Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 28 invités
Tweaks modules tripath hifimediy tk2050
Message » 19 Déc 2010 13:10
J'ai ajouté les liens dans le 1er post ;)
ptiJean
Inscription Forum: 13 Juin 2003 10:46
Message » 19 Déc 2010 18:11
J'aime bien les photos de condo avec leurs couleurs métalisées : ça fait un peu boules de Noël, c'est donc parfaitement de saison vos petits tweaks. :mdr:
robob
Inscription Forum: 21 Mar 2007 19:23
Message » 20 Déc 2010 13:43
Merci AlexScan. Avec tout ces comparos, on va avoir des t2 aux ptits oignons :P
TiTiX77
Inscription Forum: 19 Jan 2010 16:00
Message » 26 Déc 2010 13:34
Prochain condo à l'essai dès que j'aurai reçu mon nouveau module DAC :
Amp Ohm FP-CA-AU 630VDC - 5% tolerance
Technical Specifications (according to manufacturer): "Amp Ohm Audio Capacitors are specially designed for high performance audio systems. The capacitors are hand wound and have their insulated copper leads hand soldered before being assembled in a plastic case and resin sealed. The resin filled end identifies the outer winding. This construction results in the capacitors having low ESR and low inductance and possessing high stability with respect to both temperature and frequency. They are ideal for use in loudspeaker crossover networks and valve amplifiers where pure sound is at a premium. Line on label denotes outer foil".
Sound: The Amp Ohm FP-CA-AU is a very neutral sounding capacitor that takes a nice smooth and calm approach to the reproduction of music. I found the balance of the midrange very pleasing letting acoustic instruments keep their natural warm tone. Absolute detail and air isn't quite up to the level of an Audyn Cap Plus or Mundorf Supreme but it comes very close although they do need some time to open up so don't judge them fresh out of the box. Spatiality is broad with reasonable depth but if you want "bowling alley" depth go for (the much more expensive) Mundorf Silver/Oil. Compared to the more luxurious Amp Ohm capacitors they are more 2D and a little rough, but again those cost far more.
Verdict: 8,5
AlexScan
Inscription Forum: 27 Déc 2005 20:57
Message » 26 Déc 2010 19:04
AlexScan a écrit:Prochain condo à l'essai dès que j'aurai reçu mon nouveau module DAC :
ils sont en soldes chez audiophonics :D
http://www.audiophonics.fr/condensateur ... -4503.html
alkasar
Inscription Forum: 29 Nov 2005 22:47
Message » 26 Déc 2010 19:25
Je sais !!!
AlexScan
Message » 26 Déc 2010 19:50
:wink:
alkasar
Message » 27 Déc 2010 11:03
Une petite photo pour illustrer le T2 avec les K75-10 déportés, j'ai également ajouté un des EPCOS d'origine (en bas à droite) :
ptiJean
Message » 27 Déc 2010 12:13
Oh my god ... ils sont vraiment énorme !!!
Sinon ton boitier il est TOP , tu l'a trouvé ou ? :P
AlexScan
Message » 27 Déc 2010 12:15
Les K75-10 : énormes oui !
Le boitier ? :mdr:
Une boîte à sucres vide, trouvée à Carrefour à 4 € ! :lol:
Super pratique pour les montages temporaires, ça se perce facilement (quasiment avec le tournevis seul sans perceuse), et ça tient tout en place !
ptiJean
Message » 27 Déc 2010 14:28
ah, Marylin est de sortie :D
Pour le prochain, tu regarderas au rayon boites à cigares :mdr:
alkasar
Message » 27 Déc 2010 14:30
:mdr:
Achtung aux boîtes en bois : j'oserai jamais.
J'ai pas envie de faire brûler mon salon !
ptiJean
Message » 27 Déc 2010 15:45
ptiJean a écrit::mdr:
t'es pas joueur :mdr:
alkasar
Message » 27 Déc 2010 16:07
Mais si un boitier en bois ça le fait je me suis déjà fait un PCHC dans un boitier en bois ça n'a jamais brûlé ni même chauffé ...
AlexScan
Message » 27 Déc 2010 16:17
Moi je préfère le mix bois plexi :mdr: .
robob
