Le pearl accepte lesfréquences suivantes sur la prise HDMI :
Support 1,080p, 24p / 50Hz / 60Hz HD input signals (HDMI Input only)
dixit
Utilizes three units of the world's smallest 3rd Generation 0.61” SXRD full HD panel - each for red, green and blue color reproduction - reproducing more than 6 million native pixels.
Incorporates a 200- Watt Ultra High Pressure (UHP) mercury lamp that achieves high brightness of 900lm and excellent red color reproduction
0.61 inch SXRD (Silicon X-tal Reflective Display) full HD panel
Display Resolution: Full HD -1,920 x 1,080 pixels
Contrast ratio of SXRD full HD panel device: 5,000 : 1
Brightness: 900 Lumens
Adopts the newly developed control algorithm “Advanced Iris 2” to reproduce high contrast ratio. The new control algorithm adds the manual adjustment function for iris setting to allow users to enjoy maximum flexibility by adjusting the aperture of iris depending on the pictures and sources
The combination of the “Advanced Iris 2” and SXRD full HD panel makes black level deeper and more details, and generates a dynamic contrast ratio of up to15,000:1*
Sony unique new “1-chip picture processing engine”-using full Digital video Signal processing- achieves high gradation reproduction and detail reproduction performance
Real Colour Processing function allows adjusting colour and hue of each of the primary colours independently to suit their individual preference
Lens Shift function is flexible for set-up within limited space constraints
Surprising Low Fan Noise: only 22dB
12 Bit Panel Driver Full Digital Chassis
HD I/P Converter, allows not only video Signal I/P conversion but also HD Signal I/P conversion
Built-in All Range Crisp Focus (ARC-F) Lens is included to further enhance the performance of the SXRD Full HD panel
1.8 times zoom, a 100” 16:9 Wide Screen projection size is achieved throwing distance 3.0 to 5.5 meters
HDMI Input, the benefits are its small size can transmit the inclusion of Digital audio and video signals, and its ability to maintain a good Signal-to-noise (S/N) level, which preserves perfect Signal quality
Made in Japan
Input Terminals: HDMI x 2, Video x 1, S-Video x 1, Component x 1, Input A (D-Sub 15 pin) x 1, Trigger x 1, RS-232C x 1
Power requirements: 100 to 240V, 50/60Hz
Power consumption: Max. 300W
Dimensions (W x H x D): 395 x 173.5 x 471.4 mm
Weight:11Kg
* When "Auto" mode of the Advanced Iris is used. This "Auto" mode of Advanced Iris dynamically changes according to the setting of the projector and the level of picture.
Quelle: Sony
source :
http://www.meinheimkino.com/thread.php? ... #post46104
