usa_satriani a écrit:Par contre pour le truc acurate là ?
Choisis "secure" à priori pour la détection des gaps. Pour la méthode, fais comme ça :
On the tab Gap Detection, choose Method A (to start with) and Secure. Insert a CD and press F4. Gap detection starts and takes only a few seconds per (clean) track. Do the same for Methods B and C. The fastest of the 3 Methods is the best for your drive. If none of the 3 works (typically EAC will 'hang' on a track) change Secure into Accurate or Inaccurate and run through the 3 methods again. It is a good idea to set Secure back afterwards, because it is more precise, and will really work for most of your CDs. Finally Save your settings into the profile.
