La version ES en lecteur blueray à venir.
http://presscentre.sony.eu/imagelibrary ... ilsID=9410" onclick="window.open(this.href);return false;
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 45 invités
Lecteurs Blu-Ray
[BD_2D] Sony BDP-S5000ES
- audiophi
- Inscription Forum: 30 Oct 2004 16:45
Ah, enfin! Depuis le temps qu'on l'attendait... Superbe!
- bandicootfr
- Inscription Forum: 28 Déc 2000 2:00
Il a l'air sympa sur la papier !
- deuch
- Inscription Forum: 08 Mai 2000 2:00
BDP-S5000ES: The world's most advanced Blu-ray Disc Player, for customers who require absolute perfection in home cinema
Blu-ray Disc has revolutionised the home cinema experience, bringing huge increases in video and audio quality, and features designed to further enhance viewers' engagement with the movie they are watching. Although the quality of the complementary products of the range, BDP-S350 and BDP-S550, make them perfectly capable of delivering the full HD experience, the new BDP-S5000ES Blu-ray Disc Player is designed to take that audio and video experience to the limit.
Sony has put all its expertise in video and audio processing into the BDP-S5000ES, making it the best player yet. The combination of the HD Reality Enhancer and Super Bit Mapping takes the picture quality way beyond what has previously been available from Bu-ray Disc, ensuring a stunning image whether you use a BRAVIA™ LCD TV or a home cinema projector from Sony.
The HD Reality Enhancer continually analyses the image coming from the disc, sharpening edges while not over-emphasising other elements of the picture, reducing the effect of grain on the original filmstock, and increasing the colour depth from the 8 bits on the disc to the equivalent of 14 bits. Meanwhile Super Bit Mapping, which uses unique processing based on human visual sensitivity, enables the player to deliver the best possible quality over HDMI™, with smoother colour tones.
To match all the video capability, the BDP-S5000ES has been designed to sound better than any other Blu-ray Disc Player. It uses a high-stability Precision Drive HD transport mechanism in the center position, an ultra-rigid Frame and Beam chassis to reduce vibration and a low-leakage R-Core transformer.
The analogue audio board is isolated from the video and servo sections to avoid interference, and the player offers Linear PCM and HD audio decoding with bitstream output, and 7.1-channel analogue outputs. It will handle all formats up to Dolby TrueHD and DTS-HD Master Audio, either decoded internally or output as bitstream.
It will also upscale your existing DVDs to 1080p using Sony's Precision Cinema HD Upscale, and even the analogue component video output is superior, thanks to the use of 14-bit/ 297 MHz Video D/A conversion.
To make the most of the extra features becoming available on Blu-ray Disc releases, the S5000ES is compatible with BD-Live and BonusView, This enables it to access exciting online services and extra content, such as commentaries and special features, which can be downloaded from the Internet and saved on the included 1GB USB flash storage device.
In addition that Internet connection, via the player's Ethernet port, will allow future firmware enhancements, ensuring the player to be kept up to date with any developments in features or funtionality.
- boonjik
Disponible en décembre pour 1500€.
- boonjik
rahhh lovely , et dans les meilleures chaumières pour 1500$
- Talon Karrde
- Inscription Forum: 13 Fév 2000 2:00
lgm3 a écrit:es veut dire ?
Elevated standard.
C'est une réponse qu'on peut facilement obtenir avec Google + "Sony ES".
- quidam
- Inscription Forum: 02 Aoû 2005 17:18
Costaud .. le prix et les dimensions ...
Je ne suis pas sûr que la difference de prix par rapport à un S550 soit justifié en jugeant l'image
Déja entre un BDP S1 et un PS3 le journalistes étaient incapables de voir la difference alors ...
J'ai pourtant eu par le passé des appareils Sony de la série ES ...
- flash41
- Inscription Forum: 01 Juil 2004 9:29
On va attendre qu'elle sorte et soir testée avant de la flinguer
Les différences peuvent être visibles si il y a des filtres NR ou autres que l'on peut régler. Enfin à vérifier
- deuch
deuch a écrit:On va attendre qu'elle sorte et soir testée avant de la flinguer
oui bien sûr
mais les filtres sont toujours désactivés chez moi que ce soit au niveau du lecteur DVD ou du plasma ...
- flash41
miam miam elle suporte aussi le SACD et là............................................. je pense qu'il n'y a pas foule en lecteur blu ray
PROJO: Sony vpl vw 300/ AMPLIS Yamaha CX-A5100/AMPLIS DE PUISSENCES Anthem A5 et PVA7 LECTEUR BLU RAY: Sony BDP 7200 - UBP-X800 / CAISSON: SVS SB 4000/ ENCEINTES: Triangle Quatuor et BW CTL5 5 (surround) salle en 11.1
- STAR WARS
- Inscription Forum: 16 Aoû 2006 9:02
wow bonne nouvelle, enfin une platine Blu Ray et SACD ! vivement les test !!
- digit@ll
- Inscription Forum: 16 Sep 2007 12:00
Elle n'est pas du tout SACD, vous avez confondu avec la SCD-XA5400ES qui lui ressemble et qui est un lecteur SACD.
Cette platine Blu-ray ne lit pas les SACD ... Enfin du moins d'après les premières specs ou alors j'ai mal lu
- deuch
bah oui on s'est enflamés effectivement, à priori elle ne les lis pas
- digit@ll
Retourner vers Lecteurs Blu-Ray
