[A-400] Firmware 05-01-121220-24-POP-422 (Forum Release) (20.12.2012)
> > > D O W N L O A D < < <source
http://www.networkedmediatank.com/showt ... ?tid=64685pas de patch HD Audio délivré par Sigma apparemment (SDK)..
de DL et je test ..
Release date : 20 December 2012
Firmware version : 05-01-121220-24-POP-422-000
1. Known Issues (Will add others when public firmware gets released!)
- Some MKV/M2TS with DTSHD let AVR blink on heavy sound (we forwarded three samples to sigma, they confirmed the issue and are working on a solution now)
- some mkv with idx/sub freeze when first subtitle should show up
- External subtitle is shown inside the movie instead of black bar at the bottom
2. Firmware
- Fixed network streaming performance issue
- Fixed subtitle space too big between lines
- Fixed bmp becomes darker after video playback
- Fixed youtube playback blink when tvmode is 1080p24Hz
- Fixed bookmark not working for multiple ssif (3D frame packing) content
- Fixed DVD play as Actual-Size instead of Fit-to-Screen on default
- Fixed video show as Fit-to-Screen for 2 seconds then change to Actual-Size when start playing some video
- Fixed zooming video in Fit-to-Screen mode to 99% and the video will show as full screen
- Fixed Now-Playing-Playlist highlight wrong audio tracks when disable repeat-one setting using remote control
- Improved stability of 3D playback
- Improved playback performance
- Updated polish translation
3. System
- Fixed SD card cannot eject (unmount)
- Fixed submit query at keyboard and press done, search will hang issue
- Added Airplay and Airtunes
- Added HFS+ support
4. NMJ
- Fixed NMJ unable to show movie poster after scanning read-only samba share
- Fixed NMJ took around 4 mins to access photo just-scanned page for read-only shared folder
- Fixed NMJ show incorrect filename for some audio files
- Fixed NMJ sometimes use publisher/producer name as artist (Flac files are aggregated wrong now because mediainfo needs update, no issue with mp3)
- Fixed NMJ navigator SETUP button not working during video playback
- Fixed Update Database show wrong wording when update database in Nederland
- Fixed french language corrupted at help page
