Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 36 invités
Vos réglages pour la gamme Sony W4000
Message » 18 Sep 2009 20:05
Oui c'est pour cela que je réhausse la luminosité et/ou le rétro-éclairage :P .
Cobrasse
Inscription Forum: 17 Aoû 2008 13:02
Message » 21 Sep 2009 9:48
Jour ! :)
Attention, j'ai procédé à un petit correctif dans mon message du 18.09.09. Et devinez ? Eh bien, le résultat est encore meilleur. Si, si, c'est possible. Je n'en crois pas moi-même mes yeux. :o
jedi poodou
Inscription Forum: 23 Fév 2009 12:11
Message » 11 Oct 2009 22:10
Hi, i change my RGB levels in service menu and forget to write original levels.
Who have this tv, please write me your original (from manufacture) RGB levels in service menu. TNX
52W4000
AND how i understand all 52W4000 have different RGB original levels. So what i have to do? :(
Computer i calibrate with colorimeter. What to do with sat, cabel tv?
AGV
Inscription Forum: 11 Oct 2009 22:07
Message » 12 Oct 2009 9:41
AGV a écrit:Hi, i change my RGB levels in service menu and forget to write original levels.
52W4000
There is no way to come back, each panel is unique and calibrated in the factory, you have to note the values before changing them or they're lost.
So you have to calibrate now to have the best picture for you.
stefsamy
Inscription Forum: 24 Juin 2004 19:34
Message » 12 Oct 2009 10:13
how to calibrate for cable TV or satellite?
AGV
Message » 12 Oct 2009 11:17
You have to calibrate for your principal/best source, then for the others only play with the picture option settings in XMB menu.
Because the RGB levels are commune to all sources.
If you calibrate for PC, then after for TV, the calibration for PC will not be good.....
stefsamy
Message » 13 Oct 2009 1:36
I can not calibrate it on cableTV or SAT, if you use calibrator then understand why. For PC, yes, no problem with calibration, but for tv, sat, cabletv...how?
AGV
Message » 23 Déc 2009 9:05
Bonjour à tous,je voudrais avoir vos avis sur mes réglages(surtout des avis de ceux qui ont réglé leur lcd avec une sonde)J'ai un 40w4000 et voici mes réglages.
Rétro:4
Contraste:85
Luminosité:55
Couleur:55
Temp couleur:chaud1
Netteté:15
Tout les filtres désactivés et bien sûr le tout en mode cinéma.
billy
Inscription Forum: 06 Avr 2009 0:19
Message » 23 Déc 2009 18:18
Oui tu es dans les réglages les plus couramment utilisés pour avoir un bon équilibre, le soir pense à baisser le rétro à 2 voir 0 (et éventuellement passé la luminosité à 60 (teste sur des fond blanc puis noir, pour voir ce qui est le mieux entre le rapport rétro/luminosité).
:wink:
Cobrasse
Message » 24 Déc 2009 9:59
luminosité à 60 je dirais plutot 55 mais Rétro:1 voir 2 et tu nous dit pas si tu a mis le capteur de lumière,la encore après plusieurs test......... plutôt oui pour moi dans tout les cas
passer de bonnes fête A+
jason31
Inscription Forum: 30 Nov 2005 2:13
Message » 04 Jan 2010 23:26
Salut tout le monde!
et bonne année ^^
dites moi, il n'y aurai pas quelqu'un qui traine par ici, qui aurait le toto fait pas yoko83 au tout debut du topic en pdf, j'aimerai retoucher ma balance des blanc (trop rouge a mon gout)
mais une fois dans le menu service / balance des blancs / canal 0, je veux baisser la valeur R de 20 pts, mais je n'y arrive pas... si quelqu'un peut m'indiquer la marche a suivre... merci :)
synch2008
Inscription Forum: 03 Jan 2010 11:29
Message » 05 Jan 2010 1:18
Cobrasse
Message » 05 Jan 2010 11:57
Merci beaucoup!
Je ferais mes réglages ce soir, en attendant d'avoir une sonde ^^
synch2008
Message » 06 Jan 2010 23:03
Bonsoir à tous,j'ai une petite question à poser,j'aimerai bien louer ou bien acheter une sonde Mais aurais-je vraiment une plus belle image,est-ce que je verrais une très grande différence avec mon image actuelle?Merci de vos réponses.
billy
Message » 11 Jan 2010 11:37
J'ai commander une sonde, elle devrait arriver d'ici fin de semaine, je m'attaquerai aux reglages avec une platince DVD, et ensuite ferais un profil pour mon pc
Je pense que la difference doit etre visible! mais pas forcement utile pour une personne qui aime les rendu flashy!
synch2008
Retourner vers Ecrans HD
