@ Munch 14 !!!Felicitation !!!
Sur le site de Philips UK a la page support du 42PFL9900D/10 a l'adresse suivante :
http://www.p4c.philips.com/cgi-bin/dcbi ... GB&slg=en#
Il est indiqué les types de fichiers lisible par l'entrée USB (sous reserve!) pourrait-tu faire quelques essais et nous confier les résultats s.v.p.?
42PFL9900D/10 Internet & media transfer
Supported file type extensions (.jpg, .jpeg, .mp3, .wav, .aif, .aiff, .mpg, .mpeg, .vob, .mp4, .avi, .divx, .xvid, .alb, .m3u and .pls.)
The access and response time of the content on a device can differ depending on the type or brand of the device.
The access and response time of the content on a device will decrease the more unsupported or corrupted files are on the device.
The maximum size of any multimedia file should never exceed 4Gbyte.
Never use a “.” In a folder (directory) name.
If video streams are supporting multiple audio tracks the first audio track will automatically be selected, the other audio tracks can’t be selected.
Subtitles (e.g. DivX .srt subtitle files) are not supported.
Can I use a portable hard disc as source for my TV?
- Answer
Only if the portable hard disc is recognizable as a USB Mass Storage Device it can be used on the TV.
Connect it with a USB-connection-cable.
D'avance merci.
