Pour poster une image , il faut faire " copier l ' adresse de son lien " :
ex :http://www.pocket-lint.com/images/42KY/philips-3d-cinema-219-platinum-3.jpg?20100907-205310
http://www.pocket-lint.com/images/42KY/ ... 907-205310
On voit sur ces images : en haut le nouveau 58 pouces , en dessous le vieux 56 pouces .
Rien que la contraste , c ' est flagrant !!!!!
When it comes to 3D we watched a couple of clips from demo tapes and movies including the fireworks clip from G-Force - you might laugh when we say this, but because of the thin bezel and the lack of black bars, the images really do leap out of the television, while all the time offering you a crystal clear image that will be hard to beat.
That crystal clear image is possible in 3D because of the lack of crosstalk (described by Wikipedia: "In Stereoscopic 3D Displays, crosstalk refers to the incomplete isolation of the left and right image channels so that one leaks or bleeds into the other - like a double exposure") - basically Philips has done everything it can to combat this, something that has plagued some existing 3DTVs.
A new thinner bezel means the you now get more screen too. The two televisions pictured above might be the same size in physical dimensions if you include the frame, but the new model manages to squeeze in another 2-inches of screen into the mix, meaning you get a 58-inch screen rather than a 56-inch one.
It might only be 2 inches, but any man or women will tell you that really can make the difference between something that's, well okay, and something that's mind blowing. We wouldn't go as far as saying the extra 2 inches on the Philips model is mind blowing, but it's certainly welcomed.
What is mind blowing however is the improvement in colour and the improvement in black handling thanks to a number of new proprietary technologies from Philips whether you are watching 2D or 3D images. That means stealing tech from the company's current 9000 series including Direct lit LED, 400Hz and Perfect Pixel HD Engine picture processing, while LED Pro operates over 1500 LEDs as a backlight for the display.
Que du bon !!! encore !!!!
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: jedi poodou et 94 invités
[EP_3D] Philips 21/9ème 2010 - 3D - 58pfl9955H
- zimmer
- Inscription Forum: 05 Oct 2003 16:44
En fait , je croyais que l ' image s ' afficherait sans cliquer sur le lien. Je ne sais pas comment faire autrement.
Quelqu ' un peut nous le dire ?
- zimmer
normalement via imageshack tu peux le faire !
- Carleone
- Inscription Forum: 31 Déc 2008 11:17
Ok faut cliquer sur img : ça donne ça :
et le lien de l ' image tu la met entre les 2
- zimmer
Salut a tous
Est ce qu il est possible que quelqu un mette en francais le test
De l ecran qui est actuellement en anglais
- lexaout95150
- Inscription Forum: 21 Jan 2010 23:17
Il suffit de demander :
* qualité d'image exceptionnelle
* lunettes 3D met en marche automatiquement
* traitement de l'image peut-être exagéré
* Prix élevé
Philips a secoué le monde AV dix-huit mois auparavant, lorsqu'il a présenté le premier rapport d'aspect TV 21:09. Bien que tous les autres écrans sont conformes au format 16:9 d'abord décidé à l'époque Chumley-Warner de tubes à rayons cathodiques à écran large, Philips s'est tourné vers le cinéma super-large de l'inspiration.
Le résultat a été un écran de télévision qui a été un match presque parfait pour la majorité des films sortis en Blu-ray. Pour les fans du film, cela signifiait pas top plus noir des bars et des bas lors d 'une nuit dans un seau de pop-corn. Maintenant, la marque a dévoilé un modèle de deuxième génération à la pointe fest IFA à Berlin, c'est encore plus spectaculaire.
T Le rétro-éclairage CCFL vieux morceaux a été remplacé par un faible encombrement LED de remplacement et l'écran est entièrement compatible 3D. L'ensemble, qui remplace l'original et, seul, assis dans la gamme Philips, les navires plus tard ce mois-ci, mais nous avons déjà eu l'occasion de le mettre à l'épreuve. Ce sont nos premières impressions.
Qu'est-ce que vous devez savoir
Philips nouveau téléviseur Cinema 21:9 est à la fois plus mince et plus grand que son prédécesseur. The screen now measures a massive 58-inches corner to corner. L'écran mesure maintenant un coin massive 58-pouces à angle. Il dispose également d'un rétro-éclairage de loin supérieure. Bien que l'original utilisé torches CCFL quelque peu inégal, le nouveau modèle de sport multi-segmenté, gamme complète d'éclairage LED.
T Cela signifie des noirs profonds et dynamiques avec des teintes riches de Dubaï. C'est aussi le premier écran Philips avec intégrée Active Shutter support de la 3D (il ya d'autres Philips téléviseurs 3D à venir plus tard cette année, mais ils ont tous vous avez besoin pour la souche jusqu'à un émetteur séparé et faisceau verres, prix à environ £ 250).
Il ne faut pas longtemps pour s'apercevoir que le nouvel écran emploie aussi militaire de traitement d'image de qualité. I Ses images sont plus nettes, plus lisse et plus brillante que toute la marque a publié avant. In fact, it may have the brightest LED pictures we've seen to date --En fait, il peut avoir les plus brillants des images LED que nous avons vu à ce jour - grâce à une fonction de pointe stimuler blanc surnommé par boffins Philips Bright Pro.
Picture processing tweaks réglages de traitement d'image
L'ensemble des performances de mouvement est remarquable. Ce nouveau Cinema 21:9 ensemble a la dernière itération de la marque Perfect Pixel HD Engine, avec 400 Hz Clear LCD supercherie cadence.
C'est bien beau, mais nous avons quelques problèmes avec juste dans quelle mesure Philips a poursuivi finesse d'image sur cet appareil. Un résultat regrettable sur n'importe quel téléviseur qui utilise des fréquences de rafraîchissement d'image sur 200 Hz, c'est que l'aspect caractéristique du film est perdu. Poussé trop loin et les films commencent à présenter des artefacts de mouvement étrangement glissante.
Cependant, vous pouvez toujours éteindre la fonction (ou vers le bas).
Plus utiles sont les bosses de résolution pour la vidéo Internet bas débit et la vidéo en définition standard. mise en valeur de propriété Bit Smart et réduction du bruit améliorée donnent du lustre supplémentaire et en détail à la vidéo Internet et les canaux peu en manque de TNT.
Est-ce le meilleur de la TV 3D encore?
. Peut-être la plus grande révélation est juste à quel point 3D regarde sur le LED Cinema 21:9. Nous avons couru à travers une sélection de matériel 3D et a été éliminé par la clarté et la luminosité de ses images 3D.
Philips a mis beaucoup d'efforts pour diminuer le problème de la diaphonie (le double d'imagerie couramment vu sur les écrans LCD). Ses images 3D sont aussi étonnamment lumineux.
Le rapport d'aspect 21h09 de l'ensemble semble vraiment à améliorer les effets 3D. En l'absence de barres noires de blocage dans l'image, des visuels regardent comme ils sont sur le point de déborder sur le bord de la lunette. Une démo de Burton's Alice au pays des merveilles de Tim regarda sensationnel. La luminosité de l'ensemble de l'image étonnante et des couleurs, et en douceur 3D convaincante sans doute fait le film de meilleure qualité que l'a fait au cinéma.
Contrairement aux articles de lunetterie rival qu'ils n'ont pas besoin d'être activé manuellement. Les spécifications automatiquement sous tension quand ils reçoivent un code d'activation de la TV, déclenchée par n'importe quelle source connectée 3D. Très malin!
Tandis que le ratio de l'ensemble son aspect insolite est idéal pour les films, ce n'est pas si brillante pour le 16:9 format TV. TCela signifie que, pour beaucoup, l'affichage finira comme une pièce maîtresse dans un home cinéma, probablement couplé à une autre source HD tels que Sky HD.
Alors qu'est-ce que nous pensons?
Philips peut être labourer un sillon solitaire avec son Cinema 21:9 Platinum écrans 3D, mais les fans du film seront époustouflés par cette mise à jour. Nous pensons qu'il pourrait même être assez bon pour une conversion de la 3D cyniques là-bas.
* Prix élevé
- zimmer
C'est clair que pour des films en 2.35 et pour certains jeux PC, ça met la bave aux lèvres, mais si il n'est pas possible de garder les bandes noires sur les côtés afin de conserver l'intégralité de l'image d'un film en 16/9, je passe mon chemin.
- Geekeeta
- Inscription Forum: 30 Juil 2007 17:29
- Ridge Racer
- Inscription Forum: 10 Nov 2005 0:49
un petit rappel de la Charte semble nécessaire
Sont interdits sur les forums :
5-11 les posts recopiant intégralement ( copier/coller ou scan ) un texte publié ailleurs ( autre site web ou article de journal ) à moins de pouvoir justifier d'une autorisation de reproduction du texte d'origine. Pour argumenter un point de vue, il est possible de citer un court extrait d'un texte à condition de préciser de façon claire et explicite la source ( lien vers le site web, titre + numéro du magazine + auteur de l'article, ... ).
- alfa
- Inscription Forum: 27 Avr 2003 14:33
Ridge Racer a écrit:ça doit être pareil que sur le 56PFL9954,
Il y a un exemple de format d'image avec me 16/9 ici
http://www.lemondenumerique.com/page-13034-philips-56pfl9954h.html#test-373-3-philips-56pfl9954h.html
Comme je le disais en première page, vous avez 45 pages de discussion sur le prédécesseur du 58" ici: viewtopic.php?f=1194&t=29904885
Vous y trouverez toutes les réponses à vos questions par ceux qui possèdent déjà une dalle 21:9.
Merci Dialhot et Ridge Racer ! J'avais bien suivi ton lien mais je m'étais contenté de le lire en diagonale... Les formats sont donc respectés, c'est une très bonne chose. Il me reste un a priori en ce qui concerne le retro-éclairage LED dont l'impact semble dénaturer la finesse des détails contrastés (est-ce ce que vous appelez clouding ?). Je vais voir si je trouve des retours utilisateurs à ce sujet. En tous cas, la profondeur des noirs sur le 58" est étonnante...
- Geekeeta
@zimmer : heu ...y' a pas un problème sur les images de l'age de glace ??... sur la deuxième captures d'écran, l'image semble "tronquée", comme si un zoom était appliqué cachant certaines parties importantes de l'image , comme les pattes de Sid !
- lbhc
- Inscription Forum: 03 Avr 2007 17:28
C ' est normal . L ' age de glace est en 1.85 donc en 21/9 il manque le haut et le bas.
Mais on peut le regarder en 1.85 natif , tu auras des barres noires à gauche et à droite !!
- zimmer
