Par contre y'a énormément de texte à traduire et à l'aveuglette c'est pas facile, y'a ça à traduire:
- Code: Tout sélectionner
WARNING: Unknown key found: "upgrade_attention".
WARNING: Unknown key found: "upgrade_dark_screen_warning_string1".
WARNING: Unknown key found: "upgrade_dark_screen_warning_string2".
upgrade_confirm_warning_text_2 =
upgrade_confirm_warning_text_3 =
upgrade_confirm_warning_text_1 =
upgrade_confirm_warning_text_4 =
upgrade_confirm_warning_text_5 =
dialog_utils_url__1 =
fw_online_upgrade_non_stable_non_current_version_caption__1 =
fw_upgrade_setup_hr_settings =
video_setup_hdmi_color_depth_8_bit =
fw_online_upgrade_dialog_title =
smb_mount_in_use_description3 =
navigator_item_info_label_workgroup =
video_advanced_settings_dialog_title =
fw_online_upgrade_no_suitable_storage_text_1__1 =
fw_online_upgrade_stable_non_current_version_caption__1 =
hdmi_color_depth_confirm_text2 =
video_setup_hdmi_color_depth =
hdmi_color_depth_confirm_text3 =
fw_online_upgrade_confirm_non_stable_version_text_4 =
hdmi_color_depth_confirm_text4 =
network_browser_default_smb_network_folder_name__2 =
hdmi_color_depth_confirm_text__1 =
fw_online_upgrade_confirm_non_stable_version_text_1 =
fw_online_upgrade_confirm_non_stable_version_text_2 =
fw_upgrade_setup_label_warn_about_autocheck_failures =
fw_online_upgrade_confirm_non_stable_version_text_3 =
color_depth__1 =
fw_online_upgrade_autocheck_failed_message_text_2 =
video_setup_hdmi_cec_disabled =
fw_online_upgrade_autocheck_failed_message_text_1 =
upgrade_attention_text_1 =
upgrade_attention_text_2 =
fw_upgrade_setup_label_ignore_non_stable_versions =
fw_online_upgrade_confirm_disable_autocheck_text_1 =
fw_online_upgrade_confirm_disable_autocheck_text_3 =
fw_online_upgrade_confirm_download_system_storage_text =
fw_online_upgrade_confirm_disable_autocheck_text_2 =
fw_upgrade_setup_check_failed_message_line_2 =
network_browser_disconnect_failed =
fw_online_upgrade_downloading =
photo_viewer_info_format_aai =
navigator_item_info_disconnecting =
fw_online_upgrade_install_button =
download_file_dialog_error__1 =
fw_upgrade_setup_check_failed_message_line_1 =
download_file_dialog_avg_speed =
fw_online_upgrade_remind_later_button =
download_file_dialog_error_closing_output_file =
download_file_dialog_error_writing_output_file =
fw_online_upgrade_no_new_version_message =
fw_online_upgrade_show_all_versions_button =
download_file_dialog_error_opening_output_file =
network_browser_popup_disconnect =
download_file_dialog_error_opening_input_stream =
video_setup_hdmi_cec_enabled =
fw_online_upgrade_autocheck_failed_ignore_button =
download_file_dialog_error_reading_input_stream =
hdmi_color_depth_confirm_title =
download_file_dialog_read_value__2 =
fw_online_upgrade_new_version_message =
fw_upgrade_setup_checking =
fw_online_upgrade_autocheck_failed_do_not_warn_button =
setup_fw_upgrade_settings =
video_setup_hdmi_cec =
fw_upgrade_setup_label_autocheck_updates =
network_browser_popup_add_to_main_screen =
fw_online_upgrade_skip_this_version_button =
video_setup_advanced_settings_edit =
download_file_dialog_avg_speed_value__1 =
fw_online_upgrade_stable_current_version_caption__1 =
fw_online_upgrade_non_stable_current_version_caption__1 =
download_file_dialog_remaining =
download_file_dialog_error_getting_file_size =
download_file_dialog_confirm_cancel_title =
video_setup_hdmi_color_depth_10_bit =
video_setup_hdmi_color_depth_12_bit =
video_setup_hdmi_color_depth_auto =
fw_upgrade_setup_label_current_version =
navigator_error_failed_to_open_url =
fw_online_upgrade_confirm_download_text =
fw_online_upgrade_confirm_disable_warn_about_autocheck_failures_text_2 =
fw_online_upgrade_unpacking_error_text =
fw_online_upgrade_confirm_disable_warn_about_autocheck_failures_text_3 =
download_file_dialog_button_cancel =
fw_upgrade_setup_button_check =
download_file_dialog_opening_url =
fw_online_upgrade_confirm_skip_version_text_1 =
fw_online_upgrade_no_suitable_storage_text_2 =
fw_online_upgrade_confirm_disable_warn_about_autocheck_failures_text_1 =
network_browser_popup_disconnecting =
fw_online_upgrade_show_all_version_dialog_title =
fw_online_upgrade_confirm_skip_version_text_2 =
video_setup_advanced_settings =
fw_online_upgrade_unpacking =
fw_upgrade_setup_hr_status =
fw_online_upgrade_searching_suitable_storage =
navigator_item_info_button_disconnect =
navigator_item_info_title_smb_share =
navigator_item_info_disconnect_failed =
fw_upgrade_setup_title =
Pour les 3 premières lignes je sais pas trop ça dit que ça n'a pas été trouvé, par contre pour les autre ça dit juste que c'est manquant...
Donc si y'a des personnes qui savent à quoi correspondent chaque balise, donnez moi les infos
![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
