Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alfachris, nouar, Robson5 et 5 invités
Préampli passif Audio Synthesis Passion
Message » 12 Déc 2010 18:34
Type : Pré ampli passif
Marque : AUDIOSYNTHESIS
Modèle et options : Passion
Prix de vente : 370 €
Département où la marchandise est visible : 67
Montant des frais d'expédition : Offerts (France metro
Première main : 2ème main, acheté à un particulier en Octobre 2009
Prix neuf : 1600 €
Facture disponible : non
Date et lieu d'achat : Octobre 2009
Année de fabrication: 1996
Numéro de série : sur demande
3 stereo line inputs, tape output, main listen out and mute facility
- Tape output may be used as a Direct In, by-passing all input switching
- Stereo, 31-step, all Vishay attenuator, 1.5dB & low level 6dB steps
- Less than 0.05dB error in Left to Right tracking and individual step accuracy
- Absolute simplicity - a classic 'L' pad only 2 Vishay Bulk Foil resistors are ever in the signal path at any one time
- Signal and ground of all inputs are switched for total source isolation
- Coin silver self-wiping switch contacts
- WBT connectors, Teflon insulated, 24 carat gold plating & isolation
- Pure silver (>99.99%) & Teflon used for all internal wiring
- Fully comprehensive 2 year guarantee on components & workmanship
- Size (w x h x d): 110mm x 65mm x 130mm
- Weight including packaging: 1.9kg
Compatibility - Sources
Two specifications of the source are relevant when using a passive controller.
One is the output impedance of the source which should be low, ideally 600ohms or less.
The second is the output voltage from the source since this (together with the power amplifier and speaker sensitivity) will determine how much volume is available in the room. The higher the output voltage the better, we recommend greater than 1V rms. The 3.5V output from the DAX series is perfect for use with PASSION.
Compatibility - Cables
Due to their minimal design nearly all passive preamps exhibit an output impedance which both changes with level and is sometimes higher than a conventional active preamp's. Consequently the cable used between the passive controller and power amplifier should have a low capacitance (the shorter the cable the better) and be screened. We highly recommend SilverBlue (120pF/m terminated in WBT plugs) and SilverBlue Locap (80pF/m).
Compatibility - Power Amplifiers
When used with a passive preamp a little more gain may be needed in the power amplifier, we recommend 30dB or more. An alternative way of specifying this is as the power amplifier's sensitivity for full output, a figure of 1V for maximum output is ideal.
The amplifier's input impedance is also relevant due to its loading effect upon PASSION's output impedance and hence the source's load driving capability. A minimum input impedance of 20kohms is a good guide.
The Audio Synthesis power amplifier, DESIRE, with an input sensitivity of 0.5V and impedance of 440kohms is a perfect match!
Site web du constructeur :
http://www.audiosynthesis.co.uk/passion.htm
http://www.soundstage.com/tm_01.htm
http://www.hifiwigwam.com/view_topic.ph ... forum_id=5
KR man
Inscription Forum: 11 Fév 2010 20:09
Message » 16 Déc 2010 11:09
Up
Une petite revue pour ceux qui ne connaissent pas ce produit:
http://www.soundstage.com/tm_01.htm#full_review
KR man
Message » 20 Déc 2010 16:36
Up
KR man
Message » 21 Déc 2010 11:16
Ca doit marcher rudement bien avec le bloc de puissance de la marque, en vente ici :
http://www.homecinema-fr.com/forum/viewtopic.php?f=1045&t=29955498
PC 100% linéaire (alim320VA), switch MELCO S100 (alim FARAD Super3) > rj45 VOVOX Textura > AURALIC Vega G2.1 >xlr> SUGDEN SPA4 > WILSON BENESCH Vertex
[HP, XLR, AES/EBU, Secteur : MPC Présence Evo, Absolute ou MRC]
Sithodea
Inscription Forum: 14 Déc 2006 15:32
Message » 21 Déc 2010 18:41
Je suis eventuellement interéssé par votre preampli mais je voudrais le tester pour voir s'il peut rentrer dans mon système .
Deuxiemement le prix peut il se négocier .
J'ai déja un passif mais si celui ci est mieux :wink:
Si nous trouvons un accord je vous envois le chèque , je l'essaye si c'est bon je garde le preampli et vous encaissez le chèque .
Si l'essai n'est pas concluent je vous renvois le preampli et vous me renvoyez le chèque.
Cordialement
Alain
amagyar
Inscription Forum: 07 Jan 2005 14:56
Message » 01 Jan 2011 1:41
Réservé. En attente chèque
KR man
(VENDU) Audio Synthesis Passion
Message » 12 Jan 2011 18:08
C'est vendu, on peut fermer :D
KR man
