Marque : Arcam
Modèle et options : AVR200 NOIR
Département où la marchandise est visible : 49
Possibilité d'expédition : Oui, par colissimo
Etat de la marchandise : Neuf
Première main : Non
Prix neuf : €1300 euros
Prix : €450 euros -> €400
![:o](https://www.homecinema-fr.com/forum/images/smilies/icon_eek.gif)
Facture conservée : Non
Date et lieu d'achat : Un copain il y'a 1an et demi
Documentation conservée : Oui
Description et commentaires :
Suite à retour vers HK, je revends mon Arcam.
Il est comme neuf avec documentation.
AVR200 RECEIVER - DESIGN DETAILS
* 5 x 70 wpc (all channels driven into 8 ohms)
* 2 x 90 wpc (both channels driven, stereo mode)
* Massive toroidal power transformer
* Dolby Digital and DTS decoding
* Dolby Pro Logic II decoding
* 5 x digital inputs (3 x co-axial and 2 x optical)
* 1 x digital output (co-axial)
* High quality video switching from both composite and S-Video sources
* FM and AM tuner with 40 presets and RDS
* External 5.1 multi-channel input for DVD-Audio or SACD players
* Pre-amp outputs for all channels - L, C, R suitable for bi-amplification with Arcam P85 or P85/3 power amplifiers
* Full remote control and on-screen displays
* Remote control input jacks for friendly custom install
* Full menu-driven bass management
TECHNICAL SPECIFICATIONS
AVR 200 RECEIVER
AMPLIFIER SPECIFICATION
Output power (20Hz-20kHz at 0.5%THD)
8 Ohms, five channels 70W
8 Ohms, two channels 90W
8 Ohms, single channel 100W
Harmonic distortion, 1W, 8 Ohms at 1kHz 0.02% typical
Left/Right crosstalk >60dB at 1kHz
Frequency response +/-1.0dB 20Hz to 20kHz
Inputs
Sensitivity 200mV
Input impedance 10k Ohms
Overload margin 20dB
Power amplifier input sensitivity 740mV (normal gain)
Outputs
Preamplifier
Nominal output level 200mV
Maximum output level 3V
Headphones
Output impedance 390 Ohms
Physical
Size W/D/H mm. inc. feet 430x450x150
Weight net 11.9kg
Weight packed 14.1kg
Mains voltage 230V +/-12%
120V +/-12%
Power consumption (maximum) 500VA
RADIO SPECIFICATIONS
FM section
30 preset stations available
RDS Station Identification, Radio Data Display
FM tuning range 87.5 to 108MHz
FM sensitivity <6uV
THD
Mono <0.25%
Stereo <0.35%
Signal to noise ratio
Mono >72dB
Stereo >66dB
Pilot tone suppression >60dB
Alternate channel selectivity IHF >60dB
Capture ratio <3dB
AM section
10 preset stations available
AM tuning range
10kHz step 530 to 1710kHz
9kHz step 531 to 1602kHz
Usable sensitivity <30uV
IF rejection >36dB
Signal to noise ratio, 5mV input >38dB
THD, 5mV input <3%
![Image](http://www.arcam.co.uk/archive/diva/images/avr100.jpg)
