Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 49 invités
Discussions générales qui ne rentrent dans aucune autre catégorie
le nouveau Denon 3807
Message » 18 Aoû 2006 13:59
salut à tous
en cherchant sur le net j'ai pu voir les nouvelles spécif de ce fameux AVR 3807
Power Output; Watts Per Channel 120 All Channels Rated @ 0.05 THD All Channels Rated @ 0.08 THD –
Weight: In Pounds 38.6 Width (inches) 17.1 Height (inches) 6.7 Depth (inches) 16.9 SOUND
MODES THX Ultra2-Certified
– Dynamic Discrete Surround Circuit – D.D.S.C - D Processor(s) – Bit Depth and Type 32-bit Floating Point Dolby Pro Logic IIx – with Cinema, Music, Game Modes THX Post-Processing
– DPL (4.0), DPL2 Cinema, DD/DTS (5.1), ES Discrete (6.1), ES Matrix, Neo:6 Cinema –
THX Ultra2 7.1 Cinema, Music and Game Modes – THX Surround EX Decoding
– Dolby Digital Surround EX Decoding dts ES Discrete 6.1 Decoding dts ES Matrix 6.1 Decoding dts Neo:6 Stereo-to-Surround Cinema and Music Modes dts 96/24 5.1 for DVD-Video
Processing Dolby Headphone – HDCD Decoder Audio Signal Delay (Sync. Audio with Video signal)
– By source Pure Direct/Direct/Stereo Modes on Digital/Analog inputs Stereo/Direct Modes w/Pure Analog Path 5-Channel Stereo Mode
– Video Game Mode – Wide Screen 7.1 Mode Mono Movie Surround Mode – Rock Arena Surround Mode – Matrix Surround Mode – Jazz Club Surround Mode – Virtual Surround Mode
– For 2 Speakers/Headphones – Multi-Channel Stereo Mode 5/6/7 DSP Effect Modes 7 Auto Surround Mode (Analog or Digital Input Type)
Active Center Channel In All Surround Modes CONNECTIVITY True 24-bit/96-kHz Digital Input Capability True 24-bit/192-kHz Digital Input Capability (Denon Link & 1394)
Assignable Digital Inputs Digital Input – DENON Link 3rd (SACD Ready) IEEE-1394 Digital
Audio Input/Output – Digital Inputs: Coaxial 2 Digital Inputs: Optical 5 Digital Outputs: Optical 2 Digital to Analog REC Out
– Analog Audio Inputs, Incl. Tuner 11 Phono Input MM type Source Function Renaming Analog Record Outputs 3 Front Panel A/V Inputs w/Cover * Composite and S-Video x* with Optical Video Conversion
–Composite to S-Video to Component Video Conversion – Composite to S-Video to Composite Video Conversion
– Analog to HDMI DVI/HDMI Video Inputs – Compatible with 1.1 Spec. – Multi-Channel Audio 2 HDMI HDMI Video Outputs 1 Composite Video Inputs 8 Composite Video Outputs 3 S-Video Inputs 7 S-Video Outputs 3 Component Video Inputs x Bandwidth
- *Assignable 3x100 Component Video Outputs 1 6-Ch. External Analog Input – 8-Ch. External Analog Input Banana Plug Speaker Terminals, All Channels Cinema EQ Front A/B Speaker Selector
– 56 Station Auto-Preset Memory Tuning Radio Data System (RDS) – XM Satellite Radio 'Connect and Play' Ready – with optional antenna Direct Function (Tone Bypass) Volume Control Un-muting Selectable Muting Levels (Full/-40/-20) Video Select Control RS-232 Port
– Third Party Remote Controllers RJ-45 Ethernet Port – Same Functionality as AVR-5805/4806 – PC Setup and Control Capability IR Serial Remote In/Out terminals +12v Trigger Output - Assignable
– Multi-Source/Multi-Zone (*Uses REC OUT) 3S/3Z Pre-amp Outputs for Multi-Zone High Pass Filter for Multi-Zone Outputs – Multi-Zone Pre-Amp Outputs
– Selectable Output Levels Zone 3 fixed Discrete Multi-Zone Composite Video Output
- *S-Video also Zone 2 Only Discrete Remote Power On/Off, Source Selection and Volume for Main and Second/Third* Zones * Discrete Remote Source Selection for Zone 3 Assignable Amplifier Configuration of Surround Back Channels x With Volume Speaker Time-Delay and Level Controls: L/R, Sub, C, Surr. L/R, Surround Back Pre-Amp Outputs COMPONENT TECHNOLOGY Equal Power Amplifiers 7ch Low Impedance Drive Capability High
-Current/Discrete Amplifiers Independent Power Supplies 4 Pure Audio Construction
– Toroidal Power Transformer – Dolby Digital, dts and DSP Modes
– Analog Devices, HammerHead SHARC Dolby Digital, dts and DSP Modes
– Texas Instruments Aureus – AL24 Processing - All Channels AL24+ 24-bit/192-kHz DACs – Burr-Brown PCM-1791 2/8ch 24-bit/192-kHz DACs - Analog Devices
– Analog-to-Digital Conversion - Bit Depth/Sampling Rate 24/192 Variable High/Low Pass Crossover Points (12/24dB) 40/60/80/100/120/150/200/250 Built In Time Based Correction CONVENIENCE FEATURES Front Panel A/B Speaker Selector
– Auto Setup Calibration Auto/Manual Room Equalization Audyssey MultEqxt Room Eq. with up to eight position setup Auto Setup Microphone Included/Type Dual Surround Mode Spkr. Selector Icon-Based On-Screen Display Front Panel System Setup Control Personal Memory Plus System Setup/Surround Parameters Lockout Relay-Controlled Protection Circuits Microprocessor User Re-set Detachable Power Cord Subwoofer Peak-Level Limiter (THX)
– Pre-programmed (10 Devices) Glow Key Remote Control with Punch Through Commands – Pre-programmed/Learning EL Remote with Backlighting and Punch Through Commands All New Version.PRE ORDER ONLY.
voci le lien http://72.14.221.104/search?q=cache:mQruj7XSRZIJ:www.newyorkwholesaleaudiovideo.com/DENON-AVR3807-P23832C0.aspx+AVR-3807&hl=fr&gl=fr&ct=clnk&cd=4
si ces spécifications sont bel et bien celles du 3807, c'est une petite bombe qui arrive et une grande révolution dans la série des 3800.
malheureusement, toujours d'HD en vue mais rappelons que ceci n'est pas contractuel.
Denon va reconcilier pas mal de Monde en incluant le label THX ultra 2
malheureusement, il faudra attendre probablement le 3808 pour être au HDMI 1.3, ce qui est dommage
stephane.r
Inscription Forum: 18 Oct 2004 22:05
Message » 18 Aoû 2006 14:55
Alors vivement l'AVR3808 :wink:
yann13
Inscription Forum: 13 Sep 2004 16:31
Message » 18 Aoû 2006 15:00
et l'alimentation dans tous cela :idee: :wink:
FGO
FGO
Message » 18 Aoû 2006 17:17
aprés lecture approfondie de ces spécifications techniques, ce nouveau denon propose :
le label THX ultra 2 avec sa puce postprocessing
du 1080p en sortie HDMI (version 1.1)
un controleur RJ45 avec les mêmes fonctionalités que sur l'A11 et A1
le Dolby Headphone
1xIEEE 1394
il ne propose toujours que 2 HDMI en entrée, probablement pour le différencier du futur 4307.
stephane.r
Message » 18 Aoû 2006 19:08
c'est quoi le futur 4307 ?
Ou peut-on trouver la spec ?
yann13
Message » 18 Aoû 2006 19:45
aucune spécif avancées, mais on peut déjà présentir du THX ultra 2, IEEE 1994, probablement un scaler Faroudja et du 1080p en sortie HDMI
stephane.r
Message » 18 Aoû 2006 20:33
Et des prises HDMI 1.3 ?
Décodage DTS HD ?
yann13
Message » 18 Aoû 2006 20:35
On peut faire du 1080P avec la HDMI 1.1 ?
r4m
Inscription Forum: 01 Déc 2004 23:39
Message » 20 Aoû 2006 10:14
r4m a écrit:On peut faire du 1080P avec la HDMI 1.1 ?
oui
stephane.r
Message » 25 Aoû 2006 13:31
Petite question :
Sur les Denon est il possible de brancher un signal hdmi venant d'un lecteur dvd, par exemple du 1080i et de renvoyer ce signal sur les sorties yuv de l'ampli pour alimenter un projo dépourvu d'entrée hdmi ?
Y a t'il un autre moyen que celui la ? l'ampli fait il de l'upscaling via yuv ?
Cordialement.
stcbr69
Inscription Forum: 01 Aoû 2002 20:47
Message » 25 Aoû 2006 15:55
stcbr69 a écrit:Bonjour,
Petite question :
Cordialement.
je ne suis pas spécialiste mais je pense qu'on ne peut pas pour des raisons d'anti-copies, HDCP oblige. un signal numérique doit rester numérique. il faudra absolument que ton lecteur soit pourvu de sorties analogiques (RGB, YUV, Y/C, Composite).
bonne chance
stephane.r
Message » 25 Aoû 2006 16:08
Donc si je restes en analogique, j'envois par exemple un signal yuv (480) à l'ampli, l'ampli peut il faire de l'upscaling 720 ou 1080 yuv ?
Merci pour vos réponses !
stcbr69
Message » 25 Aoû 2006 16:19
stcbr69 a écrit:Donc si je restes en analogique, j'envois par exemple un signal yuv (480) à l'ampli, l'ampli peut il faire de l'upscaling 720 ou 1080 yuv ?
le 1080 , n'y compte pas, mais le 720 , c'est fort possible si l'upscale le propose.
stephane.r
Message » 25 Aoû 2006 16:44
Rien d'exceptionnel dans les spéc du 3807 .... wait and see pour les écoutes !
safe
Inscription Forum: 25 Sep 2000 2:00
Message » 25 Aoû 2006 20:36
safe a écrit:Rien d'exceptionnel dans les spéc du 3807 .... wait and see pour les écoutes !
si , il passe en spécif THX ultra 2 comme la série AVC .
j'aimerai bien l'entendre justement, voir ce qu'ils ont mis de nouveau en étage d'amplification, alim et filtrage.....
stephane.r
