Des informations officielles sur les changements de firmware apportés par Philips. On trouve ça ici.
Pour info, voici la liste des tous les changements :
Software history
Main modifications
Each release contains:
• All solutions identified in earlier versions
• Improved connectivity to improve compatibility with other external devices
Q591E_0.100.0.0
• implementation to switch off the overnight update.
• Regression caused on HDMI has been resolved.
Q591E_0.97.0.0
• Solution for picture drops when watching digital broadcasts in the United
Kingdom.
Q591E_0.94.0.0
• audio issue solved when switching between HDMI sources.
• Optimalisation Audio SPDIF for HTS3367
Q591E_0.93.0.0
• Upgrade Madrid solution.
• Improvement for Riks-TV.
• Improved picture quality via availability of more colors.(color gamut)
Q591E_0.91.0.0
• Solution for the Madrid Broadcast issue.
• Improvement digital channel reception La7 DVB payTV channel Italy.
• DGTVi approved.
Q591E_0.89.0.0
• Improvement of Teletext.(no longer mixed pages or skipped parts)
• Solution for loosen channels overnight in Denmark.
• Reboot of the 42PFL9803D/10 after switching to the HDMI(Philips 1080)
solved.
Q591E_0.83.0.0
• replaces all previous releases, including Q591E_1.58.14.0.
• problems with installation algorithm for DVB-T UK solved.
• audio problems with certain STB devices solved.
Q591E_0.58.14.1
• Improvements for DNLA(decrease time to display thumbnails)
• Improvements DVB-T for France(region with the Belgian boarder)
Q591E_0.58.11.0
• Improvement of the OSD after start-up.
Q591E_0.58.8.0
• Missing of information on TXT pages has been solved.
• Improved settings when identifying the source as a 'PC'.
• Resolving the fact that mouse movements lag behind.
• Solution about disappearing subtitles with DVB-C.
• Sporadically no picture on DVB-C channels with specific CAM's and when
starting up the TV, has been solved.
Q591E_0.58.5.0
• Improvement of the connection via HDMI with Bose system.
• Improvement of stand-by behaviour.
• Improvements for EPG behavior in UK.
• Functionality added for Australia and Finland.
• Improvement scroll behavior remote control.
• supports MPEG4 in Spain.
Q591E_0.25.26.1
• Improved channel reception in Spain.
Q591E_0.25.24.1
• Improved black impression.
Q591E_0.25.21.0
• A 1080p 60Hz type of input signal does no longer show flashes on screen
with this software upgrade.
• The Common Interface functionality is now enabled for the UK with this
software upgrade.
• Possible picture judder with MPEG4 signals is solved with this software
upgrade.
• While the TV relaunches its software during normal use, strange picture
and sound artefacts no longer appear, with this software upgrade
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 103 invités
Philips xxpfl7403, xxpfl7423
- Kcnarf57
- Inscription Forum: 09 Déc 2008 11:12
Salut à tous,
Je viens de brancher mon PC par la prise dite "VGA" sur ma 47PFL7403, et je ne parviens pas à mettre une réso supérieure à 1360*768.
Déjà, à la base, le maxi était le 1024*768. Il a fallu que je décoche sur le panneau de config du PC l'option "masquer les résolutions non supportées par l'écran".
Là, j'ai bien accès à quantité de réso, dont le 1920*2080. Mais la TV n'affiche pas l'image.
Elle m'indique "pas de signal video" et non "signal video non supporté", ce qui indiquerait qu'elle reçoit quelque chose au moins...
J'ai essayé le mode couleur 16 bits également, et je suis resté en 60hz.
Bref, si quelqu'un a une idée, je suis preneur.
Pour info, j'ai un P4 2Ghz sous Win XP avec une CG Nvidia GeForce 4 MX 440 with AGP8x.
Fafa - Administrateur Suppléant de l'Association - Secrétaire Adjoint & Superviseur Forum Univers TV
Fafa a écrit:Salut à tous,
salut fafa,
je pense au vue des capacités de ta CG tu aura pas mieux que le 1024 x 768.
"• Moteur de traitement vidéo (VPE) de NVIDIA proposant des capacités vidéo et multimédia inégalées
° Intégration d'un encodeur TV à une résolution de 1 024 x 768
° Intégration d'un décodeur MPEG-2 matériel
° Compensation de mouvement et IDCT
° Compatibilité HDTV ....."
si tu pousse ta CG au dessus, tu aura un ecran noir due a la carte.
je pense que si tu veux profiter du 1920 x 1080 sur ton ecran, il te faut changer de CG.
cordialement
ange
- aNGe_a_Sa_FeMMe
- Inscription Forum: 11 Avr 2008 21:57
Merci pour ton avis.
Actuellement, j'arrive quand même à être en 1360*768, ce qui n'est pas trop mal.
