Sur AVS Forum, Il y un nouveau disc "gratuit" à télécharger pour calibrer qui a été crée par visca blaugrana : GCD - Gamut Calibration Disk
le lien du topic sur AVS Forum
il existe plusieurs versions :
As I think most calibrations disk available today lack in-debt calibrations patterns for Gamut calibration, I decided to create one my self, the goal with this is not to create a disk for full calibration, as there is plenty of disks available for this, its only for gamut calibration.
b4.3.11 the latest beta version of the disk in AVCHD (This need burning to a DVD) format is avchd
b4.3.9 the latest beta version of the disk in AVCHD (This need burning to a DVD) format is avchd (If you have problems with this version try the b4.3.9 Strict AVCHD)
the latest test version with pop-up menus in Blu-Ray (This need burning to a BD) format is here b4.3.7 if you use this let me know and I will upload b4.3.8 in blu ray format
the latest test version with pop-up menus in AVCHD Strict (This need burning to a DVD) format is here b4.3.9 if this is required let me know and i will upload latest version
Just a quick guide to what format to chose:
Use the Blu-Ray version if you wish to burn to a Blu-Ray disk (BD25 or DB50) - use this format if your blu-ray player dont support 1080p/24fps via AVCHD (reports suggest that panasonic players dont)
Use the AVCHD in 9/10 instances
Use AVCHD Strict if you have problems using the normal AVCHD disk (if you have problems with the normal version please let me know)
this release include (All 10% windows & 1% Windows APL & 10% windows with fixed 22%APL & Fields)
100% luminance - Saturation Sweep
75% luminance - Saturation Sweep\t\t\t\t
50% luminance - Saturation Sweep\t\t\t\t
25% luminance - Saturation Sweep\t\t\t\t
\t\t\t\t
100% Saturation - luminance Sweep\t\t\t\t
75% Saturation - luminance Sweep\t\t\t\t
50% Saturation - luminance Sweep\t\t\t\t
25% Saturation - luminance Sweep
100% luminance - 100% Saturation: Primaries/Secondaries Sweep\t
100% luminance - 75% Saturation: Primaries/Secondaries Sweep\t
100% luminance - 50% Saturation: Primaries/Secondaries Sweep\t
75% luminance - 100% Saturation: Primaries/Secondaries Sweep\t
75% luminance - 75% Saturation: Primaries/Secondaries Sweep\t
75% luminance - 50% Saturation: Primaries/Secondaries Sweep\t
50% luminance - 100% Saturation: Primaries/Secondaries Sweep\t
50% luminance - 75% Saturation: Primaries/Secondaries Sweep\t
50% luminance - 50% Saturation: Primaries/Secondaries Sweep
Grey Scale Patterns 5 & 10% steps
Clip Pattern
Color Test Patterns
Reference pictures
