Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Calibre 101 et 49 invités
Les Lecteurs CD & SACD
NAIM UNITIQUTE
Message » 10 Jan 2010 21:42
"Exciting New product from Naim Audio!
UnitiQute all-in-one audio player £1350
Connect with your music like never before
It’s a cliché we know, but good things come in small packages. The UnitiQute all-in-one audio player however isn’t just good: it’s a brilliant-sounding, uniquely versatile, seductively compact and, of course, irresistibly cute example of what contemporary music in the home is all about. Music downloads, high-resolution music files, internet radio, network music, UPnP™ servers, iPod/MP3 players, Wi-Fi streaming - everything that the new era of music delivery can throw at it, UnitiQute can play.
Music for everyone
Just like NaimUniti, its multi-award-winning sibling, UnitiQute is right at the forefront of modern music delivery technology, and its significance for music enthusiasts of all aspirations is far greater than the simple sum of its component parts. For the committed enthusiast with an existing Naim setup, UnitiQute can not only deliver exceptional Naim music-making as a second system, but also play the role of gateway to all the new digital music delivery formats - from USB memory sticks, UPnP™ streaming to internet radio. For the more casual listener, UnitiQute can take the place of both the old hi-fi system and the iPod dock, sound far better than either, and at the same time introduce new worlds of audio ripe for exploration.
Small box...Big on features
For starters, UnitiQute includes a preamplifier with two analogue inputs, five 24bit/192kHz-capable digital inputs and all the traditional Naim musical clarity and transparency. Next, UnitiQute includes a muscular power amplifier that provides all the rhythmic punch and definition you would expect from Naim. You want conventional radio? Well, UnitiQute includes FM and DAB tuners that get the best possible performance from either format. UnitiQute is happy also to play music from an iPod or MP3 player via its front panel-mounted USB socket. The USB audio connection is digital so iPod sound quality is optimised, and Apple authenticated too so compatibility is seamless. And the same USB socket can be used to play music files in almost any format at up to 24bit/96kHz resolution straight from a memory stick. And it doesn’t end there. A network Ethernet socket and integrated Wi-Fi means that, along with everything else, UnitiQute can easily tap into Internet radio or UPnP™ servers, a Naim HDX for example, to drop almost unlimited music choices right into your lap. Talk about cute.
Easy access to your music
Bringing everything audio, digital and analogue together is one thing, but making it all work seamlessly together is something else entirely. UnitiQute is controlled by a dedicated remote handset in combination with a large, clear display. The UnitiQute user interface borrows the principles of intuition and accessibility, and much of the substance, from the already proven NaimUniti interface. The interface is clear, intuitive, uncluttered and makes light work of access to UnitiQute’s remarkable versatility and performance. And an iPhone/iPod Touch Uniti control App, expected early in 2010 will enhance the UnitiQute experience still further and raise its brilliance yet another notch.
Then there are the multi-room audio opportunities that UnitiQute opens up. With a UPnP™ server, a wireless network router and a UnitiQute you have a very high performance hi-fi system with access to almost limitless music. Add a second, or even a third UnitiQute and you have a multi-room hi-fi system that installs effortlessly, is easily modified and sounds outstanding.
Enter the world of digital music
There’s never been a more exciting time to be an audio enthusiast and NaimUniti is an audio product whose time has come. NaimUniti: All in one, for one and all.
Streaming
UnitiQute can play audio fi les at resolutions up to 24bit/96kHz streamed from UPnP™ music servers like the Naim HDX hard disk music player, or from PC or Apple Mac music libraries. And if you don’t like the idea of running network cables around the house, don’t worry. UnitiQute can do all this wirelessly.
Multi-format Radio
The UnitiQute multi-format tuner can switch seamlessly between DAB, FM and Internet radio stations. Favourite stations are listed in a common interface menu for browsing and selection. An entire world of radio is a few button presses away.
iPod and MP3
Connect an iPod or MP3 player via the UnitiQute USB interface and its audio files and playlists are listed on the UnitiQute display for simple browsing, selection and playback.
USB-stored Audio
Connect a USB memory stick to the front panel USB socket and the audio files it contains will be identified by the UnitiQute interface and be immediately available for browsing, selection and playback. UnitiQute can play USB-stored music files of up to 24bit/96kHz resolution.
Your complete audio system
UnitiQute may be compact but it packs some serious audio technology within its elegant extruded and die-cast enclosure. On the analogue side, the UnitiQute preamplifier module is a distilled version of that found in its NaimUniti sibling. Similarly, and again, as with the NaimUniti, the UnitiQute power amplifier borrows its design from the NAIT 5i, and given a pair of Naim n-SAT speakers to work with, the music it makes is dynamic, tuneful and addictive.
UnitiQute digital audio performance profits immeasurably from nearly two decades of high-end digital audio knowhow and experience at Naim. From the first CD player, the CDS in 1991, to the stunning DAC digital to analogue converter of 2009, every Naim digital product has advanced the art of digital audio engineering to the benefit of music reproduction. UnitiQute is no different. UnitiQute is capable of handling an enormous range of digital audio formats, and Naim digital audio engineering ensures that each one sounds as musical and engaging as its inherent potential allows. UnitiQute digital connectivity also means that as well as offering all-in-one functionality operating as a digital hub for external digital sources, games consoles or digital TV audio for example, it can also output its internal sources or external digital signals to an external DAC for even higher audio quality.
Analogue audio connectivity is not forgotten either. Two analogue inputs can accommodate CD players or portable music players via rear panel phono sockets and a front-panel mini-jack. And a preamplifier output means that with the addition of an external power amplifier, or even a sub-woofer, UnitiQute can become the heart of a very wide bandwidth audio system. And when you want to listen privately, a front panel headphone socket makes such selfishness all too easy.
KEY FEATURES
* UPnP™-enabled for playback of network-stored audio / internet broadcasts from PC, Mac or NAS drives
* Multi-format radio (FM, DAB, Internet)
* Front-panel USB for iPod/MP3 player and USB memory stick playback
* Apple authenticated enabling digital output from iPod for ultimate quality
* iPod control, charging and front-panel content display when connected to front-panel USB port via standard iPod cable
* 3.5mm front panel input that supports both analogue and digital sources
* Two analogue inputs (3.5mm front-panel socket and RCA)
* Onboard DAC with five 24bit / 192kHz capable S/PDIF inputs for external digital sources
* Preamplifier and 45W per channel into 4Ω, 30W per channel into 8Ω power amplifier
* Ethernet and Wi-Fi network connectivity
* Plays WAV, MP3, Windows Media–formatted content, AAC and FLAC from any suitable UPnP™ device together with WAV, AAC, MP3 and Apple Lossless (from an iPod)
* Switchable bass contour control for low-volume listening
* Bass management system for use with subwoofer-satellite loudspeaker systems
* Digital output on 75Ω BNC connector (RCA adapter supplied)
* Front-panel display with intuitive interface, remote-controlled
* Front-panel 3.5mm headphone output
* Front panel logo touch-sensitive mute function
* vTuner 5* full service internet radio service
* Linear Power supply with 200VA toroidal transformer with three separate windings
* Separate power supplies for digital, analogue, and power amplifier
* Ground selector switch for optimum performance
* High quality Wolfson DAC
* Naim compact, non-resonant, non-magnetic case
* OLED display for high contrast
Specifications
OUTPUTS
Audio Outputs
Speaker output
Pre-amp output (RCA)
Power Output
Digital output
BNC 75Ω(plus RCA adaptor)
Other outputs
3.5mm headphone socket
INPUTS
Antenna inputs
Wi-Fi, F type (plus PAL adaptor)
Analogue inputs
3.5mm socket on front panel, 1 RCA
Overload margin
20dB
Input sensitivity
270mV at 47kOhm at 47kOhm
Digital Inputs
5 SPDIF (2 optical, 2 coaxial, 1 digital/analogue with 3.5mm jack)
USB inputs
1 Front panel socket
Other inputs
Ethernet and iPod (digital via USB socket)
CONTROL
IR input
front panel only
RS23 Yes
Other
FORMATS
Audio files supported
Internet radio (WMA, MP3 Streams, MMS)
Playlists (M3U, PLS)
MP3, AAC (up to 320 kbps, CBR/VBR)
Apple Lossless (from iPod)
WMA-9 (up to 320 kbps)
WAV and FLAC (up to 24bit/96kHz via UPnP™ and USB only)
OGG Vorbis
fr
Inscription Forum: 29 Juin 2007 17:54
Message » 10 Jan 2010 22:05
De HC-FR, je suis passé à HC-UK, c'est le bug de 2010 ? :mdr: :wink:
Mouss :wink:
HAKEM
Inscription Forum: 04 Juil 2002 7:39
Message » 11 Jan 2010 0:09
Voilà un outil qui est bien vu !
Je n'aurais pas gouté au ahut de gamme de chez Naim, je me serais bien laissé tenter :
30 watts à la Naim c'est bien suffisant pour mes Divatech....
Le Unité a une fonction qui ne me serviraitpas : la lecture CD....
Ah , si j'étais riche : je le prendrai pour mon second système : celui de ma résidence secondaire...ou ma chambre...
yijing
Message » 11 Jan 2010 0:53
Bah voui faut dire que Naim c'est pas vraiment donné non plus :wink:
Gort'h
Inscription Forum: 25 Juin 2004 14:36
Message » 11 Jan 2010 0:58
:o
Ah bon ?
-Dac
- Tuner
- Pré-amplificateur
- amplificateur de puissance
- Radio
et puis
- Prises RCA
-Usb
attends c'est pas fini :
- câbles secteur
- notice d'emploi
- certificat de garantie
C'est pas donné ? :mdr:
Ah, j'oubliais : l'antenne !
yijing
Message » 11 Jan 2010 13:44
On en parle déjà sur d'autres sujets. Et balancer en anglais les docs techniques sans un seul commentaire pour ouvrir un sujet.. :roll:
haskil
Contributeur HCFR 2024
