![Image](http://img15.hostingpics.net/pics/786266741.jpg)
![Image](http://img15.hostingpics.net/pics/370592362.jpg)
![Image](http://img15.hostingpics.net/pics/304051693.jpg)
Lien vers le site WEB du constructeur : http://www.primare.net/product.asp?ProductID=56
Features
· Crystal CS 4398 24/192 Stereo DAC Advanced multi-bit Delta-Sigma architecture (BD32)
· SRC 4392 2 channel high performance asynchronous sample rate converter with a digital interface receiver
· Fully balanced analogue output stage (BD32)
· OPA 2134 High Performing Audio Operational Amplifiers
· 3 Analogue power supplies
· 4 Digital power supplies
· 1 Standby power supply
· 4 layer print to the best possible signal to noise.
· An audiophile relay controlled MUTE circuit
· Fully Linear PLS (R-Core)
· Signal to Noise 120dB
· Outputs: 1 pair XLR and 1 pair RCA (both 4,3V)
· Output impedance : RCA 100Ohm - XLR 110Ohm
· Inputs: 1x asynchronous USB-B, 1x AES/EBU, 3x Optical, 3x Coax S/PDIF
· XMOS 24/192 USB 2.0 and MCU (MCU only in this design).
· Input selection, DIM, ON/OFF can be operated by remote C23 or C33. (select MEDIA)
· Dimensions 430 x 370 x 95mm
· Power consumption : Standby 0,5W - Operation 60W
· Weight : 8.5kg
· Colour options : Black or Titanium
PPI : 2500€
