Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 14 invités
REL STORM 5
Message » 06 Mai 2005 8:46
Vends 1 subowoofer Rel STORM 5. Neuf, emballage d'origine, facture. Placage bois véritable black ash. A peine rodé. Prix neuf 1700 € vendu à 1100 €.
prol
Inscription Forum: 16 Oct 2002 20:41
Message » 06 Mai 2005 16:41
Et pour ceux qui veulent en savoir + :
High quality, gas-tight Neutrik Speakon input (high level)
High quality, panel-mounted twin phono inputs (L/R) (low level)
LFE phono input/output, a separate input to twin low level phono inputs
Totally discrete input circuitry for high and low level inputs
Large, blue front-firing LED display with adjustable brightness
True 200W (continuous) discrete, direct-coupled MOSFET amplifier
Downward-firing long-throw 250mm (10”) cast chassis driver
Improved ABC® filtering circuit calibrated in single Hz steps from 16 to 99
Separate volume controls for high and low-level adjustment
Variable Slam/Depth control –9dB to +9dB at 80Hz
5-12V DC trigger
Simultaneous connection of high and low level sources
Set-Safe® audibly transparent driver protection
Double-sided glass-fibre boards with plated-through holes
IEC power input socket and switch - no captive leads for installation flexibility
Finished in 30mm MDF in balanced Black Ash, Maple, Cherry, Walnut, Light Oak and Rosenut real wood veneers
Designed and hand-built in Great Britain, three-year worldwide warranty
Specifications
System Type
Closed box 'Zero-Q' loading
Frequency Roll Off
16Hz-99Hz
Lower In-Room Response (-3dB) 15Hz
Gain Control Range
80dB
Dimensions WxHxD mm (incl feet & controls)
345 x 520 x 370
Net Weight kg
30
Lien => http://www.rel.net/index2.htm
Bonne vente.
OO7livier.
OO7livier
Modération Home-Cinema & Rencontres
Inscription Forum: 21 Nov 2002 14:32
Message » 08 Mai 2005 9:24
Pas d'amateurs ?
prol
Message » 10 Mai 2005 6:13
Ecoute possible.
prol
Message » 11 Mai 2005 19:07
Personne pour ce superbe caisson ?
Faites moi une proposition correcte.
prol
Message » 12 Mai 2005 21:20
Personne ?
prol
Message » 13 Mai 2005 15:10
tu es ds quel dpt?
escaf1
Inscription Forum: 12 Mar 2002 2:00
Message » 19 Mai 2005 17:49
up !
prol
Message » 20 Mai 2005 16:02
PAS DE PROPOSITION ?
prol
Message » 26 Mai 2005 20:13
un petit up pour ce superbe caisson !!!!!
prol
Message » 29 Mai 2005 20:45
VENDU !
prol
Retourner vers Enceintes HIFI
