I am assuming the arse-string joke though originated due to a real failure of the glue between the hard and soft plastics on the rear strap? If so, that is a bit alarming that it failed so quickly and I hope is not a sign of things to come for others? It problem stems down to the stress when you take it on and off your head. You should always loosen the straps using the two push buttons on either side of the headset when you want to take the headset off.
Problème de fiabilité du collage des straps sur le HMZ ?
Le conseil de relâcher la pression avec les boutons poussoirs avant d'enlever le casque ne me semble pas très pratique (obligé de les re-régler à chaque fois ?)
![:o](https://www.homecinema-fr.com/forum/images/smilies/icon_eek.gif)
