![Image](https://lh5.googleusercontent.com/-PQlPbiMGHi8/UUofqYFnuHI/AAAAAAAArM4/9kibo3-iXkM/s767/filtres-infinity-alpha-50.jpg)
UPDATE Avril/2013
![Image](https://dl.dropboxusercontent.com/u/7577946/Filtre%20enceintes/Plan%20Filtre%20Alpha%2040%20Alpha%2050%20Medium%20tweeter.jpg)
![Image](https://lh6.googleusercontent.com/-agB5pxwZVzo/UUofpzyZieI/AAAAAAAArM0/7p6T7XvpT1o/s500/filtres-infinity-alpha-20.jpg)
J'ai redessiné le schéma et écris un petit guide pas à pas et en photo ici (Optimisé pour Internet Explorer ça coince avec firefox) : [color=red][
![Image](https://lh5.googleusercontent.com/-PQlPbiMGHi8/UUofqYFnuHI/AAAAAAAArM4/9kibo3-iXkM/s767/filtres-infinity-alpha-50.jpg<br />)
![Image](https://lh6.googleusercontent.com/-agB5pxwZVzo/UUofpzyZieI/AAAAAAAArM0/7p6T7XvpT1o/s500/filtres-infinity-alpha-20.jpg<br />)
![Image](https://lh5.googleusercontent.com/-j_K8RIykypc/UUofPTQZ4rI/AAAAAAAArGU/97IlaoGPrps/w657-h430-p-o-k/Alpha-50-filtres-medium.jpg)
![Image](https://lh6.googleusercontent.com/-MGndom1aQCs/UUofOYyqz-I/AAAAAAAArGI/CQo5g_i25Yo/w647-h430-p-o-k/Alpha-50-manchon.jpg)
![Image](https://lh3.googleusercontent.com/-zpMPH2xC2c8/UUofIM1UA5I/AAAAAAAArFI/NowbHMWswn0/w552-h371-p-o-k/Alpha-50-01.jpg)
![Image](https://lh3.googleusercontent.com/-rjS0DpMqrqs/UUofHS8D4PI/AAAAAAAArFA/or-yRkzDSK0/w557-h371-p-o-k/Alpha-50-basse-demonte.jpg)
![Image](https://lh6.googleusercontent.com/-C-G9L7xpIlU/UUofL-aYdkI/AAAAAAAArFw/9pFwWWPb65M/w703-h410-p-o-k/Alpha-50-filtre-d%25C3%25A9monte.jpg)
![Image](https://lh6.googleusercontent.com/-SJu2ifwoNE8/UUofNtt9g0I/AAAAAAAArGA/Cik4X0vlCL4/w715-h430-p-o-k/Alpha-50-filtres-medium-col.jpg)
![Image](https://lh3.googleusercontent.com/-Hp4xuRyfemA/UUofQdDf1ZI/AAAAAAAArGg/xGUeGr1YH6g/w654-h434-p-o-k/Alpha-50-soudure.jpg)
![Image](https://lh5.googleusercontent.com/-pHN5sPR4eKQ/UUofQym3bmI/AAAAAAAArGo/Aqsd3yCcIvo/w654-h434-p-o-k/Alpha-50-taille-composants.jpg)
COMPOSANTS POUR TWEAK ALPHA 50
Qte Désignation Marque Maison du HP Riviera acoustic
1 mètre Cuivre/Argent C.A.1 AUDIO-DYNAMIQUE 2,50 €
2 mètres câble Léonische 2.5 AUDIO-DYNAMIQUE 6,00 €
2 condensateur mkp Type PB 400 volts 5,6 uF S.C.R. 5,40 €
1 condensateur mkp Type PB 400 volts 8,2 uF S.C.R. 3,00 €
1 condensateur mkp Type PB 400 volts 39 uF S.C.R. 9,50 €
1 self AD 0,15 mH Maison du HP 8,00 €
1 self AD 0,40 mH Maison du HP 9,00 €
1 self LA 3,3 mH Maison du HP 8,00 €
1 résistance 0,68 ohm intertechnik 1,15 €
1 résistance 1,2 ohm intertechnik 1,15 €
1 résistance 2,2 ohm intertechnik 2,20 €
1 paires de bornes HP dorés K30 intertechnik 9,65 €
TOTAL 65,55 €
COMPOSANTS POUR TWEAK ALPHA 20
1 metre Cuivre/Argent C.A.1 AUDIO-DYNAMIQUE 2,50 €
1 metres cable Léonische 2.5 AUDIO-DYNAMIQUE 3,00 €
1 condensateur mkp Type PB 400 volts 5,6 uF S.C.R. 2,70 €
1 condensateur mkp Type PB 400 volts 6,8 uF S.C.R. 3,00 €
1 self AD 0,25 mH Maison du HP 8,00 €
1 self AD 1,50 mH Maison du HP 12,00 €
1 résistance 1 ohm intertechnik 1,15 €
1 résistance 1,8 ohm intertechnik 1,15 €
TOTAL 43,15 €
yapluka
![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
