s.dejardin a écrit:Corrige t il des problèmes de lenteur (allumage, changement de chaine) et de non desactivation de du contraste dynamique ?
Rien d'indiqué dans les logs des modifs concernant la "lenteur"....
Pour le contraste dynamique, cela m'étonne que tu ne saches pas le désactiver car normalement dans les paramètres d'image, tu devrais avoir le choix entre "Aucun/Minimum/Maximum" (ou équivalent).
_____
Firmware
0.26.33.9:
- TV cannot store the channels from cable service provider, Kabel Baden-Wurttemberg.(Only
applicable to country, Germany)
- TV does not display the correct resolution for some PC formats and is forced to the
640x480 resolution.
- While playing a media file in the root directory of the USB memory device, the Program +/-
button does not allowed you to select another media file.
- Unable to enter the network frequency for DVB-C installation.(Only applicable to country,
Netherlands)
- To preset/position analog channels from preset number 2001 onwards after channel
installation.(Only applicable to country, Netherlands)
- Channel disappeared from the original preset position and shifted to a preset number
16384 after installation update.(Only applicable to country, Lithuania, Czech Rep or Italy)
Firmware
0.26.29.6:
- No channels found after auto-installation.(Only applicable to country, Ukraine & Bulgaria)
- Riks TV certification.(Only applicable to country, Norway)
- Intermittent access of electronic user manual with the [Yellow] button on the remote control.
(Only applicable for models with electronic user manual)
- The audio language does not change when you select an audio language from the list of
available broadcasted languages in the TV menu for a digital channel.
- The TV is intermittently blocked when accessing YouTube service.(Only applicable for Net
TV models)
- To include DVB-T MPEG4 feature for country, Slovenia.
- Channel Nederland 2 and Nederland 3 presets are shifted after installation update.(Only
Firmware
0.26.24.8:
- Channels TF1, France2 and M6 have disappeared from the preset list after installation
update.(Only applicable to country, France)
Firmware
0.26.24.4 :
- Initial production software
