Merci Kevlar,
tu m'aides très bien !
le temps que la Tnt hd soit dans le coin, si les grandes chaines sont bien diffusées en Sd, c'est parfait. nt1 et direct 8 aussi (me semble) c'est vrai que déjà c'est bof, et avec certaines diffusions, même si elles m'intéressent, je regarde pas tellement ça pique.
j'ai trouvé ça, dans un test donné en page 1, sur avforum (c'est pas des aveugles, il me semble
Video Processing
One of my biggest criticisms of last year's Panasonic displays (except for the extremely expensive Z1, that is!) was the lacklustre quality of the TV's scaling when the TV was fed with a 480i or 576i source. In other words, when the TV was fed a standard definition signal, the on-screen picture was somewhat blurry, because the TV wasn't preserving all of the high frequency content in the signal. This is now a thing of the past, as the scaling on the G20 is fantastic. The smallest details of SD sources are preserved and are presented on-screen without blurring or ringing. The resulting clarity is very close indeed to products using the high-end HQV scaling chip (seen in some AV receivers and premium Blu-ray Disc players).
Scaling (the actual "resizing") of SD signals is just one part of making them watchable on HD flat panel displays, however. I also tested the Panasonic TX-P42G20's diagonal interpolation and film mode detection capabilities. First, diagonal interpolation, in other words, how well the TV suppresses jaggedness in standard def material. The TX-P42G20 did a good job, consistent with other displays in this price range (and above). For those of you familiar with the "three rotating bars" test pattern on the HQV test disc, the top two moving bars were smooth except for some jaggedness at their edges, and the bottom line was fairly smooth, indicating good performance.
Traitement vidéo
Un de mes plus grands critiques d'écrans Panasonic l'an dernier (sauf pour le Z1 extrêmement coûteux, ce qui est!) A été la qualité médiocre de l'extension du téléviseur lorsque le téléviseur a été alimenté avec une source 480i ou 576i. En d'autres termes, lorsque le téléviseur est alimenté par un signal en définition standard, l'image sur l'écran était un peu floue, car la télévision n'est pas la préservation de l'ensemble du contenu à haute fréquence dans le signal. Ceci est maintenant chose du passé, que l'échelle sur le G20 est fantastique. . Les moindres détails de sources SD sont conservés et sont présentées à l'écran sans effet de flou ou de bourdonnements.. La clarté qui en résulte est très proche en effet de produits utilisant la puce mise à l'échelle haut de gamme HQV (vu dans certains récepteurs AV et de la prime lecteurs Blu-ray Disc).
Mise à l'échelle (l'actuel "redimensionnement") des signaux SD n'est qu'une partie d'entre eux faisant regardable sur les écrans HD à écran plat, cependant.. J'ai aussi testé interpolation diagonale du Panasonic TX-P42G20 et les capacités de film en mode de détection. Tout d'abord, l'interpolation diagonale, en d'autres termes, comment la télévision supprime jaggedness en matière définition standard. Le TX-P42G20 fait un bon travail, compatible avec d'autres écrans de cette gamme de prix (et ci-dessus). Pour ceux d'entre vous familiariser avec le motif "trois barres tournantes" test sur le disque de test HQV, les deux premières barres animées étaient lisses, sauf pour certains jaggedness à leurs bords, et la ligne du bas est assez lisse, ce qui indique une bonne performance.
Donc, à moins que google traduction ne se plante, le g20 fait au mieux aussi sur les sources sd. Même s'il est en dessous de mon px81 (je ne dis pas que c'est le cas, je suppose juste vu le traitement qu'il doit appliquer), il s'en tirera assez bien et si en plus ça ne te choques pas non plus, bah les (peu) puristes que moi et ma famille sommes ne serons pas non plus choqués. C'est ballot de pas pouvoir le vérifier de visu avant l'achat. Je tenterais quand même de leur faire brancher le plasma en tnt. mais pas gagné.
SInon, pour abordé les défauts de ce G20. Déjà, je crois ne pas être sensible au ghost (noirs flottants, c'est ça ? ) En tout cas, sur Sin City, je n'ai jamais rien vu. Sans cherché, il est vrai. J'ai juste visionné et pris mon pied, quoi.
Donc sur celui-ci ce sera pareil. En plus, impossible pour moi de visionner sans lumière. c'est désagréable pour moi. Doinc doublement tranquille.
Reste quoi ? La sensibilité. ça ne devrait pas être plus mauvais que mon Pana, et depuis mon installation ça va, donc si cela était encore problématique, j'échangerais pour une autre marque, et tant pis !
La bande verte. Bah ce n'est pas un défaut, mais une panne. je croise les doigts. Et puis extension 5 ans de garantie, de toute façon...
L'alimentation et son Buzz, ça c'est enquiquinant.
j'espère que l'onduleur In -Line sur lequel il sera branché supportera le plasma (1000va, ça devrait aller) et que s'il s'agit vraiment d'un problème de courant "propre", ça règlera la question.
Que reste -il dans les tiroirs, comme soucis avec ces panasonic 2010 ?
