LCD TVs :
* ..While the LCD is on, unplug the power cable
* ..Then while holding the " INPUT " and " VOLUME (-) " down, replug the cable in.
* ..When it powers up you will see a little "k" appear in brackets.
* ..Then on the set, press and hold the " VOL (-) " and " CH (-) " down and release
* ..The service menu appears on.
* ..Turn the set off to exit the Service Menu.
The service menu has a whopping 26 pages to scroll through!!
let me just post some of the more important info from the menu.
-Main Ver. 1.03 (U 2006/09/07 1A)
Boot ver. D60UB1.00
Temp: 5F
Lamp Error: 0
Industry init (+cause): Off
Hotelmode: Off
Center Actume: 2H OM
Monitor Gamma: 154
Monitor Gamma:
Red1 194_____Green1 176_____Blue1 149
Red2 369_____Green2 336_____Blue2 283
Red3 547_____Green3 505_____Blue3 420
Red4 etc etc etc
Red5 etc
Red6 etc
>>>>>>RED PUSH CONFIRMED TO BE ADJUSTABLE!<<<<<<<<
Monitor Max Temp: 58
LCD Test Pattern: Off
je vais passer pour un noob mais est ce que quelqu'un peu donner l'explication exacte de ça
![:)](https://www.homecinema-fr.com/forum/images/smilies/icon_smile.gif)
et me dire a quoi sa sert?
![:oops:](https://www.homecinema-fr.com/forum/images/smilies/icon_redface.gif)
HS:mes reglage 42xd1 pour xbox 360
Retro eclairage> 0
contraste> +30
luminosité> -1
couleur> -15
nuance> +10
netteté> +10
temps des coul> moyen haut
noir> non
trud> oui
sinon réglage ip> entrelace
ou mode film> oui
