Type : Intégré HC
Marque : Arcam
Modèle et options : AVR200 NOIR
Département où la marchandise est visible : 49
Possibilité d'expédition : Oui, par colissimo
Etat de la marchandise : Neuf
Première main : Non
Prix neuf : €1300 euros
Prix : €450 euros -> €400
Facture conservée : Non
Date et lieu d'achat : Un copain il y'a 1an et demi
Documentation conservée : Oui
Description et commentaires :
Suite à retour vers HK, je revends mon Arcam.
Il est comme neuf avec documentation.
AVR200 RECEIVER - DESIGN DETAILS
* 5 x 70 wpc (all channels driven into 8 ohms)
* 2 x 90 wpc (both channels driven, stereo mode)
* Massive toroidal power transformer
* Dolby Digital and DTS decoding
* Dolby Pro Logic II decoding
* 5 x digital inputs (3 x co-axial and 2 x optical)
* 1 x digital output (co-axial)
* High quality video switching from both composite and S-Video sources
* FM and AM tuner with 40 presets and RDS
* External 5.1 multi-channel input for DVD-Audio or SACD players
* Pre-amp outputs for all channels - L, C, R suitable for bi-amplification with Arcam P85 or P85/3 power amplifiers
* Full remote control and on-screen displays
* Remote control input jacks for friendly custom install
* Full menu-driven bass management
TECHNICAL SPECIFICATIONS
AVR 200 RECEIVER
AMPLIFIER SPECIFICATION
Output power (20Hz-20kHz at 0.5%THD)
8 Ohms, five channels 70W
8 Ohms, two channels 90W
8 Ohms, single channel 100W
Harmonic distortion, 1W, 8 Ohms at 1kHz 0.02% typical
Left/Right crosstalk >60dB at 1kHz
Frequency response +/-1.0dB 20Hz to 20kHz
Inputs
Sensitivity 200mV
Input impedance 10k Ohms
Overload margin 20dB
Power amplifier input sensitivity 740mV (normal gain)
Outputs
Preamplifier
Nominal output level 200mV
Maximum output level 3V
Headphones
Output impedance 390 Ohms
Physical
Size W/D/H mm. inc. feet 430x450x150
Weight net 11.9kg
Weight packed 14.1kg
Mains voltage 230V +/-12%
120V +/-12%
Power consumption (maximum) 500VA
RADIO SPECIFICATIONS
FM section
30 preset stations available
RDS Station Identification, Radio Data Display
FM tuning range 87.5 to 108MHz
FM sensitivity <6uV
THD
Mono <0.25%
Stereo <0.35%
Signal to noise ratio
Mono >72dB
Stereo >66dB
Pilot tone suppression >60dB
Alternate channel selectivity IHF >60dB
Capture ratio <3dB
AM section
10 preset stations available
AM tuning range
10kHz step 530 to 1710kHz
9kHz step 531 to 1602kHz
Usable sensitivity <30uV
IF rejection >36dB
Signal to noise ratio, 5mV input >38dB
THD, 5mV input <3%
36 messages • Accèder à une page • 1, 2, 3
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 14 invités
A défaut de facture (si ton copain ne l'a pas conservée), la lettre de cession s'impose : http://laurent2001.free.fr/lettre_cession.pdf
Adhérez à l'association pour que le site progresse : http://www.homecinema-fr.com/asso.php/
- frahlt
- Membre d'Honneur
- Inscription Forum: 05 Mai 2006 4:29
logique et lettre de cession sera fourni merci
- Nt016
- Inscription Forum: 28 Sep 2005 7:56
Très bon intégré avec entrées 5.1 analogique pour profiter des nouveaux formats son et sorties pre-out pour s'en servir comme excellent préampli.
En plus il est superbe en noir et son prix est très doux ... vous pouvez foncez !!! (moi je peut pas)
- AlexScan
- Inscription Forum: 27 Déc 2005 20:57
sherwood 963
les différences par rapport à un sherwood 963?
- pierrotlune
- Inscription Forum: 28 Sep 2007 18:20
Je peux dire uniquement mon ressenti personnel...
Les Sherwood sont, je trouve, dans une gamme plutot Yamaha - c'est à dire vraiment sans plus niveau musique. L'Arcam reste pour moi le meilleur equilibre HIFI/HC disponible car ils utilisent les mêmes composants que leurs amplis stereo et puis ils ont une grande expérience dans ce domaine. Niveau cinéma je trouve l'Arcam très très fort dans le rendu des détails et la précision du son.
Il faut dire aussi que niveau WAF (esthétique) - l'Arcam gagne direct - le Sherwood étant assez moche
Les amplis Arcam gardent bien leur valeur grace à leur réputation et à leur qualité sonore et qualité de finition. (voir la note de AlexScan!)
L'ampli et télécomande sont en état parfait. (Ca va me manquer de pouvoir contrôler mon CD72 avec les mêmes télécommandes!)
- Nt016
Je confirme arcam c'est du très très bon
bonne vente
bonne vente
- crocket51
- Inscription Forum: 04 Mar 2003 14:30
Modéré par Bobim
Si pas de respect vis à vis de chaque, il y aura des cartons jaunes de distribués !
A bon entendeur ...
A bon entendeur ...
- BradPitt
- Inscription Forum: 15 Déc 2005 18:23
modéré par Bobim
- seb62espace2
- Inscription Forum: 06 Fév 2007 17:21
Surtout que notre ami crocket =51 a été écouté du arcam chez elecson recement et c'est pour cette raison qu'il se permet de dire que c'est un bon ampli.
Quand a ton ampli brad c'était pour t'aider dans ta vente.
Sur ce bonne vente a toi Nt016 et désolé pour le HS.
Cdlt
Cdlt
- seb62espace2
BradPitt a écrit:seb62espace2 a écrit:Tu peut préciser tes dires.......Je vois pas de quoi tu parles?
Mais, en quoi est-ce que ça te concerne ??? Tu réponds à sa place, tu la lui tiens aussi ?
Non mais c'est un pote!!
Je n'irais pas plus loin car je veut pas pourrir ce post.
A bon entendeur salut!
- seb62espace2
je confirme arcam c'est du très très bon...!!
- magieverte
- Inscription Forum: 04 Aoû 2006 10:02
BradPitt - tu peux defendre ton ampli mais je ne réagirai pas à des gamineries. J'ai donné MON AVIS personnel et cela n'engage que MOI. Bonne vente a toi!
- Nt016
Bonsoir
Je déteste particulièrement de voir polluer une pa.
Si le trollage continue, je distribuerais personnellement le ou les cartons jaunes !
Merci de ne plus polluer la vente de NT016. Vous règlez vos comptes ailleurs !
Cdlt
Bobim
Staff PA
Cdlt
Bobim
Staff PA
bobim - Membre HCFR
36 messages
• Page 1 sur 3 • 1, 2, 3
