Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: BA, fast freddy et 42 invités
[Nouveauté] DLP FULL HD MITSUBISHI : HC 3700
Merci je lui pose la question car perso le Benq w5000 que je voulais acheté, je le trouve pas bien du tout, si le Mitsu est une copie directe, il faut fuir
- Sonic69
- Inscription Forum: 30 Oct 2002 23:12
traduit du Chinois
Mitsubishi MITSUBISHI HC3700 the most economical full HD projector released quiet domestic listing 2007 12:24 December 6, 2007 at 12:24 Thursday Recently, Mitsubishi Electric held a grand rally in Guangzhou in 2007 called "the acclaimed new Mitsubishi 1080 P full HD home theater projector" conference. 1080P HC6050,1080P HC3700,FULL HD! The conference not only issued a 1080 P industry has always been concerned about the whole high-definition home theater projector HC6050, but also announced a DLP projection of the 1080 P-HC3700 home, both domestic FULL HD projector marks Mitsubishi HD projector products formal home landing the domestic market!
Mitsubishi HC3700
HC3700 Both in the home projector, the introduction of pre-HC3700 relatively silent. Today, we are first and we appreciate this projector with the customs.
HC3700 10000∶1 1080p using DLP technology, with 10,000 high-contrast 1080 p full HD projector, the user can provide a better product choices 1080 p entry Mitsubishi HC3700 sets in a lot of advantages. Silicon OptixReon-VX In the video processing applied the Silicon Optix's 10 Reon-VX processor can bring "Hollywood quality" image quality.
HC3700 Adopted the 10 image processing in I / P (Interlaced / Progressive) conversion and precise. Even in dealing with the video - the film mixed sources, it also can detect specific material to fast speed and accuracy to deal with them. This will ensure that the re-appeared gradually higher quality video. For terrestrial digital television or satellite broadcasting digital movies. "2-3Pull-donw (Film mode)" function can eliminate most of jagged, showing a perfect image. The projector also supports high-precision 3-D deal with a new generation of optical discs and 24 P.
Reon-VX next generation of high-performance processor
Silicon OpticsREALTA,HQVTM“high-performance chips are based on Silicon Optics launched the popular REALTA, HQVTM it to be called "Hollywood quality image" superior visual performance and famous. HC3700 projector as the core, it can be excellent on the screen showed exquisite images.
24 P software compatible with the Blu-ray direct output
HC3700 directly compatible with the Blu-ray next-generation optical disc 24 P, will provide two times the film (24 frames / sec) 48 P output, double-speed, fluency, as well as detailed texture, lifelike. In addition, the built-in dual HDMI1.2 Mitsubishi HC3700 terminal, the user-art digital connectivity. PS3、 HD port connections support, allows users to easily connect a variety of devices, including Blu-ray Disc player, PS3, home theater systems and other support HDMI-CEC of audio-visual products. The built-in electrical products, as well as zoom lens shift function allows home users even in the small space can be no obstacle to the installation of the full enjoyment of the big-screen fun.
Mitsubishi HC3700 through advanced noise reduction technology, this product will be in the noise control only 19 db, is the world's most quiet of the family projector.
Summary: It is understood that the HC3700 compared HC6050 to some cheaper prices, is a domestic economic HD projector. Mitsubishi projector before the home has not been officially listed in the domestic, the HC3700 the grand listing will greatly stimulate the domestic market fiery. HC3700 listed price is not yet determined, but the author estimated the price of this projector may be less than 30,000.
Alain
Mitsubishi HC3700
Alain
- ALBO
- Inscription Forum: 04 Mar 2001 2:00
Mitsubishi HC6050... peut-être la version D7 du HC 6000... ça peut être terrible s'il ne sort pas à 4000 euros mais a 3500 voir 2990... a voir au ces pour plus de détail (peut-être).
- nicopaco
- Inscription Forum: 13 Fév 2002 2:00
personne a plus d'infos sur ces histoires de roue 6X ?
ca doit etre immonde en 360 Hz ?
leeperry a écrit:sur le HC3100 la roue est en 4X, et possible de passer en 5X......mais y'a pas mal de couleurs qui passent a la trappe et ca cree des zones clignotantes....bref c'est laid
alors quand je vois que les Optoma HD8x et ce BenQ sont en 5X, et possible de passer en 6X
C4H a aborde le sujet ici :
http://www.cine4home.de/knowhow/DLP-Far ... raeder.htm
- leeperry
- Inscription Forum: 06 Jan 2007 19:44
leeperry a écrit:personne a plus d'infos sur ces histoires de roue 6X ?
Lu sur le topic du W5000 sur AVS
The color wheel change from 2 to 3x (2x,2.5x,3x).
Certainement 4, 5 et 6x
Il serait moins bruyant en 4x mais la vitesse ne serait pas toujours sélectionnable car associée à certains modes
Alain
- ALBO
ok mais ce que je veux dire c'est que deja le 5X est laid par rapport au 4X.
ca fait des zones ou les couleurs disparaissent, enfin c'est vraiment vilain...comme C4H le souligne >300Hz.
ca me faisait pareil qd je forcais le 85Hz sur le HC910.....85x4=360Hz car le HC910 accelere la roue par rapport au taux de rafraichissement(pas le cas des 1100/3100)
ca donne une image avec des gros paves clignotants........donc j'ai du mal a comprendre pourquoi ces DLP fullHD ne proposent pas le bon vieux 4X......sauf si y'a un truc qui m'echappe
- leeperry
Leeperry , il t'arrive plein de choses bizarres avec tes projos
azzaro - Messages: 3021
- Inscription Forum: 23 Mar 2002 2:00
ca doit etre ca
le HC910 a la roue qui augmente selon le rafraichissement, c'est clairement audible
et un pote a pareil avec un DELL data.
je preferais meme le bruit a 72Hz qu'a 60.......mais comme d'hab l'image judderise mechamment qd on est pas en 60 :p
et sur le HC3100 en 5X y'a des couleurs qui passent la trappe par rapport au 4X, clairement visible dans les travellings et C4H confirme la meme chose
- leeperry
lol tu vois aucune diff en 4X et 5X sur ton 3100 ?
sur Kill Bill en HD si tu l'as, la scene ou Black Mamba est en moto.....ca saute aux yeux la diff dans les travellings.
et ton 48Hz hyper fluide, c'est en 5X ?
- leeperry
Je n'ai pas ce film , mais en 48hz X4 ou X5 tout est parfaitement fluide , les couleurs sont parfaites , calibrage sonde a l'appuis , j'ai même fait une demo a deux posseseurs de JVC HD1 et HD100 particulierement sensible aux aecs d'ou l'utilisation du mode X5 , ils ont été enchantés tous les deux du résultat restitué par ce petit vp.
bah vi je sais bien que le 3100 marche bien, tu preches un converti
j'ai pas dit que c'etait moins fluide en 5X, j'ai dit que certaines nuances de couleurs passaient a la trappe...ce que C4H confirme sur le lien que j'ai donne.
la roue va trop vite pour pouvoir offrir autant de nuances qu'en 4X.
mais qd je changerai dans une paire d'annees, j'aimerais bien avoir un projo 1080 en 4X et non 6X
et pour les histoires de sondes, sans vouloir enfoncer des portes ouvertes, j'ai discute de la sonde HCFR avec un programmeur de logiciel de colorimetrie(ARGYLL), et il trouve aberrant l'idee que la calibration de la sonde soit faite avec un fichier etalon.
donc si t'as l'opportunite un jour, calibre avec une sonde commerciale
copie de son mail :
donc lui il a tente de creer un etalon "universel" et n'utilise pas de fichier THC....je n'ai plus de sonde HCFR pour tester avec son logiciel par contre
et un membre du forum qui fait partie de la mailing list a repondu :
j'en discute en ce moment avec Michel, mais j'ai aussi remarque que les couleurs etaient bcp plus naturelles avec la spyder2(j'attends une eye one d'ici 2 jours) qu'avec les etalons du 3100...
...l'idee qu'un etalon par modele de projo puisse convenir a tous semble plus qu'utopique
copie de son mail :
I can't say I really understand what the HCFR folks are doing with their reference files. It doesn't make any sense to me that they can "calibrate" an instrument
without an independent reference of some sort. So what I've done with my driver is to hard code a reference of the particular HCFR I have into the software. The reference was created by calibrating against
an X-Rite DTP94 on two particular displays. The validity of this calibration depends greatly on the uniformity of manufacture of the optical sensor,
and the similarity of the spectral characteristics of the displays to what is actually being measured. Without some sort of manufacturers factory calibration for each HCFR instrument, I don't see what else can be done for it.
As far as I understand, the reference file is in fact the primaries of a given beamer. I think they are hoping that primaries does not vary too
much from a beamer to another, so they calibrate the HCFR colorimeter that way.
If it is the case, I agree it is not very smart, as there *are* differences from beamer to other, and the screen also has to be taken into account... So, Graeme's method is better. I'll maybe suggest them
to use it!
- leeperry
Quoiqu'il en soit , le resultat que me donne la calibration avec la sonde hcfr , même si il n'est pas parfait , est tous simplement extra , les films hdvd et br en natif sont restitués avec brio , pour moi aucun intérêt d'aller plus loin dans une recheche ultilme et hypothétique d'un résultat encore meilleur.
Dans cette démarche je te souhaite bonne chance
bein le resultat "encore meilleur" je l'ai deja avec la s2+ARGYLL
la eye one c'est pour le sport
mais bon le successeur de mon HC3100 sera dur a trouver je crois, si meme Mitsu se met a nous refourguer des BenQ
- leeperry
leeperry a écrit:bein le resultat "encore meilleur" je l'ai deja avec la s2+ARGYLL
Le précédent OEM avec Optoma c'était révélé désastreux, cf. un HC 2000 de triste mémoire.
- worf
- Broker
- Inscription Forum: 25 Juin 2002 16:37
