Association Marantz vp12 s1 et Marantz dv 9500
» 01 Mai 2005 13:29
En cherchant une solution économique pour bénéficier de la réolution maxi de mon VP 1280x720, (sachant qu'il ne possède qu'une entrée YUV et DB15, et que mon lecteur DVD ne sait sortir que du 576p via YUV et 720 en HDMI), J'ai trouvé un scaler .
En voici les caracteristiques:
Zinwell BLS-3000 Brite-View Pro Home Theater Video Line Doubler with Video Switcher and TV Tuner
Product Description BUY IT
Zinwell BLS-3000 Brite-View Pro Home Theater Video Line Doubler with Video Switcher and TV Tuner.
Applications mainly used for:
Ideal for Plasma Display Panels, DLP and LCD Projectors and other HDTV displays. Easy to use remote control. The Zinwell BLS-3000 is a High-Resolution video scaling processor & hub that converts standard-definition video content from your DVD player, VCR, PVR, satellite receiver, game console, or PC to any output resolution between 480p and 1080i. The Brite-View Pro brings a host of new Video Scaling features to the Zinwell product family, while adding Audio switching, routing, and processing technology. For the sophisticated home theater, and audio/video presentation systems, the Brite-View Pro makes the perfect centralized control and processing hub. Standard NTSC and PAL video are converted into high-quality 480P, 720P or 1080i Video resolution. BLS-3000 will ensure video sources to perform smooth, flicker-free, and at a highest picture quality. With integrated TV tuner, you can enjoy HDTV programs as well as DVD films on any display devices. By means of the multiple in/output connectors of Brite-View Pro, you can easily organize your audio/video into a true home theater with the highest quality at just an affordable price.
If got tired of watching standard resolution on your High Definition TV/Projector, take advantage of our everyday low price Zinwell Brite-View Pro. It will make your VCR or DVD look like State Of The Art HD receiver.
Technical Specifications:
Advanced video processing technology to improve picture quality
Advanced digital noise reduction
Advanced color edge enhancement
Adaptive static detect de-interlacing
Full screen, true color display
Double scan conversion
Automatic 3:2/2:2 pull down detection and correction
3D comb filter
Dynamic format 4:3 or 16:9 for RGB output
124 channels built-in TV tuner with Fine Tune function (individual storage per channel)
Support up to SXGA (1,280x1,024 resolution) for RGB output
Support 480p, 720p, 1080i for YPbPr output or DVI
Easy on screen display operation with hot key on the IR control.
Multiple in/outputs simulating video/audio switching center
Support MTS, optional Parental Control and Closed Caption for NTSC system
Inputs&Outputs:
Inputs:
2 x Composite Video: RCA connector
2 x S-Video: 4 pin, mini DIN
2 x YPbPr: 3-line RCA connectors
1 x RGB: 15 pin D-sub VGA connector
1 x Tuner: RF connector
2 x Audio: 2-line (L & R) RCA connectors
Outputs:
Hardware switch selectable between RGB and YPbPr output signals
Analogue RGB resolution: 640 x 480 (VGA), 800 x 600 (SVGA), 1024 x 768 (XGA), 1280 x 1024 (SXGA)
Analogue HDTV (YPbPr) resolution: 480p, 720p, 1080i
Refresh rate: 60Hz for NTSC system
1 x YPbPr: 3-line RCA connectors
1 x HDTV pass thru: 3-line RCA connectors
1 x RGB: 15 pin D-sub Female connector
1 x DVI: DVI-digital Female connector
Qu'on penser vous?
Y a t il d'autres moyens pour y remedier?
Merci pour vos conseils et remarques.
