Je m'intéresse pas à ce modèle pour moi je suis satisfait des mes tangent prestige
![:love: :love:](https://www.homecinema-fr.com/forum/images/smilies/love.gif)
Si vous avez pu écouter ce modèle merci par avance pour vos avis
![Image](http://d23rycayl5lni3.cloudfront.net/media/oart_0/oart_u/k2653/thumbs/7519_48783.jpg)
Pulse load capacity (IEC - Short Term) 350 Watt
Sensitivity (2.83 V / 1 m) 86 dB
Minimum amplifier output power recommended 100 Watt
Maximum acoustic pressure 104 dB/1m
Impedance 4 - 8 Ohm
Frequency range from/to 42 - 27000 Hz
Crossover frequency internal switch 350 / 2000 Hz
Tweeter (number) 1
Tweeter (diameter) 33.00 mm
Tweeter (material) Special fabric
Bass/Midrange driver (number) 1
Bass/Midrange driver (diameter) 100.00 mm
Bass/Midrange driver (material) Titanium full membrane
Woofer (number) 6
Woofer (diameter) 170.00 mm
Woofer (material) Carbon Rohacell sandwich cone
Miscellaneous Subwoofer: 2x aktiv-drivers, 4x passiv-drivers
Acoustic principle 3-way
Housing structure Variable passive membrane
Housing material 22 mm MDF
Housing surface High-gloss
Removable front cover Yes
Net internal volume 43 Litres
Integrated stand Yes
Miscellaneous 4 passive membranes, 1 front, 3 back
Terminal clamps Screw terminal with bass alignment function
Suitable for banana plug Yes
Maximum cable diameter 10.00 mm
Dimensions Depth 37.40 cm
Width 22.00 cm
Height 98.00 cm
Weight 31.20 kg
Miscellaneous Width base feet: 31 cm
