Bonjour, I am a new user of HCFR. I really need help with installing my colorimeter.
Is the Pantone Huey Pro colorimeter , able to work with HCFR ?
I am very grateful if someone can help me.
Please give details if you are able to.
Thank you /Merci
mdphd777@sympatico.ca
Marc in Canada.
7 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Modération Forum Installations, Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: ericb56 et 12 invités
At this stage, the software only works with the home made HCFR sensor, the Sypder 2 and 3, DTP94 and Eyeone.
Quote from the software tutorial : "En plus de la sonde décrite plus bas, le logiciel prend aussi en charge des sondes du commerce, les Spyder II, Spyder III (nouveau dans cette version), DTP94 ainsi que les modéles EyeOne (Beamer, Display 2, Display LT) de Gretag sont supportées."
- homecinema67
- Inscription Forum: 08 Fév 2009 23:22
Merci HomeCinema67. I returned the Pantonr Huey. I only bought it because someone posted on AVS forums that it worked with HCFR. Not so.
I bought the Spyder 3 pro but it does not work in HCFR. I moved the spyder3 dll into the HCFR directory and still problems.
Please someone, a fellow enthusiast is suffering cos I really want this to work so I can get into calibration of my Plasma and Epson Projector.
Any advice is welcome.
Marc au Canada
Marc au Canada
- avhound77
- Inscription Forum: 14 Fév 2010 11:22
Continuation!!!!
I would really appreciate it if a kind soul will email me the old Spyder 3 dll file. I have been reading and I understand that for HCFR to recognize my Spyder 3 pro, I will need the old Spyder 3 dll file and not the latest version.
So , please if someone has it Can you , Will you e-mail me a copy ?
Many thanks
Marc Au Canada
or
maansaad@sympatico.ca
Merci. Shoukran.
Many thanks
Marc Au Canada
or
Merci. Shoukran.
- avhound77
I have the Spyder 3 pro myself and had the same issue.
Here is a link wit the old file.
http://www.megaupload.com/?d=9CTK7TEZ
Good luck with your calibration.
- homecinema67
Merci homecinema67
Je voudrais vous remerciez pour votre aide, homecinema67. J'ai recu l'affiche comme vous avez me montrer. Est-ce que c'est possible de vous demandez pour de l'aide si j'ai d'autres questions?
Marc au Canada.
Marc au Canada.
- avhound77
You are welcome Marc. No problem for further help if I can ... Take care. François
- homecinema67
7 messages
