karyboue a écrit:A propos des Pana VX100
"The Pioneer Kuro screens set new standards for image quality, but these new monitors from Panasonic are in some ways even better. The level of detail they offer is unparalleled."
http://www.homecinemachoice.com/blogs/t ... nity+02+03
Un autre point de vue :
"The other major difference between the KURO and the Panasonic Premiere is the way they revealed dark detail. The KURO takes a higher level signal to come out of black, which caused details in dark movies (think Batman Begins and Alien Versus Predator) to be obscured. The same content on the Panasonic revealed the dark details the KURO hid."
"The conclusion? The new Panasonic TH-65VX100 is overall the best flat panel tested to date, and should be considered by anyone contemplating a flat screen display in the 60”-65” screen size range."
http://hdguru.com/panasonic-premiere-th ... eview/276/
Bref, il y en a des dizaines de pages de tests comme ca sur le net.
Effectivement, le niveau de détail des noirs délivré par les dalles pana depuis 2007 a toujours été reconnu.
Tant mieux si les nouvelles gammes ont encore réussi à progresser dans cette voie!
