aujourd’hui , j'ai envoyé un mail au fabriquant du w4s ...... , je voulais avoir surtout des renseignements sur l'entrée i2s , sur les players qui fonctionne bien avec le w4s , ... etc etc j'ai eu une réponse dans les 2 heures ....très réactif
![:o](https://www.homecinema-fr.com/forum/images/smilies/icon_eek.gif)
....bravo !!
Hello Fred,
My name is Clint and I am assisting EJ as much as possible. It is great to hear that your getting ready for a DAC-2. The i2s input has not changed and it can be made compatible with select CD players if we can modify them. The DACs do have plug in digital and USB boards which will allow for replacements to be installed if we have one. The media player will depend on which OS you are using and for MAC you should consider Fidela(audiophile engineering), Audirvana, or Pure Music. If you have a PC system you should strongly consider J River media center.
Best Regards,
Clint
