Type : Ampli HC
Marque : YAMAHA
Modèle et options : RX-V1500 Titane
Prix de vente : VENDU
Département où la marchandise est visible : 31 TOULOUSE
Montant des frais d'expédition : UPS environ 40€
État de la marchandise : Impeccable...aucune rayure!
Première main : NON
Prix neuf : ???
Date et lieu d'achat : Il doit dater de 2005...
Description générale : Désolé c'est en anglais...mais bon il lui manque rien sauf le décodage HD...mais comme il possède des entrées 5.1 analogiques
MAIN FEATURES
Featuring 7-channel discrete amplification (120W x 7), Yamaha’s Digital ToP-ART design concept, YPAO (Yamaha Parametric Room Acoustic Optimizer), Quad-Field CINEMA DSP, 16 surround programs, full movie sound format compatibility as well as THX Select processing, SILENT CINEMA, Night Listening Mode, 9 channel speaker outputs with Zone2 out, and component video up conversion for optimum video quality.
Features for convenient operation include extensive menus, front panel video Aux optical input terminal and a direct access remote control. This high-performance receiver also provides a variety of features for setting up a multi-room custom installation.
Other Features
Accurate Touch Volume Control
192 kHz/24-Bit DACs for All Channels Analog Mixdown
2-Channel Stereo Mode and Straight/Effect Switch
High Dynamic Power and Linear Damping
Digital Tone Controls for Front L/R, Center, Presence and Subwoofer
Wide-Range Audio Frequency Response for DVD-Audio/SA-CD Compatibility
9-Channel Speaker Outputs with Zone 2/Presence Speaker Outputs
Dialogue Lift for Enhanced Dialogue Sound
Selectable 9-Band Subwoofer Crossover
Speaker A, B or A+B Selection (Front L/R)
Wide-Range Video Bandwidth (60MHz -3 dB)
Night Listening Enhancer ensures that all programs (including Dolby Pro Logic IIx)
Direct-Access (Macro-Command, Learning and Preset Capable) Remote Control Unit with Macro-Command Buttons
Site web du constructeur : http://www.yamaha.com/yec/products/prod ... UCT&LGFL=Y
Utilisez la fonction "recherche" de votre forum
6 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Davidhoch, ManuDM et 7 invités
C'est du rapide ici.
Très bon vendeur avec du materiel toujours impeccable .
HC: JBL Pro, JVC NZ7, Marantz 7706, Zidoo Z1000pro, Pana UB9000
HIFI: JBL Array 1400, Marantz PM14S1 SE
Tochiro - Modérateur Home-Cinéma
- Inscription Forum: 21 Nov 2004 18:47
VENDU AU PLUS RAPIDE
- wincoach
- Inscription Forum: 10 Avr 2002 2:00
6 messages
