Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: epb01, gegeflipp75, LE PIRATE, Lobito94, reidemeister philippe, SuperSonic61 et 140 invités
ONKYO RECEIVER PRÊT POUR HD....ET PAS CHER!
Message » 15 Juil 2007 6:47
:D j'ai trouvé:
DTC-9.8
THX Ultra2, 7.1-Channel 3-Zone Preamplifier/Processor
S/N Ratio (LINE IN) 110dB
All Discrete Circuitry
Absolute Ground Plate
Toroidal Transformer
Independent Power Supply 4
Optimum Gain Volume -
Linear Optimum Gain Volume
PROCESSING:
DOLBY Decoder DD Plus, TrueHD
DTS Decoder DTS-HD Master Audio
Neural Surround Neural THX
THX Processing Mode
DSD Processing/Direct Mode /
Direct
192K/24 Bit DACs Burr Brown
VLSC (ALL CH)
DSP Type / QTY 32 BIT / 3
Adjustable Crossover (Hz) 40/45/50/55/60/70/80/90/100/110/120/130/150/200
Adjustable Crossover by Channel Pair
Accurate Speaker Distance Setting 0.2ft step
AV Sync Delay (by source) 250ms
Multi-Band Speaker EQ 15 Band
CONNECTIVITY:
Audio I/O 9 / 2
Balanced Audio Output (7.1ch)
Balanced Audio Input (2ch, assignable)
Phono Input
Digital Audio IN (OPT/COAX) 3 / 3
Digital Audio OUT (OPT/COAX) 1 / 0
Composite I/O 6 / 1
S-Video I/O 6 / 1
Front-Panel A/V
Front-Panel Optical
Component Video / Bandwidth 3 / 100MHz
HDMI I/O 4 / 2
HDMI Version V1.3a Repeater
HDMI Bandwidth 1080p
HDMI Deep Color Capable (36bit)
Component Video Upconversion
Analog to HDMI Upconversion
480i to 480p Processing HQV
1080p Upscaling HQV
Noise Shaped Video (NSV)
Multi-Channel Input 7.1
Pre-Outs 7.1
Powered Zone2 N/A
Zone 2 Fixed/Variable line Out
Zone 2 Fixed/Variable Subwoofer Out
Zone 2 Tone/Balance Control
Zone 2 Max/Power On Volume
Zone 2 Composite Video Out
Zone 2 HD Component Video Out
Zone 3 Fixed/Variable line Out
Zone 3 Max/Power On Volume
Zone 3 Fixed/Variable Subwoofer Out
HDMI / Component video assignable to Tape/CD/Phono
iPod Ready (DS-A2)
Radio Data System (RDS)
Internet Radio Capability via Ether (PlaysForSure) -
Streaming Audio From PC via Ethernet (PlaysForSure) -
Streaming Audio From USB memory (PlaysForSure) -
Built-in HD Radio Tuner
XM Radio Ready
SIRIUS Radio Ready
Sat Radio Accessibility Both
Simultaneous Access to Multiple Tuner Bands (Z1, Z2, Z3)
INTEGRATION ACCESS:
RS-232
IR Input/Output 2/1
Ethernet (E-control, AMX Duet)
RIHD (Remote Interactive over HDMI)
RI System Control
12V Trigger (w/adjustable delay) Assignable (x3)
MISC.
Pre-Pro/Learning Remote /
Back-Lit Remote
Color-Coded Speaker Terminals N/A
Auto Speaker Calibration w/ Mic. Audyssey MultEQ XT
GUI for Setup Menu (advanced)
Input Name Edit
Setup Store/Recall function
Permanent Memory Storage
Solid Aluminum Front
Detachable AC Cord
Rack Mount Kit Available IRK-175-4
Warranty 3 YEARS
alfachris
Inscription Forum: 12 Aoû 2003 21:36
Message » 15 Juil 2007 6:51
:D Allez, puisque j'y suis, une petite photo de l'arriére, et surtout le prix: 231000 YENS, soit à peu prés 1400euros :o :o
Le produit rêvé, je vais brûler un cierge tous les jours en attendant son importation :roll:
alfachris
Message » 15 Juil 2007 6:58
:D ...existe aussi sous la référence Onkyo Pro PR-SC885P:
alfachris
Message » 15 Juil 2007 8:38
enfin un constructeur qui sort un super préampli HC abordable.
XLR, HDMI, nouveau décodage,
Attendons les premiers Banc d'essai.
Mais visiblement, les concurrents ont du souci à se faire.
philou9178
Inscription Forum: 24 Nov 2006 12:59
Localisation: Essonne 91- Squatteur épisodique Paris Stade Jean Bouin et Saint Denis Stade de France
Message » 15 Juil 2007 9:20
sdif18 a écrit:je me suis renseigné sur un site pour le sr605 et apparamment il y a plus de reservation que de produits, onkyo est submerger de commande, si je commande un sr 605 aujourd'hui, je ne l'aurais que fin aout, debut septembre d'apres le site.
apparemment pour le 605 il y aurait 50 silver et 50 black pour la france(d'apres l'importateur :( )
tony16
Inscription Forum: 03 Nov 2005 14:51
Message » 15 Juil 2007 10:38
alfachris a écrit:
DTC-9.8
Cette version "integra" est réservée au marché japonais il me semble... 8)
ironfred
Inscription Forum: 30 Sep 2005 16:11
Message » 15 Juil 2007 12:02
ironfred a écrit:
alfachris a écrit:
DTC-9.8
S'il a du succès au japon,
il sera exporté en Europe et en Amérique du Nord.
philou9178
Message » 15 Juil 2007 13:50
Hello,
J'ai quelques question sur ces ampli, je pense partire pour le 875 mais quelques points restent flou pour moi par rapport au 805.
- Premièrement, avec tout les ampli A/V, onkyo et autre. On branche toutes nos sources sur l'ampli et on resort avec un seul cable (HDMI) sur le diffuseur. Mais cela pose un problème car du coup il est impossible d'avoir des réglage différent au niveau du diffuser pour chaque sources.. et donc on perd en qualité. Savez-vous si il existe des ecran qui on la possiblité d'avoir des réglage pré-enregistré que l'on peut appliquer pour la même source ???
Vous me direz qu'il est passible de brancher que l'audio sur l'ampli et la video direct sur le diffuseur. Mais avec le HDMI 1.3 (ps3 par ex) cela n'est plus possible..
- Pensez-vous que le scaler du 875 vaut vraiment la peine ?
Je m'explique, il est vrai que la majorité des source sont toujours en SD, mais pour les DVD la plus part des lecteur actuel font deja du scaling. La seule source qui reste en SD c est la TV (TNT, cable ou sat) et dans se cas je pense que le 875 peut etre interessant !
Mais, savez vous si les écran nouvelle génération (pio G8, pana PZ700, philips) qui coute quand meme très cher. N'ont pas eux aussi des puces aussi bonne voir mieux que le Onkyo 875 ??
Dans se cas autant utiliser le scaler de la TV
Voila merci a vous :D
lucasP
Inscription Forum: 02 Juil 2007 15:07
Message » 15 Juil 2007 16:31
J'ai une petite question sur le 605 qui me fait galéré :
J'ai branché le HDE1 sur l'ammpli en HDMI et lorsque je regarde un film en true hd, en dolby plus, le voyant ne s'allume pas. En appuyant sur display, il me marque PCM multich, hdmithrough, pcm fs :48khz. mon lecteur est en bistream. Est-ce que j'ai encore foiré quelque chose ???
De plus, je ne sais plus du tout quel audio sélectionné, là je suis en "direct" et je trouve pas que c'est super (j'ai mis batman begins, digital plus ou true hd dans l'audio). Quel selection je dois choisir sur l'ampli pour avoir quelque chose de bien (pure audio, neo 6, etc...) ?
Et encore autre chose, lorsque je mets un dvd avec dolby digital ou dts (de base quoi), la encore il me mets tout en pcm à la lecture du film, je comprends plus.
Merci de vos conseils.
edward.zinkins
Inscription Forum: 22 Mar 2005 2:05
Message » 15 Juil 2007 17:28
petite question, pour relier les cable d'enceintes a l'ampli il faut des fiches speciale?
car sur mon vieil ampli actuel ce sont des pinces, et la systeme de l'onkyo est different
sdif18
Inscription Forum: 20 Nov 2005 12:09
Message » 15 Juil 2007 17:38
ironfred a écrit:
alfachris a écrit:
DTC-9.8
dans la doc ils parlent d'une version pour les USA et une version pour les autres ...
et attention aux prix en Yens, souvent il y a un coefficient multiplicateur d'une indécence certaine qui est appliqué quand il arrive dans nos chers pays ...
"Remember, remember, the 5th of November."
Danam
Inscription Forum: 12 Fév 2002 2:00
Message » 15 Juil 2007 18:21
edward.zinkins a écrit:J'ai une petite question sur le 605 qui me fait galéré :
Pour l'instant ton problème n'en est pas un en soi et n'étonne personne.
Onkyo est le premier fabricant à inclure ces décodages mais tant que les majors (droits d'auteurs)ne s'accordent pas sur la diffusion des stantards HD audio, le décodage ne se fait qu'a la source et l'ampli ne sert qu'a transiter l'information comme n'importe quel ampli 5.1-7.1 .
Un firmware promis par Tosh devrait arranger bientot le problème .
Pour ce qui est du Pcm avec les DVD, je me demande si ca ne résulte pas de ce meme probleme.
Ton lecteur convertit tous les signaux HD mais aussi DD et DTs vers Pcm, tu dois donc changer les parametres ds ton lecteur pour laisser passer ces 2 derniers.
Danam a écrit:
ironfred a écrit:
alfachris a écrit:
DTC-9.8
Les amplis integra sont griffés Inegra et celui-ci ne l'est pas donc il y a bon espoir pour l'importation.
J.eV.oisC.lair
Inscription Forum: 08 Jan 2005 17:06
Message » 15 Juil 2007 19:43
les fiches speciales sont des fiches bananes, vous en avez tous?
sdif18
Message » 15 Juil 2007 20:20
Moi , j'en ai pas , mais rassuré moi , ils ont prevu le meme systeme que les hp ???
dacuga
Inscription Forum: 17 Mai 2007 9:31
Message » 15 Juil 2007 20:24
bon j'ai convaincu ma copine, je commande le 605 demain en silver
sdif18
