Update le 23/09/2009
Voici le test complet.
http://www.projectorreviews.com/benq/w6000/index.php
update le 14 septembre 2009
Test de projectorreview (enfin sur son blog)
http://www.projectorreviews.com/blog/20 ... /#more-479
Les plus:
* facilite de placement
* superbe rendu de la couleur de la peau
* superbe luminosite (vs sony HW15)
-> voir la photo plus bas .. a gauche le sony a droite le benq
* image tres nette ...
Les moins:
* Iris tres visible (la concurrence fait mieux sur ce point)
* un peu bruyant
update le 9 Septembre 2009
w6000 reference chez Benq:
http://www.benq.com/products/Projector/?product=1546#
Info trouve sur AVS
http://www.avsforum.com/avs-vb/showthread.php?t=1127322
Plus de photos ici
http://66.196.80.202/babelfish/translat ... 2009.htm#g
sur une des photos on voit:
Traitement HQV
DB
HDMI1.3
BC
Il ne semble pas avoir le traitement "motion flow" du HD8200 de chez Optoma ...
PHIL12
Benq w6000
Availability - "mid 2009 for 2000 euros (= ~$2500 US // $3200 CAN)"
(I know - technically this should be in the under $3000 forum but since it replaces the w5000 and the price on this is not officially announced it would be appropriate to at least announce this here?)
Across the pond, at CEBIT 2009, seems Benq has announced the w5000's replacement . . . . Obviously limited info so far but the highlights (gleamed from translated German and Italian coverage) include -
1. Instead of white it now comes in black piano lacquer
2. The W6000= 43 x 14.5 x 31.8cm weight of 19lbs
(vs W5000= 49 x 18 x 42cm weight of 21lbs)
3. Listed at 2500 ANSI lumens (vs 1200 for the W5000)
4. Listed at 50 000:1 Contrast ratio (vs 10 000:1 for the w5000)
5. 280 watt lamp (vs 200 watt on w5000)
6. Lamp life is the same 2000 / 3000 if economy
7. States still has vertical and horizontal lens shift (I think the w5000 only had vertical), but one of the german forums mentions its manual, not motorized as on the w5000
8. LOUDER at 34 db (can that be right???) compared to the w5000 at 28db
9. 2 HDMI (1.3 presumably), component, a VGA connection, S-video and Composite.
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: microboss1, tex61 et 167 invités
On voit aussi qu'il va bien casser les oreilles
- locutus2borg
- Inscription Forum: 06 Nov 2006 13:18
La vache !!! 34 dB !!!
2500 Lumens !!!
Ils font ce qu'Optoma avait fait l'année dernière, prendre un produit data en l'aménageant tant bien que mal au HC... C'était une erreur de la part d'Optoma...
2500 Lumens !!!
- allucinéma
- Pro-Divers
- Inscription Forum: 19 Juin 2002 18:15
Boudiou qu'il est laid .
A côté le LG115 est une taupe-modèle .
Xavier.
Xavier.
- tobal
- Inscription Forum: 13 Sep 2001 2:00
allucinéma a écrit:La vache !!! 34 dB !!!
avec ça c'est 15 db
mais bon...le 5.1 en prend un coup aussi !!!
- TONITO
- Inscription Forum: 20 Sep 2004 15:08
A moins de le mettre dans le casque le 5.1
- kbil69
kbil69 a écrit:A moins de le mettre dans le casque le 5.1
haaaaa,j'te jure..ces fabricants...
il manque toujours le centime pour faire l'euro !!!
- TONITO
il faudrait sans doute éditer le titre du sujet, car le taux de contraste annoncé est de 50 000 : 1 (comme d'ailleur celà est déjà mentionné dans le sujet) :
http://www.aboutprojectors.com/news/200 ... focomm-09/
Toutefois, l'annonce la plus importante n'est pas vraiment là , AMHA
- Thebe
- Inscription Forum: 01 Déc 2002 8:04
quelques compléments, dont le prix, soit 2 499 Euros et disponible en septembre.
http://www.big-screen.de/deutsch/pages/ ... handel.php
- Thebe
la feuille des caractéristiques a été mise en ligne sur ProjectorCentral :
http://www.projectorcentral.com/pdf/pro ... c_5037.pdf
- Thebe
houch !!! 2500 Lum.
ç'est pour éclairer un stade ce truc !!!
je trouve déja que mon W5000 a une peche d'enfer sur 2.60m
LE W6000 est surement crée pour ceux qui veulent faire des super base (3m et plus...)
c'est plus du Homeciné, mais ciné tout court !!
(la pièce va couter un pont !!!)
- TONITO
le calculateur de distance a également été mis en ligne sur ProjectorCentral :
http://www.projectorcentral.com/BenQ-W6000.htm
- Thebe
- PHIL12
- Inscription Forum: 28 Juin 2001 2:00
Les plus:
Les moins:
* Mauvaise gestion de l'iris (la concurrence fait mieux sur ce point)
Les plus:
Les moins:
- PHIL12
ben il est en ligne en definitif sur projector central :
http://www.projectorcentral.com/benq_w6 ... review.htm
Babelfish translation :
http://66.196.80.202/babelfish/translat ... review.htm
- Thebe
