), 7.2-channel preamp output, USB with iPod / iPad / iPhone Direct, 2 zone / 2 sources + InstaPrevue function
http://usa.denon.com/us/product/pages/p ... denonna%29
AVR-X4000 /Juin/b] =1500 E
Complete 9.2-channel signal processing with Audyssey DSX and [b]DTS Neo: X
, Discrete 7-channel amplifier with 125 w, Audyssey MultEQ XT32 (prepared for Audyssey Pro),Audyssey Lfc, two independent subwoofer outputs, 4k-video switching , DDSC-HD, AL24 Processing Plus, Clock Jitter Reducer, Denon Link HD, network integration with AirPlay, Internet Radio, DLNA, Last.FM, Spotify, Flickr, 7 HDMI inputs (including 1 x front) m. And Silicon Image, 2 HDMI outputs (simultaneous) + an additional Zone 2
+Audyssey LFC (Low Frequency Containment) processing provides a full range tonal balance for late-night listening that minimizes deep bass content from intruding into adjacent rooms or spaces.
+Audyssey Sub EQ HT provides individual tailoring for dual subwoofer setups.
+ 2 puces Analog Devices 32-bit DSP's vs one for others
mise à jour X2000 x 3000 et x 4000....
A new firmware update is available
X4000
X4000
1. 6/4/2013
- Usage Data default changed to OFF.
- Use of Denon Remote app becomes abnormal
- When Airplay has been selected using the remote app and another network source is then selected, app doesn't change from Airplay
- When both Zone2 and HDMI Pass Through are OFF, and unit is restarted, when Menu selected GUI is not displayed
- Popup information description of Russion is wrong
- When TV format is PAL, the aspect ratio is incorrect.
- When not setting Usage Data, the popup display of restart was added to the specification
2. 7/18/2013
- VIewing photos vis USB interface, the 4:3 image is stretched in width severely
- When Usage Data is set to OFF, the PopUp display of restart was added to the specification
- Setup Assistant starts by connecting the HDMI cable
- After the firmware is update, the device is not found via the iOS application
- Spelling mistakes on Web GUI
3. 2/19/2014
- Crestron update
- Sirius XM API2.0
- When DTS-HD MA 96k audio is streamed, there is noise or no output
- Noise from DD+ stream from Netflix
- WMA 11/12 files not playing
- Noise from WAV file in NAS (Twonky Server 7) via remote app
- MSLEFT and MSRIGHT of the AMX command
- Noise between tracks of FLAC file
- No communication with Buffalo LInkStation
- No sound from SW in PURE DIRECT
- DIalogue Enhancer set by Menu is not memorized
- When connected Server shuts down in the Resume play of Last Station of iRadio, the browsing of iRadio cannot be done
4. 2/18/2015
- Sometimes cannot turn on the power of the unit via C4 or/and Application. (No response at "PW?" command of AMX.)
- Sometimes cannot control Pandora in multi zone via Crestron
5. 11/12/2015
- When the customer connects the iPod/USB or Media Server to the AV Receiver and music is played, the product did an unnecessary access to server of the Last.fm. Therefore, when the Last.fm server, failed, playback of music from the iPod/USB and Media Server stopped.
- When the AV Receiver receives the signals other than POWER ON by Remote controller during standby, the AV Receiver reacts and Standby LED lights up and after 5 seconds lights off. (The AV receiver doesn't work.)
- When the customer is playing contents of DD+ signal of the Netflix Stream with the volume at position of "00dB" by AV receiver, the noises of high pitched "screech" or "chirp" might be heard from the speaker at random. (The noise is especially heard from the speaker of the Surround Left channel.)
X3000
1. 6/4/2013
- See upate for the X4000 for same date
2. 7/18/2013
- See update for the X4000 for same date
X2000
1. 7/18/2013
gegeflipp75
Inscription Forum: 12 Déc 2007 16:00
Message » 18 Avr 2013 20:17
sll33
Inscription Forum: 08 Oct 2008 9:35
Message » 18 Avr 2013 22:07
sll33 a écrit:http://www.futureland.fr/AVR-X4000-NOIR-p-35254-c-423_66.html
il ya des erreurs sur cette page qui présente le x4000...
exemple:
De plus, l'AVR-X2000 présente des nouvelles bornes
gegeflipp75
Message » 26 Avr 2013 7:54
Source Avs
http://www.avsforum.com/t/1465528/the-o ... ead-faq/30
Online found a Denon.eu data sheet PDF on the AVR-X4000 now.
NEW FEATURES AVR-X4000 MultEQ-XT32 :love:
Horizontal color-coded layout of the 11 speaker terminals
Label sheet for marking Speaker Wires & HDMI Cables
Improved Setup Assistant, providing easy-to-follow setup instructions and pictures with Graphical User Interface (Advanced GUI, 9-languages)
9.2 signal processing (with 2 independent subwoofers)
11.2 pre-out for main zone
Audyssey MultEQ-XT32 :love: for higher resolution room correction
Audyssey LFC for best late-night bass experience without disturbing neighbours
Optimised Bass redirection, for powerful bass performance in configurations without subwoofer DTS-Neo:X (up to 9.1) InstaPrevue, to preview HDMI input sources on screen
Zone2/3 output from 2-channel digital PCM sources (coaxial, optical, HDMI, network)
From a another source is the data sheet PDF from Denon.eu against AVR-X3000
NEW FEATURES AVR-X3000 MultEQ-XT :evil:
Horizontal color-coded layout of speaker terminals
DTS-Neo:X (up to 7.1)
6+1 (front) HDMI inputs with 3D, CEC and ARC support
HDMI output for Zone2
Zone2 output from 2-channel digital PCM sources (coaxial,optical, HDMI, network)
gegeflipp75
Message » 29 Avr 2013 15:16
Moi qui m'apprétais à commander un des derniers 4311 encore en vente, la sortie très prochaine de ce X4000 va me faire attendre un petit peu! La seule chose que je reprochais au 3113 étant le MultEQ XT au lieu du MultEQ XT32, ce X4000 s'il est proposé au prix du 3113 sera une excellente affaire.
Morg81
Inscription Forum: 10 Avr 2008 9:46
Message » 29 Avr 2013 15:28
En fouinant plus en avant sur le net, j'ai trouvé sur le forum AVS un lien vers la datasheet officielle du X4000 sur Denon.eu :grad:
Donc a priori confirmation:
- MultEQ XT32
- LFC
- 7 canaux amplifiables, 9.2 sorties (à comparer aux, respectivement, 9 et 11.2 pour les 4311 et 4520)
- DTS-Neo:X, Audyssey DSX et Dolby Prologic TTz
- 3 sorties HDMi
- etc.
Prix public prévu: 1'299 $ // 1'199£ donc on peut tabler sur du 1'299€ prix public :thks:
A suivre!
Morg81
Message » 29 Avr 2013 18:15
Je viens d'appeler Illel et ils le font à 1490 euros; sortie prévue danns un mois.En tous les cas, il a l'air prometteur et, épaulé d'un bloc de puissance et/ou ampli hifi en bypass, peut peut-être venir taquiner son grand frêre le 4520 en utilisation homecinema...A espérer...
arno-ivanitch
Inscription Forum: 03 Mai 2008 11:09
Message » 29 Avr 2013 21:36
Le MultiEQ XT32 peut-il a lui seul justifier la différence de tarif entre un 3313 et ce nouveau X4000 ? Avez-vous remarqué d'autres points largement en faveur de ce dernier par rapport au 3313 ? D'avance merci !
Cut350
Inscription Forum: 03 Déc 2009 19:27
Message » 30 Avr 2013 9:22
Perso, j'ai failli prendre le 3313 en regard du prix actuel (c'est fou ce que c'est la dévaluation... :mdr: ).Puis cette annonce d'un remplaçant ayant, enfin, le xt32 me fait réfléchir...ou alors attendre que le 4520 voit son prix, trop élevé actuellement à mon goût, baisser.C'est pour une écoute exclusivement homecinema accompagné d'un ampli hifi en bypass...
arno-ivanitch
Message » 30 Avr 2013 11:14
Oui super intéressant ce X4000 pour profiter du XT32 :love:. Il y a plus qu'à attendre un an pour le prendre à 700 euros :mdr:
vindermere
Modérateur Installations
Inscription Forum: 06 Déc 2006 19:26
Message » 30 Avr 2013 19:22
dans un an il sera dépassé et il faudra attendre son remplaçant, mais qui sera trop cher, donc attendre encore un an qu'il baisse aussi, mais il sera également dépassé ... :ko:
teter35
Inscription Forum: 03 Aoû 2011 19:43
Message » 30 Avr 2013 21:47
teter35 a écrit:dans un an il sera dépassé et il faudra attendre son remplaçant, mais qui sera trop cher, donc attendre encore un an qu'il baisse aussi, mais il sera également dépassé ... :ko:
C'est pas vraiment le cas de figure ici puisqu'on doit considérer le vrai saut qualitatif entre le multiEQ XT et XT 32. Un tel passage n'est pas une évolution du même ordre que l'ajout de 5 watt et le passage d'une façade plastique à alu.
Ca redeviendra probablement valable entre le X4000 et son successeur ceci dit.
Marlo
Inscription Forum: 18 Avr 2008 1:39
Message » 01 Mai 2013 8:24
tout comme le 4520 on peut noter l'utilisation sur le x4000 de 2 puces Analog Devices 32-bit DSP's contre une seule sur le 3313...
ps
le 3310 était multi EQ
le 3311, 3312 et 3313 étaient multi eq XT
le 3314 (x4000) XT 32....
avant qu'arrive un hypothétique Xt64 :ane: on a quelques années devant soi pour profiter de ce beau denon...lol
gegeflipp75
Message » 01 Mai 2013 10:24
gegeflipp75 a écrit:tout comme le 4520 on peut noter l'utilisation sur le x4000 de 2 puces Analog Devices 32-bit DSP's contre une seule sur le 3313...
ps
Exactement, LE truc qui rends ce X4000 réellement intéressant est le passage au XT32! Avec un prix "réel" qui devrait assez rapidement flirter avec les 1'000€ c'est vraiment très sympa :D
Morg81
Message » 01 Mai 2013 10:54
C'est sympa, mais dommage qu'ils n'aient pas emboité le pas de onkyo plus tôt avec leur 818.
Marlo
