![Image](http://img59.imageshack.us/img59/7048/umc1.jpg)
Maintenant que les premiers utilisateurs français ont reçus leur UMC-1, je pense qu'un topic unique sera intéressant pour tout le monde
J'essaierai de mettre à jour autant que possible cette première page avec les derniers infos, firmwares, cr, ... concernant cette machine à fort potentiel.
Dernière information : 30/11/2011
Le firmware v7.4.19 a été ajouté.
Site officiel
Tarifs : 699$ -> Baissé à 499$
Frais d'expédition via Fedex pour la France : 83$
Manuel d'utilisation
Descriptif technique :
![Image](http://img36.imageshack.us/img36/3163/topicumc12.th.jpg)
![Image](http://img227.imageshack.us/img227/6482/topicumc13.th.jpg)
* Twin Cirrus® 32 bit dual core DSP’s
* Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, SPDIF, PCM 8 channel (note: some audio formats are only supported via HDMI)
* Multi-channel Dolby Volume
* Genesis/ST® Torino high performance scaling engine - featuring a full implementation of the Faroudja DCDi™ image processing suite
* Intuitive, full color graphical OSD with adjustable transparency presented over live video, including HDMI
* Emo-Q™ automatic multi-channel room correction and loudspeaker setup. Calibrated measurement microphone included.
* Quadruple bass manager with independently selectable high and low pass frequencies from 40hz – 250hz, in 5 or 10Hz increments (depending on frequency)
* Selectable 12db or 24db per octave high pass and low pass filters by channel groupings
* Independent 11-band graphic EQ with global bass and treble controls by channel groupings
* Balanced subwoofer output
* All legacy video inputs can be scaled and output over HDMI at up to 1080p
* 1080p/24 fps video support
* Video pass-through mode with 12 bit compatibility
* HDMI sources can be format converted to component video up to 1080i (subject to Macrovision™ guidelines)
* HDMI 1.3a Deep Color compliant
* All inputs are assignable and feature input labeling, selectable decode modes, selectable triggers, etc.
* 0.5dB level trims on all channels
* High voltage, low impedance main analog outputs for uncompromised dynamic headroom
Connectique :
![Image](http://img30.imageshack.us/img30/8085/topicumc14.jpg)
* 5 - HDMI inputs and 1 HDMI output.
* 3- composite video inputs (RCA)
* 3 - S-video inputs (S-video mini DIN)
* 3 - component video inputs (RCA)
* 1 - component video output (RCA)
* 4 - stereo analog audio inputs (RCA)
* 1 - 7.1 analog input set (RCA)
* 1 - 7.1 analog output set (RCA)
* 4 - coaxial digital inputs, (RCA)
* 3 - optical digital inputs (Toslink)
* 1- coax digital audio output (RCA)
* 1- optical digital audio output (Toslink)
* 1 - Stereo or 2 channel analog multi channel mix down output for fixed level monitoring (RCA)
* 1- stereo analog variable and independent Zone 2 output (RCA)
* 1 - stereo analog fixed level record output (RCA)
* High performance AM/FM tuner with 24 FM and 6 AM presets
* 3 - assignable trigger outputs Movie/Music/Amp (3.5mm mini)
* 1- IR input (3.5mm mini)
* 1 - IR output (3.5mm mini)
* 1. Microphone input (3.5mm stereo mini)
* 1- USB data input (for software upgrades only)
* Size: 17” W x 3 7/8” H x 13” D
Emo TV / Vidéos officielles : (en anglais)
* Procédure de mise à jour du firmware V6
* Utilisation de l'EmoQ
* Principe de fonctionnement de l'EmoQ
Vidéos utilisateurs :
* Vidéo de présentation de la première mise en route de l'UMC-1 avec XPA-5
* Vidéo de navigation dans les menus de l'UMC-1
* Vidéo de procédure de mise à jour du firmware V6
Procédures de mises à jour du firmware :
Page officielle des mises à jour
- Connaître sa version de firmware :
Appuyez via la télécommande sur les touches "Mute" puis "Status" puis "Volume +"
Dernières instructions officielles de mise à jour (en date du 30/11/2011) :
* Procédure officielle d'installation du firmware V7.4.19
Dernier firmware officiel disponible (en date du 30/11/2011) :
* V7.4.19
Dernier logiciel Emotiva Updateur de disponible (en date du 30/11/2011) :
* Logiciel Emotiva Updater V1.06.05
Anciennes procédures et logiciels :
* Procédure officielle d'installation du firmware V7.4.07
* Procédure officielle d'installation du firmware V7.2
* Procédure de mise à jour du firmware V7 en Français
* Procédure officielle d'installation des firmwares V6
* Logiciel Emotiva Updater pour fw V6 (V10502)
Anciens firmwares :
* V7.4.19
* V7.4
* V7.2.00.05 ATTENTION : Ce firmware est une version bêta non distribuée officiellement par Emotiva. Il est fourni uniquement par mail en le demandant. Vous prenez donc vos propres responsabilités en l'installant.
* V7.2 stable
* V7 stable (Attention ! Nouveau logiciel d'installation et procédure de mise à jour à télécharger ci-dessus)
* V6 bêta 3
* V6 bêta 2
* V6 bêta 1
* V6 + DSP Flash + code F340
* Déballage et première présentation
* CR de mouchli
* 1er CR de le caribou + 2ème CR
* Premiers essais de l'EmoQ
* CR de Genki
* Photos avec les baguettes (trims) officielles métal et noir
* CR de jalatrix
* CR de Skyzook
* CR de echobelly
* CR de lolo63
N'hésitez pas à me contacter afin de tenir à jour cette page en me fournissant lien vers CR, vidéos, astuces, ...
