opbilbo a écrit:leeperry a écrit:l'histoire ne le dit pas
mais bon dans les mesures ANSI, le HD1 est un peu a la rue
Ont-ils oublié d'éteindre le lumière dans la salle de projection ?![]()
![:lol:](https://www.homecinema-fr.com/forum/images/smilies/icon_lol.gif)
Michel
Modérateurs: Modération Forum Installations, Modération Forum Univers TV, Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 2 invités
It seems we have a similar dilemma...which projector to upgrade to next.
I also find the optics on the 3100 a bit lacking near the edges, but I still haven't found an affordable projector with the same 'pop' and color accuracy as the 3100.
A friend of mine got the JVC RS2 recently, and I tried it out on my screen (only 70" wide). It reminded me of the 3100 but with better dark detail and more resolution.
Not a night and day difference, but the fact that there are no rainbows on an LCOS display helps me as I'm susceptible to that.
I am not a fan of Sony's SXRD projectors, so you may know where I'm coming from.
On the RS2, I didn't see any of the softness, light bleed, or washy colors I usually see with LCOS.
The friend with the RS2 is getting a 2.35 screen from Stewart that is at least 110" diagonal, and the panamorphic lens, so I'll see how that goes.
The RS2 by itself it way outside my price range, but I may bite the bullet once it gets down to ~4k.
I'd say it's worth that much compared to the HC3100.
If you've seen the RS2, I'd like to hear your thoughts. Thanks.
treza a écrit:Un article intéressant sur le contraste : http://www.hometheaterhifi.com/volume_1 ... art-1.html
treza a écrit:Y at-il un moyen simple de connaitre le gain de sa pièce ?
MLill a écrit:Avec une Eye One Display je doute que tu mesures les murs à 80cm de l'écran.
Elle a un angle très fermé.
moudugnou a écrit:je fais un HS car ça fait un moment que je n'ai plus beaucoup lu sur le forum.. et après avoir fait un tour au niveau des projos, des écrans et de la hd.. je trouve qu'on est bien tranquille ici.. ça discute, ça échange, le tout de manière constructive.. bref, un forum quoi
