Voici une future télécommande "best have".
Site éditeur : http://procontrol.com/
http://www.remotecentral.com/news/505/pro_control_releases_oled_&_lcd_touchscreen_remotes.html
Le couple Pro24.z and ProLink.z a été récompensé en 2012 par le RESI et le CEPro.
Programmable 5-way joystick Yes
RF frequency Bidirectional Zigbee (2.4 GHz)
Compatible with Pro Control processor ProLink.z
Recharging cradle Yes
USB recharging cable Yes
USB programming Yes
Control via IR Yes
Full color touchscreen display TFT LCD
Battery type Lithium-Ion
Number of commands and macros allowed Unlimited*
Wizard-based programming Yes
Number of controlled devices Unlimited*
Customizable graphics via programming software Yes
Integrated tilt switch automatically turns on backlight Yes
Screen size (inches) 2.4
Screen resolution (pixels) 240×320
Number of programmable hard buttons 48
Dimensions H x W x D (inches) 9.79 x 2.23 x .9
Supported remote control Pro24.z or iPro.8
Support for iPad®, iPhone®, iPod touch® app Yes
Support for virtual PC control Yes
Support for 2-way feedback from compatible device Yes
Integrated RS232 ports 2
Ethernet control Yes
Ethernet for programming Yes
Adjustable IR output strength Yes
Integrated IR routing ports 6
Voltage sense inputs 2
Integrated RF control Bidirectional Zigbee (2.4 GHz)
System commands and macro storage Unlimited*
Integrated antenna Yes
USB programming Yes
Dimensions H x W x D (inches) 4.1 x 9.49 x 1.28
