Quelqu' un a un avis sur le shuttle M2000 :
Recommended range of application: Media Center, Intel Viiv Ready
Operating system: Microsoft Windows XP Media Center Edition 2005
with Update Rollup 2
3 languages available: German, English, French
Software: CyberLink PowerDVD
Chassis: Shuttle "M" chassis, flat case design
dimensions: 442 x 350 x 78 mm (WDH)
Processor: Intel Core Duo, Socket 479
1.6 GHz (553MHz FSB), 2 MB L2-Cache, 65nm Yonah Core
Mobile Dual Core Processor Technology
supports EIST (Enhanced Intel Speedstep Technology) and XD (Execute Disable Bit)
Chipset: Northbridge: Intel 945GT (GMCH), Southbridge: ICH7M-DH
Harddisk: 200 GB, Serial ATA 300 (3 GBit/s), 8MB buffer
USB-Harddisk Enclosure: for one 2.5" Parallel-ATA harddisk
to use as a removable secondary drive.
The 2.5" harddisk is not included.
Optical drive: 4X DVD Dual-Drive (Loader) with Dual Layer support, 2MB Buffer
Write mode: 4X DVD±R, 2X DVD±R/W, 40X CD-R, 24X CD-RW
Read mode: 6X DVD-ROM – supports Dual Format and Dual Layer, 12X CD-ROM/CD-R/CD-RW
Memory: 1024 MB DDR2-533
2x SO-DIMMs à 512 MB
Graphics card: NVIDIA GeForce 7600GS, PCI-Express X16, 256MB DDR memory
Video out: D-Sub VGA (analog), DVI-I (digital), TV (S-Video/Composite)
and Component Video output
S-Video and Composite: up to 1024x768 resolution at 60 Hz
TV Tuner Cards: 2x Hybrid TV tuner cards (PCI), supports Analog or DVB-T
Optional 2x DVB-T or 2x Analog tuner cards
Analog TV Tuner equipped with Hardware MPEG2 Encoder and FM Radio Tuner
VFD Media Display: integrated Versatile front-panel display
Displays the information you need right on the front of your XPC
compliant to MS Windows XP Media Center Edition 2005
VFD with AWAY mode function
Audio: 8 channel Intel HD Audio Sound
max. 192kHz/32-Bit, Realtek ALC880 Codec
Line in, Line out (8ch), SPDIF in/out (optisch), SPDIF out (coaxial)
LAN: Gigabit Ethernet Network Controller
Intel 82573L, supports up to 1000Mbit/s (Base-T)
Supports Wake-on-Lan function
Wireless LAN: Integrated WLAN module, supports 802.11g (54 Mbit/s)
Card Reader: integrated multi-format 8-in-1 card reader (USB 2.0)
supports CF I+II, SD, MD, SM, MMC, MS, MSP
Wireless Keyboard: Shuttle MCE Wireless Keyboard with Scroll ball
Remote Control: MCE Infrared Remote Control
receiver is integrated into the media center
Front-panel I/O
2x USB 2.0
Microphone
Earphone
Firewire Mini-port
8-in-1 card reader
Reset Button
Back-panel I/O
Sub-D VGA out (analog)
DVI out (digital)
TV out (S-Video/Composite)
Component Video Output
4x USB 2.0
1x Firewire (6 pin)
Gigabit LAN (RJ45)
Wireless LAN (54 MBit/s) incl. Antenna
Audio: optical SPDIF in/out, coaxial SPDIF out, 7.1 line-out
Clear CMOS button
Power supply
150W PSU with active PFC (Power Factor Correction)
Input : 100~240V AC
EMI Certified: FCC, CE, BSMI
Safety Certified: UL, TÜV, CB
Certification
Designed for Microsoft Windows XP Professional
FCC, CE, BSMI compliant
Further configuration options
It is possible to modify certain components of this basic
configuration. Please refer the "Shuttle Systems Configurator".
Warranty: 24 Months Pick-Up-And-Return Service
Conformity
This device is classed as a technical information
equipment (ITE) in class B and is intended for use in
living room and office. The CE-mark approves the
conformity by the EU-guidelines:
- EMV-guideline 89/336/EWG electromagnetic tolerance
- LVD-guideline 73/23/EWG use of electric devices
within certain voltage-limits
http://eu.shuttle.com/fr/desktopdefault.aspx/searchcall-12/searchcategory-283/noblendout-1/tabid-171/310_read-12436/
prix : 1640 €
