Modérateurs: Modération Forum Home-Cinéma, Modération Forum Installations, Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 6 invités
CalMAN V4 et V5 et CalMAN FOR
Message » 03 Avr 2013 13:35
Bonjour ,
Comment fonctionne une autocalibration sur un plasma VT50 avec le logiciel , comment faut il brancher le tout entre les mires , le tv , le pc et la sonde ? c'est par ethernet ?
Blutbad
Inscription Forum: 03 Avr 2013 13:12
Message » 03 Avr 2013 14:06
Blutbad a écrit:Bonjour ,
bonjour tu vas utilise un dvd de mires ou autres
babar710
Pro-Commercant
Pro-Commercant
Inscription Forum: 11 Aoû 2008 10:43
Message » 03 Avr 2013 14:10
un dvd de mires
Blutbad
Message » 03 Avr 2013 14:57
Comme le AVS HD 709 qui est un choix possible comme source dans Calman.
hydrosaure
Inscription Forum: 12 Sep 2005 14:49
Message » 06 Avr 2013 16:02
Nouvelle version de Calman 5 beta. Il y a du lourd !
CalMAN 5.1.1 build 1179
New features
- AutoCal now supports CMS calibrations at multiple saturation and luminance levels. Options available will depend upon the capabilities of the pattern generator.
- The ColorChecker has now been expanded to include many options, including custom color patches. Selections are available under Options for the layout. Custom patches can be created in the Custom Color Set Editor found under the Start Menu.
- Updated DVDO Duo support to use native controls
- Added support for Flanders Scientific displays in the Cube Generator
Bug Fixes
- WORKFLOW.NextTab/PreviousTab commands now work again
- CalMAN properly switches to a new tab when it is created
- CalMAN no longer crashes when a tab is deleted
- Fixed localization issue with datagrid scaling on some international versions of windows
- Fixed typo for CSV format in drop down for the Cube Generator
- Fixed issue with AutoCal when choosing an elevated black level
- Fixed issue with the Levels editor where 30 and 70 would show up as 30.2 and 70.2 when creating new custom levels
Known Issues
- New displays created in the customer database prior to starting a new session will be created under the default customer instead of the selected customer
- We are seeing some cases where modified text is saving incorrectly. Everything will look fine until the workflow is reloaded.
- Issue with VP50 as pattern generator
- CalMAN will give an error if you go to change the pattern size before initializing a DPG. It affects the DPG-1000/1200/1400/2000.
- Drop down for the Option/NominalLevels data field incorrectly reads SelectorVideo and SelectorPC instead of just Video and PC.
- Some users might see an error on upgrade or uninstall about being unable to remove a shortcut.
- Mouse overs on graphs which have a target line (such as Gamma and Color temperature) are not currently working
- Some machines may experience issues trying to export a report to PDF
- Once in a while when entering a layout, the slider bar will default to a different run type than what is set for the layout. This is intermittent behavior and somewhat uncommon. Current workaround is to click on one of the graphs. This will reset the slider bar to the correct run type
- When a meter has a Units selection option, CalMAN does not display any notes that may be available for that meter
- When saving a workflow over an existing uncompressed workflow, that workflow will save as uncompressed.
- CalMAN is not always able to change modes in the DDC controls with the JVC RS50. Work around is to select the desired display mode in the projector prior to connection.
- We have reports of problems with the pattern generator in JVC projectors and it may be related to firmware versions. We are currently looking into this.
alex_t
Membre HCFR Contributeur
Inscription Forum: 29 Oct 2005 23:04
Message » 07 Avr 2013 1:27
Bonjour à tous
Où peut on trouver une sonde c6 en france? Je n'ai trouvé que sur un site allemand.
Aleks
aleks755
Inscription Forum: 05 Fév 2013 16:57
Message » 07 Avr 2013 1:34
Sur youtube tape "vt50 calibration" il y a un super tuto automatique
J'espère que cela t'aidera
Aleks
aleks755
Message » 07 Avr 2013 11:13
-AutoCal now supports CMS calibrations at multiple saturation and luminance levels. Options available will depend upon the capabilities of the pattern generator.
Cela voudrait dire qu'avec un Radiance, par exemple, on pourrait demander de faire une autocalibration à 25% 50% 75% et 100% directement sans avoir à le faire 4 fois comme avant ?
deuch
Inscription Forum: 08 Mai 2000 2:00
Message » 07 Avr 2013 23:20
Salut Alex,
Est-ce cette maj qui permettrait l'autocal directe des JVC x75, x95 ?
Alain.
SAVY
Inscription Forum: 30 Mai 2007 2:48
Message » 08 Avr 2013 0:17
SAVY a écrit:Salut Alex,
Alain.
Salut.
Non pas encore. Il faut attendre la 5.2
alex_t
Message » 08 Avr 2013 13:24
Dommage,
Elle se fait bien désirée cette nouvelle maj 5.2 :-?
SAVY
Message » 08 Avr 2013 13:36
Quelle sonde utilisez vous avec calman5?
aleks755
Message » 08 Avr 2013 13:41
i1Pro et i1 Display 3 OEM
deuch
Message » 08 Avr 2013 13:48
X-rite eodis3 display pro
aleks755
Message » 08 Avr 2013 13:49
Je la trouve à 195 € c'est bien celle la?
aleks755
Retourner vers Les logiciels de calibration
