Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: glentoran, mangotin, Noricha, Nouche38, parager, Poune, totof66, ZEPHYR92, zlu et 57 invités
Logitech Squeezebox
Tire du manuel :
No light: Squeezebox Receiver is OFF.
Low white: Squeezebox Receiver is ON but no music is playing.
Bright white: Squeezebox Receiver is ON and music is playing.
Fast blinking white: Automatic software update is in progress.
Solid red: Starting up.
Slow blinking red: Waiting to be configured for your network.
Fast blinking red: Factory reset in progress.
Yellow: Connecting to your network.
If the light remains yellow, it means that the player
is having trouble connecting to the network. If
you are using a wireless network, please see the
Troubleshooting section in this User Guide.
Green: Connected to your network and waiting to be
assigned an IP address by the DHCP server.
If the light remains green, confirm that your wireless
router is providing DHCP service. In some wireless
network installations, the router may be configured
to limit the number of IP addresses for security
purposes. If DHCP is running correctly, check to see if
the router has run out of IP addresses.
Blue: Connected to the network and waiting to connect
to a music source (such as SqueezeNetwork or
SqueezeCenter).
If you are attempting to connect to SqueezeCenter
and the light remains blue, the most likely cause
is a firewall running on the computer on which
SqueezeCenter is installed. See Appendix A:
Configuring Your Firewall. If you are attempting
to connect to SqueezeNetwork and the button
SqueezeCenter).
Hi-fi : nas Qnap TS221, Transporter, Minidsp SHD, Soncoz SGD1, BoXem 4215/E2, Vivid Audio B1, Rel G2
JG Naum - Modérateur Œuvres & Multimédia
- Inscription Forum: 12 Mar 2005 20:08
Pour ta connection, ca ressemble au 'mode pont inverse' (cherche pas je viens de l inventer
) : Le receiver utilise le controller(via le reseau wifi prive entre les 2) pour se connecter a la SBS.... Normalement ds le e mode pont, c est l inverse...
Tu as le guide utilisateur de la duet ? (je l ai in english...)
![:mdr:](https://www.homecinema-fr.com/forum/images/smilies/icon_mrgreen.gif)
Non j'ai pas , mais oui j'ai couper mon wifi pour que le Receiver prenne le RX filaire.
J'veut bien un manuel LoL
- Gandalflux
En fait je pense que tu as rate le moment ou tu dois preciser que le receiver doit se connecter en ethernet... T es bon pour recommencer a zero... Avt, envoie moi un mp avec une adresse mail pour le manuel en anglais... Pour cette partie, il est tres clair
GandalfLux a écrit:Non j'ai pas , mais oui j'ai couper mon wifi pour que le Receiver prenne le RX filaire.
Il me semble que pour passer du sans fil au filaire sur le Receiver, une réinitialisation du Receiver est indispensable.
![:idee:](https://www.homecinema-fr.com/forum/images/smilies/icon_idea.gif)
- sebp
- Contributeur HCFR 2016
- Inscription Forum: 07 Juin 2007 23:35
pourtant avant j'ai fait un appuie long sur le receiver ...
M'enfin oui j'ai OBLIGATOIREMENT louper un truc LoL
MP envoyé JG Naum Merchi![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
- Gandalflux
Ca suffit pas de reinitialiser... Il faut le faire correctement
... De memoire une fois que tu as connecte le controller a ton reseau (et que le receiver est en mode association) il te demande comment tu veux que ton receiver se connecte. Et la tu n as pas droit a l erreur ....
J ai recu le MP... ![:idee:](https://www.homecinema-fr.com/forum/images/smilies/icon_idea.gif)
![:lol:](https://www.homecinema-fr.com/forum/images/smilies/icon_lol.gif)
Bon allez demain ça marche
LoL
J'imprime la doc au taf avant de partir tous à l'heure![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
![:)](https://www.homecinema-fr.com/forum/images/smilies/icon_smile.gif)
- Gandalflux
La doc est ds les tuyaux....
N y passe pas la nuit tt de meme !
ça c'est pas gagné LoL
mille merci à toi![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
mille merci à toi
- Gandalflux
Ben alors Gandalflux ! Tu l as mate ton receiver ?
Sinon en ce moment pas moyen de se connecter a mysqueezebox.com pour ecouter la radio le matin
![:evil:](https://www.homecinema-fr.com/forum/images/smilies/icon_evil.gif)
Heu alors oui ![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
J'ai couper mon Wifi et tous refait est Hop tout fonctionne nickel j'ai pue faire une belle démo résultat il en achète une hii Hiii
Donc maintenant le seul truc wifi à la maison c'est la connexion Contrôleur receiver![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
Par contre j'ai pas trouver ou lui coller une IP Fixe ni au controler ni au receiver![:(](https://www.homecinema-fr.com/forum/images/smilies/icon_frown.gif)
Et autre choses sans mon Wifi ( du routeur) est ce que je peut contrôler avec mon Iphone le receiver ? ( en Wifi ? ) J'sait pas si je suis clair pour le coup![:oops:](https://www.homecinema-fr.com/forum/images/smilies/icon_redface.gif)
- Gandalflux
Non, l'iphone (iPeng) ne contrôle pas le Receiver, il contrôle le serveur, donc tu as besoin d'activer le Wifi sur ton LAN pour que l'iphone et le serveur (ton NAS) se voient ![:)](https://www.homecinema-fr.com/forum/images/smilies/icon_smile.gif)
Au fait, iPeng for iPad est sorti!! Excellent![:wink:](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
- djoole
- Inscription Forum: 25 Avr 2007 0:43
Bon c'est bien ce que je pensait. Merci de me le confirmer.
J'avoue..... J'aurais pue faire le test mais pas trop le temp![:(](https://www.homecinema-fr.com/forum/images/smilies/icon_frown.gif)
- Gandalflux
Ca commence à me saouler les pertes de synchro de la Squeezebox Radio par rapport à la Boom...
J'ai au moins une coupure toutes les 10 minutes, parfois elle reprend la synchro 10 seconds plus tard, parfois pas du tout.
Pourtant le signal wifi est à 90%
Vous avez les mêmes soucis?
J'ai une synchro à 0ms en paramétrage, ça peut être dû à ça?
Les deux diffuse du son dans deux pièces accolées sans séparation, donc si j'ai un décalage c'est l'horreur
- ZeTom
- Inscription Forum: 04 Sep 2007 9:52
