Je viens de regarder le BR ci dessous.
Kaiser Chiefs: Live at Elland RoadCoté technique, voici le
MediaInfo du disque :- Code: Tout sélectionner
Disc Title: KAISER CHIEFS
Disc Size: 38 183 514 792 bytes
Protection: AACS
BD-Java: No
BDInfo: 0.5.8
Notes:
BDINFO HOME:
Cinema Squid
http://www.cinemasquid.com/blu-ray/tools/bdinfo
INCLUDES FORUMS REPORT FOR:
AVS Forum Blu-ray Audio and Video Specifications Thread
http://www.avsforum.com/avs-vb/showthread.php?t=1155731
PLAYLIST: 00000.MPLS
<--- BEGIN FORUMS PASTE --->
[code]
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
00000.MPLS AVC 1:24:34 28 059 303 936 38 183 514 792 44,24 28,97 LPCM 2.0 4608Kbps (96kHz/24-bit) DTS-HD Master 5.1 8407Kbps (96kHz/24-bit)
[/code]
[code]
DISC INFO:
Protection: AACS
BD-Java: No
BDInfo: 0.5.8
PLAYLIST REPORT:
Length: 1:24:34.502 (h:m:s.ms)
Size: 28 059 303 936 bytes
Total Bitrate: 44,24 Mbps
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 28971 kbps 1080i / 29,970 fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
LPCM Audio English 4608 kbps 2.0 / 96 kHz / 4608 kbps / 24-bit
DTS-HD Master Audio English 8407 kbps 5.1 / 96 kHz / 8407 kbps / 24-bit (DTS Core: 6.1 / 48 kHz / 1509 kbps / 24-bit)
FILES:
Name Time In Length Size Total Bitrate
00000.M2TS 0:00:00.000 1:24:34.002 28 059 279 360 44 240
00004.M2TS 1:24:34.002 0:00:00.500 24 576 393
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:01:41.835 24 202 kbps 37 665 kbps 00:01:16.509 35 867 kbps 00:01:11.838 33 322 kbps 00:01:09.469 100 911 bytes 342 876 bytes 00:01:09.502
2 0:01:41.835 0:02:43.930 29 510 kbps 31 856 kbps 00:04:06.779 30 600 kbps 00:03:28.041 30 225 kbps 00:03:01.214 123 079 bytes 230 924 bytes 00:04:06.813
3 0:04:25.765 0:04:27.967 29 513 kbps 31 347 kbps 00:08:36.682 30 657 kbps 00:05:02.835 30 464 kbps 00:05:02.935 123 095 bytes 186 949 bytes 00:08:48.761
4 0:08:53.733 0:03:46.859 29 370 kbps 31 382 kbps 00:11:56.749 30 480 kbps 00:09:53.492 30 237 kbps 00:11:56.749 122 498 bytes 215 564 bytes 00:11:57.349
5 0:12:40.593 0:04:35.842 29 421 kbps 31 311 kbps 00:16:19.211 30 513 kbps 00:13:56.569 30 153 kbps 00:15:02.935 122 711 bytes 231 857 bytes 00:17:12.631
6 0:17:16.435 0:02:54.974 29 422 kbps 31 255 kbps 00:18:42.654 30 517 kbps 00:18:47.259 30 170 kbps 00:18:14.693 122 713 bytes 212 185 bytes 00:20:09.808
7 0:20:11.410 0:03:49.062 29 391 kbps 31 899 kbps 00:20:14.413 30 647 kbps 00:20:12.077 30 263 kbps 00:22:28.847 122 583 bytes 240 074 bytes 00:20:13.812
8 0:24:00.472 0:03:29.943 29 369 kbps 31 609 kbps 00:27:16.134 30 518 kbps 00:25:25.223 30 035 kbps 00:24:00.739 122 494 bytes 214 131 bytes 00:27:04.356
9 0:27:30.415 0:04:11.217 29 396 kbps 31 625 kbps 00:30:56.020 30 647 kbps 00:30:51.916 30 426 kbps 00:28:53.064 122 604 bytes 250 684 bytes 00:27:33.618
10 0:31:41.633 0:03:10.657 29 355 kbps 31 563 kbps 00:34:28.032 30 566 kbps 00:31:48.539 30 252 kbps 00:31:43.968 122 433 bytes 207 964 bytes 00:34:20.825
11 0:34:52.290 0:04:36.776 29 243 kbps 31 977 kbps 00:37:56.941 30 705 kbps 00:37:56.140 30 456 kbps 00:35:25.022 121 970 bytes 260 811 bytes 00:37:56.240
12 0:39:29.066 0:04:23.496 29 454 kbps 32 453 kbps 00:39:38.876 30 634 kbps 00:40:00.664 30 383 kbps 00:40:02.266 122 846 bytes 334 974 bytes 00:39:37.375
13 0:43:52.563 0:03:53.633 29 029 kbps 31 987 kbps 00:44:12.282 30 521 kbps 00:44:08.712 29 975 kbps 00:45:27.057 121 077 bytes 247 813 bytes 00:44:12.383
14 0:47:46.196 0:10:49.215 29 337 kbps 31 751 kbps 00:50:00.897 30 598 kbps 00:49:45.782 30 367 kbps 00:48:10.654 122 362 bytes 247 219 bytes 00:50:01.732
15 0:58:35.411 0:06:51.677 29 356 kbps 32 081 kbps 00:59:43.913 30 847 kbps 01:04:38.674 30 513 kbps 01:04:37.073 122 439 bytes 303 795 bytes 01:04:43.412
16 1:05:27.089 0:02:53.907 28 944 kbps 34 626 kbps 01:06:44.100 31 032 kbps 01:06:35.858 30 495 kbps 01:06:35.091 120 722 bytes 375 575 bytes 01:06:13.202
17 1:08:20.996 0:04:09.782 28 792 kbps 33 372 kbps 01:09:40.843 30 369 kbps 01:10:59.455 30 038 kbps 01:10:54.416 120 085 bytes 374 359 bytes 01:09:42.611
18 1:12:30.779 0:03:26.973 28 847 kbps 31 901 kbps 01:13:05.981 30 445 kbps 01:13:47.589 30 087 kbps 01:15:03.966 120 317 bytes 363 985 bytes 01:15:55.350
19 1:15:57.753 0:07:57.944 28 882 kbps 35 558 kbps 01:16:19.708 32 255 kbps 01:16:18.674 30 691 kbps 01:16:13.669 120 462 bytes 433 524 bytes 01:16:21.877
20 1:23:55.697 0:00:38.805 5 932 kbps 12 895 kbps 01:24:05.273 11 791 kbps 01:24:04.472 11 682 kbps 01:24:05.106 24 763 bytes 100 352 bytes 01:24:06.908
STREAM DIAGNOSTICS:
File PID Type Codec Language Seconds Bitrate Bytes Packets
00000.M2TS 4113 (0x1011) 0x1B AVC 5073,936 28 975 18 376 932 116 99 964 303
00000.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 5073,936 4 614 2 926 293 860 16 234 640
00000.M2TS 4353 (0x1101) 0x86 DTS-HD MA eng (English) 5073,936 8 408 5 332 700 936 29 773 149
00004.M2TS 4113 (0x1011) 0x1B AVC 0,400 283 14 159 84
[/code]
<---- END FORUMS PASTE ---->
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00000.MPLS
Length: 1:24:34.502
Video: MPEG-4 AVC Video / 28971 kbps / 1080i / 29,970 fps / 16:9 / High Profile 4.1
Audio: English / LPCM Audio / 2.0 / 96 kHz / 4608 kbps / 24-bit
Audio: English / DTS-HD Master Audio / 5.1 / 96 kHz / 8407 kbps / 24-bit (DTS Core: 6.1 / 48 kHz / 1509 kbps / 24-bit)
PLAYLIST: 00001.MPLS
[code]
Total Video
00001.MPLS AVC 0:26:36 8 780 507 136 38 183 514 792 43,99 28,86 LPCM 2.0 4608Kbps (96kHz/24-bit) DTS-HD Master 5.1 8247Kbps (96kHz/24-bit)
[/code]
[code]
DISC INFO:
Protection: AACS
BD-Java: No
BDInfo: 0.5.8
PLAYLIST REPORT:
Length: 0:26:36.995 (h:m:s.ms)
Size: 8 780 507 136 bytes
Total Bitrate: 43,99 Mbps
VIDEO:
MPEG-4 AVC Video 28865 kbps 1080i / 29,970 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio English 8247 kbps 5.1 / 96 kHz / 8247 kbps / 24-bit (DTS Core: 6.1 / 48 kHz / 1509 kbps / 24-bit)
FILES:
00001.M2TS 0:00:00.000 0:26:36.494 8 780 482 560 43 999
00004.M2TS 0:26:36.494 0:00:00.500 24 576 393
CHAPTERS:
1 0:00:00.000 0:00:41.708 27 239 kbps 45 035 kbps 00:00:03.036 31 053 kbps 00:00:23.189 30 318 kbps 00:00:23.156 113 520 bytes 352 221 bytes 00:00:03.370
2 0:00:41.708 0:04:32.138 28 895 kbps 49 320 kbps 00:03:46.526 32 422 kbps 00:04:17.223 31 337 kbps 00:04:17.123 120 517 bytes 526 470 bytes 00:03:46.593
3 0:05:13.846 0:03:58.838 28 975 kbps 41 763 kbps 00:05:56.989 31 939 kbps 00:06:28.121 30 661 kbps 00:06:28.054 120 850 bytes 311 138 bytes 00:07:05.258
4 0:09:12.685 0:04:29.669 28 501 kbps 42 453 kbps 00:09:24.897 32 449 kbps 00:09:25.564 30 753 kbps 00:09:25.531 118 875 bytes 413 317 bytes 00:11:49.475
5 0:13:42.354 0:06:25.385 29 174 kbps 46 228 kbps 00:15:11.577 33 777 kbps 00:17:32.217 31 763 kbps 00:17:32.618 121 678 bytes 371 776 bytes 00:19:15.754
6 0:20:07.739 0:03:52.498 28 913 kbps 48 013 kbps 00:21:40.999 32 745 kbps 00:22:39.891 31 242 kbps 00:22:30.682 120 593 bytes 385 964 bytes 00:23:47.125
7 0:24:00.238 0:02:36.756 28 868 kbps 36 523 kbps 00:24:35.874 31 908 kbps 00:25:21.052 30 783 kbps 00:25:14.379 120 431 bytes 272 899 bytes 00:25:09.808
STREAM DIAGNOSTICS:
00001.M2TS 4113 (0x1011) 0x1B AVC 1596,395 28 875 5 762 063 822 31 367 791
00001.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 1596,395 4 619 921 743 704 5 113 696
00001.M2TS 4353 (0x1101) 0x86 DTS-HD MA eng (English) 1596,395 8 250 1 646 275 328 9 196 632
[/code]
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00001.MPLS
Length: 0:26:36.995
Video: MPEG-4 AVC Video / 28865 kbps / 1080i / 29,970 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1 / 96 kHz / 8247 kbps / 24-bit (DTS Core: 6.1 / 48 kHz / 1509 kbps / 24-bit)
PLAYLIST: 00002.MPLS
[code]
Total Video
00002.MPLS AVC 0:00:29 32 919 552 38 183 514 792 8,91 8,28 DD AC3 5.1 448Kbps
[/code]
[code]
DISC INFO:
Protection: AACS
BD-Java: No
BDInfo: 0.5.8
PLAYLIST REPORT:
Length: 0:00:29.562 (h:m:s.ms)
Size: 32 919 552 bytes
Total Bitrate: 8,91 Mbps
VIDEO:
MPEG-4 AVC Video 8283 kbps 1080i / 29,970 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio English 448 kbps 5.1 / 48 kHz / 448 kbps
FILES:
00012.M2TS 0:00:00.000 0:00:07.006 3 766 272 4 300
00005.M2TS 0:00:07.006 0:00:06.005 1 290 240 1 719
00006.M2TS 0:00:13.012 0:00:11.044 26 118 144 18 919
00007.M2TS 0:00:24.057 0:00:05.004 1 720 320 2 750
00004.M2TS 0:00:29.062 0:00:00.500 24 576 393
CHAPTERS:
1 0:00:00.000 0:00:29.562 8 283 kbps 29 234 kbps 00:00:18.418 24 785 kbps 00:00:14.347 19 393 kbps 00:00:13.813 34 548 bytes 358 200 bytes 00:00:15.115
STREAM DIAGNOSTICS:
00012.M2TS 4113 (0x1011) 0x1B AVC 6,874 4 120 3 540 213 19 373
00005.M2TS 4113 (0x1011) 0x1B AVC 5,906 1 589 1 172 775 6 500
00006.M2TS 4113 (0x1011) 0x1B AVC 10,978 17 697 24 284 174 132 170
00006.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 10,978 452 620 032 3 460
00007.M2TS 4113 (0x1011) 0x1B AVC 4,905 2 606 1 597 984 8 774
[/code]
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00002.MPLS
Length: 0:00:29.562
Video: MPEG-4 AVC Video / 8283 kbps / 1080i / 29,970 fps / 16:9 / High Profile 4.1
Audio: English / Dolby Digital Audio / 5.1 / 48 kHz / 448 kbps
PLAYLIST: 00003.MPLS
[code]
Total Video
00003.MPLS MPEG-2 0:03:05 682 911 744 38 183 514 792 29,53 25,87 LPCM 2.0 2304Kbps (48kHz/24-bit)
[/code]
[code]
DISC INFO:
Protection: AACS
BD-Java: No
BDInfo: 0.5.8
PLAYLIST REPORT:
Length: 0:03:05.018 (h:m:s.ms)
Size: 682 911 744 bytes
Total Bitrate: 29,53 Mbps
VIDEO:
MPEG-2 Video 25874 kbps 1080i / 29,970 fps / 16:9
AUDIO:
LPCM Audio English 2304 kbps 2.0 / 48 kHz / 2304 kbps / 24-bit
FILES:
00008.M2TS 0:00:00.000 0:03:04.517 682 856 448 29 606
00009.M2TS 0:03:04.517 0:00:00.500 55 296 884
CHAPTERS:
1 0:00:00.000 0:03:05.018 25 874 kbps 37 828 kbps 00:02:11.898 35 137 kbps 00:02:39.492 34 490 kbps 00:01:40.099 107 917 bytes 419 536 bytes 00:02:12.031
STREAM DIAGNOSTICS:
00008.M2TS 4113 (0x1011) 0x02 MPEG-2 184,418 25 956 598 349 898 3 255 118
00008.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 184,418 2 312 53 289 376 295 232
00009.M2TS 4113 (0x1011) 0x02 MPEG-2 0,400 963 48 183 266
[/code]
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00003.MPLS
Length: 0:03:05.018
Video: MPEG-2 Video / 25874 kbps / 1080i / 29,970 fps / 16:9
Audio: English / LPCM Audio / 2.0 / 48 kHz / 2304 kbps / 24-bit
PLAYLIST: 00005.MPLS
[code]
Total Video
00005.MPLS AVC 0:02:14 607 488 000 38 183 514 792 36,17 31,05 LPCM 2.0 1536Kbps (48kHz/16-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
[/code]
[code]
DISC INFO:
Protection: AACS
BD-Java: No
BDInfo: 0.5.8
PLAYLIST REPORT:
Length: 0:02:14.367 (h:m:s.ms)
Size: 607 488 000 bytes
Total Bitrate: 36,17 Mbps
VIDEO:
MPEG-4 AVC Video 31054 kbps 1080i / 29,970 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio English 1536 kbps 2.0 / 48 kHz / 1536 kbps / 16-bit
FILES:
00010.M2TS 0:00:00.000 0:02:14.367 607 488 000 36 169
CHAPTERS:
1 0:00:00.000 0:02:14.367 31 054 kbps 44 870 kbps 00:00:20.086 36 074 kbps 00:01:04.330 35 242 kbps 00:01:04.297 129 521 bytes 502 294 bytes 00:00:20.520
STREAM DIAGNOSTICS:
00010.M2TS 4113 (0x1011) 0x1B AVC 134,267 31 077 521 579 587 2 837 065
00010.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 134,267 1 543 25 899 788 161 202
00010.M2TS 4353 (0x1101) 0x80 LPCM eng (English) 134,267 1 543 25 899 788 161 202
[/code]
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00005.MPLS
Length: 0:02:14.367
Video: MPEG-4 AVC Video / 31054 kbps / 1080i / 29,970 fps / 16:9 / High Profile 4.1
Audio: English / LPCM Audio / 2.0 / 48 kHz / 1536 kbps / 16-bit
Voici mon avis :
Le concert :Je ne connaissait le groupe que de nom. On m'a prête ce BR et je me suis dit qu'avant de le rendre je devrai peut être le regarder.
Ce concert à été filmé dans le stade de Leeds (les amateurs de foot le reconnaîtront peut être).
J'ai passé un bon moment et finalement je connaissait 3 chansons.
Niveau "spectacle" c'est pas terrible. OK me direz vous, si je voulais voir un show j'aurai du regarder Kylie Minogue. Mais j'estime qu'il devrait tout de même y avoir un "minimum syndical".
C'est bien la 1ère fois que je vois un guitariste (surtout d'un groupe de rock) inerte ; à croire qu'il attendait les démineurs.
Heureusement que le chanteur (en costard) est une pile électrique à mi chemin entre Axl Rose et Claude François
L'image :Je préfère ne pas donner de note car je suis malvoyant (elle ne serait donc pas objective).
Aie aie aie, qu'est ce que ça bouge
L'image est d'un bon niveau mais on a pas trop le temps de l'étudier.
La seule solution pour scruter l'image et de faire une pause.
Avez vous vu le film 127 Heures ? Et bien ce concert à été monté de la même manière.
Personnellement j'aime beaucoup, mais je sais que c'est loin d'être le cas de tout le monde.
Le son :Un sans faute pour la piste DTS HD
Ça aurait peut être mérité une plus grande sollicitation des surround (mais c'est une histoire de goûts)
Le détail qui tue :Ya encore des artistes qui utilisent des câbles.
Chapeau au chanteur qui n'a cessé de bouger dans tous les sens et qui a réussi à ne pas se prendre les pieds dans le fil de son micro.
Au générique de fin... Oups, j'en ai trop dit
OH SURPRISE (enfin, si comme moi vous avez tendance à cliquer sur OK sans lire le menu après avoir insérer le BR
Si on est patient et que l'on attends la fin du générique, ça enchaîne tout de suite sur... un 2ème concert
On passe alors du stade de Leeds à une salle plus intimiste (genre BBC Sessions).
Le groupe est accompané par l'orchestre de David Arnold
Côté image, il faut être clair, je ne suis pas sur qu'ils pensaient à mettre ça sur un BR.
C'est joli, mais le côté sombre et peu éclairé de la salle allié à l'ambiance "fumoir" n'aide pas.
Mais la n'est pas vraiment l'intérêt.
Modern Way :C'est très bon au début mais des que le rifts de guitare et la batterie entent en action l'orchestre est comme "asphyxié". Seules les trompettes arrivent à se faire entendre.
Jet (de Paul McCartney & The Wings)Le résultat est déjà plus probant.
Il y a une sorte d'harmonie (voir même de symbiose) entre le groupe et l'orchestre ou aucun instrument n'est mis de côté.
RubyDu grand art en acoustique.
Un régal pour les oreilles
The angry mobLa point d'orchestre, au début de la chanson tout du moins.
Mais dès le refrain, le groupe est rejoint par une troupe de percussionniste et encore une fois le résultat est excellent.
Oh, my GodUn final surprenant
