Androphis45 a écrit:realzven a écrit:bon la 1ère page est mise à jour avec les CR d'Igor et d'antislash, en attendant les autres
Belle première page, je n'y étais pas passé depuis un moment.
Merci à toi !
![:oops:](https://www.homecinema-fr.com/forum/images/smilies/icon_redface.gif)
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 72 invités
Merci à toi !
I just installed my BDP-53FD. The BDP-53FD adds two HDMI outputs for separate video and audio with Pure Audio mode, Marvell video processing which eliminates 480i mode, DTS downmix, an extra blue light, and a heavier base. SACD can be output as DSD bitstream or PCM at 88.2 KHz. You need to aim the remote precisely in order for it to work correctly. The disc mechanism might be a little quieter than the BDP-52FD. In case you're wondering, I am keeping the BDP-53FD because of the MediaTek MT8555, Pioneer's PQLS, and the Marvell video processing. Who knows what might get added as new firmware updates are released. Even if nothing gets added, I'm happy with the combination of the MT8555, PQLS, and Marvell.
Just got my 53FD tonight. Everything seems to be fine except the network connection. It can acquire the IP address via DHCP but the intetnet connection test failed. I can ping the unit with anoter computer that is on the same subnet. But the unit cannot goto the internet. I have checked the information page. It seems the IP address/getway/DNS server are all fine. More over the unit will hang after a while. It will not respond to any command on the remote. Pressing the keys on the front panel does not work either. I have to power cycle the unit by unplugging it.
If I do not plug it into the network, everything seems to be fine. Play out bluray/CD/SACD are all working fine.
I am very frustrated. Anybody have tested the 53FD network functionality?
I have checked there is no firmware update yet..
mOULf2 a écrit:Même problème de déformation sur le 440. Ca fait partie des petits défaut chiants dont j'espère qu'ils seront corrigés par une maj.
J'ai l'impression que le lecteur essaye de faire du full screen même quand le ratio n'est pas 16:9.
Pour la touche cd/sacd elle ne fonctionne qu'a l'arrêt. Perso j'ai du appuyer deux fois sur Stop lors de la lecture d'un SACD pour modifier CD/SACD 2Ch/MultiChannel.
Quand on insère un SACD hybrid : on appuye sur stop. Après on appuye sur le bouton CD/SACD et on peut selectionner "CD AREA", "2CH" et "MULTICHANNEL".
Genki a écrit:Merci pour ces photos antislash,
Petite question : y-a-t-il un réglage de gamma ?
Retourner vers Lecteurs Blu-Ray
