Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363580] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363589] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363597] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.363622] end_request: I/O error, dev sdc, sector 0
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.364983] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.364991] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.364999] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 28 00 00 08 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.365017] end_request: I/O error, dev sdc, sector 40
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366139] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366145] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366153] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 0f 33 00 00 00 08 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.366172] end_request: I/O error, dev sdc, sector 996096
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367547] sd 2:0:0:0: [sdc] Unhandled error code
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367555] sd 2:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367563] sd 2:0:0:0: [sdc] CDB: Read(10): 28 00 00 a4 3d 98 00 00 04 00
Jun 1 07:08:54 NASVIDEO1 kernel: [69770.367582] end_request: I/O error, dev sdc, sector 10763672
Je croyais qu'on pouvait masquer des mauvais secteurs. Je sens que ça va se terminer en SAV avec un RAID5 transformé en RAID0.
