Bon ben allez, puisque Thebe me le demande si gentillement, voici une petite synthèse du sujet:
__________________________________________________
Caractéristiques du S97 (citation AVSForum) :
** Video
- Faroudja DCDi (Press release of Panasonic Japan officially mentioned the DCDi)
- Digital video output of 720p and 1080i up-conversion with HDMI
- Panasonic original 4:4:4 color upsampling
- 216Mhz / 11 bit video encoder for analog video output
- MPEG4 playback (SD Video(asf) / V : MPEG4 simple profile / A : G.726)
** Audio
- High-resolution digital audio output of DVD-Audio with HDMI, 192 khz / 24 bit / 2 ch
- High-resolution digital audio output of DVD-Audio with HDMI, 96 khz / 24 bit / 6 ch
- Advanced Multi Remaster
- Virtual battery operation power circuit
- High sound quality parts of audio DAC, OPAMP and capacitor
- Large-sized insulator for vibration control
- HDCD & Dolby Pro Logic II
* Etc.
- Depth Enhancer
- Monitor Select
- Digital Noise Reduction (Block NR, Mosquito NR, 3D NR)
- 0.6X, 0.7X, 0.8X, 0.9X, 1.1X, 1.2X, 1.3X, 1.4X variable speed playback with sound and subtitle
- subtitle brightness & position control (manual and auto mode.)
Quelques liens:
http://www.avsforum.com/avs-vb/showthread.php?s=a2a3b631e407d72167b778dcd494ae67&postid=4582851#post4582851
(doc) http://www.panasonic.ch/doc/4401_4500/4486/userguide/userguide_3_dvd-s97eg-s_-.pdf
CR et tests :
http://www.avsforum.com/avs-vb/attachment.php?s=&attachmentid=28713
De BA: http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=60
De Chriss: http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=135
D'Alex Foley:
http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=165
http://www.hometheaterhifi.com/cgi-bin/shootout.cgi?function=search&articles=121
De Pas72:
http://www.homecinema-fr.com/forum/viewtopic.php?t=29752940&postdays=0&postorder=asc&start=225
Questions et réponses:
Upscaling uniquement sur HDMI ? oui
50 Hz en PAL Progessive Scan ? oui
Lecture DVD+R/RW et DVD-R/RW ? oui
Lecture MP3 sur DVD ? ?
Lecture MPEG4 ? oui
Lecture DiVX ? non
720p (ou 750) et 1080i à 50 Hz ? oui
Dézonable (ou dézoné chez Hifissimo par exemple) ? oui
Sortie Peritel ? semble que oui
Avantages/Problèmes :
Image HDMI (ancien firmware) : plutôt image lisse, pas très contrastée
Image HDMI (firmware 536): d'après des CR, fait jeu égal avec un Denon 2910
Netteté (ancien firmware) : bien en YUV, moins bien en HDMI
Problème de macroblocking: peut être atténué avec les 2 réglages de bruit vidéo
Astuces:
Possibilité d'avoir du 576p sur l'HDMI en désactivant l'HDMI
Firmwares:
A priori, le dernier en date est le 540, mais il vaut mieux rester en 536 (downgrade impossible)
http://home.comcast.net/~fu_family/Panasonic_DVD-S97_85E536_firmware_update.zip
Sujet HCFR: http://www.homecinema-fr.com/forum/viewtopic.php?t=29768994&postdays=0&postorder=asc&start=150
Ouf, c'est quand même long à faire ! Oublis, remarques, imprécisions, etc.: pas de problème, dites-le moi et je ferai des modifs.
Fred
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 16 invités
Lecteurs et platines vidéo (lecteurs DVD, HD-DVD, Dvdscopes, Laserdiscs, etc.)
Panasonic S97 [avec synthèse]
- s-fredo
- Inscription Forum: 25 Jan 2005 19:04
Peut on le dezonner, et comment ? (si ce n'est pas fait à l'achat, bien sur)
--Patrice (Zone 1 only )
Adherez à l'association HCFR pour que le site vive et reste indépendant... HCFR for ever...
- laric
- Membre d'Honneur - Webmaster
- Inscription Forum: 19 Juil 2000 22:13
Ben alors patrice, ready to go
- BA
- Inscription Forum: 10 Mar 2000 2:00
J'ai acheté ce lecteur cet aprèm :
En YUV il y a clairement un mieux ( moins de bruit vidéo, image plus précise ) par rapport à mon sony, et bizarrement les réglages que j'avais sur le projo restent impec sur ce DVD, comme quoi les 2 lecteurs devaient transmettrent le même niveau de signal..
Par contre en 720,1080 etc... aie aie aie ! deja j'ai du payer un cable hdmi->DVI 169 € et en plus le résultat est très bizarre : une image plus plate donc sans aucun fourmillement mais sans relief non plus, sans "vie" sans contraste !! Bon je n'ai pas réussi à régler, il faudra que je réessaye mais je sens que je vais pleurer après mes sous...pour l'instant ce serait le 1080 > 720 et puis surtout en 16/9 cinemascope les 2 bandes dessus dessous apparaissent à nouveau blanches meme en baissant la luminosité , ce qui est inssuportable..
Question son , ce n'est ni mieux ni moins bien que mon sony.
Il y a une sortie peritel, voilà...
- 12singes
- Inscription Forum: 20 Déc 2002 18:08
s-fredo a écrit:Bon ben allez, puisque Thebe me le demande si gentillement, voici une petite synthèse du sujet:
** Video
** Audio
* Etc.
- Depth Enhancer
- Monitor Select
Quelques liens:
CR et tests :
D'Alex Foley:
De Pas72:
Lecture MPEG4 ? oui
Lecture DiVX ? non
Astuces:
Firmwares:
Fred
super
un peu de boulot pour les modos .
- Thebe
- Inscription Forum: 01 Déc 2002 8:04
C'est fait
- Bardamu voyage
- Inscription Forum: 04 Avr 2004 8:46
Merci beaucoup pour ton CR.
Mais en gros si je comprends, quand on passe en HDMI/DVI, il y a aucun intêrét à acheter un lecteur DVD à 1000 euros ou plus ?? vu que la qualité d'image semble être la même sur S97 que sur un 2910 !!
- fouche
- Inscription Forum: 10 Jan 2005 9:54
Ce n'est pas tout à fait ça. En gros, et d'après ce que j'ai compris, l'image en HDMI du S97 est plutôt fade avec le firmware d'origine.
Mais d'après un autre CR situé dans le sujet sur les new firmwares pour le S97 (lien dans la synthèse), il est écrit que l'image HDMI du S97 devient enfin sympa avec le firmware 536, et se rapproche de celle du Denon 2910.
Pour ma part, je me pose exactement la même question, sachant que mes hésitations vont toujours entre un 1910, un 2910 et un S97, sachant que je n'y mettrai pas plus de brouzoufs que nécessaire. Et le seul que je n'ai pas vu en démo, c'est le S97... Et les CR à son sujet ne vont pas tous dans le même sens...
Contrairement à ceux du 2910 quasi-unanimes sur sa qualité d'image.
Pas évident tout ça...
Fred
Fred
- s-fredo
L'un d'entre vous peut il me répondre sur le dézonnage ?
--Patrice
--Patrice
- laric
Pour te répondre Laric, personne n'a pu trouver la manip de dézonnage, certains ont utilisé les petites télécommandes de dvdchips, d'autres ont acheté dézonné (hifissimo). Par contre, je sais que sur avs le firmware sur lequel les forumeurs travaillent sera multizones, macro off et permettra de naviguer entre les différents firmware (antériorité ou pas).
- pas72
- Inscription Forum: 09 Mar 2004 19:06
perso, je trouve que l'image en HDMI est meilleure avec le firmware 540 que le 536
Plus nette et plus lisse qu'auparavant ; meilleure saturation des couleurs. Ceci dit, le GROS pb, c'est le bug en PAL et 720p. Petit escalier à droite de l'image
- noname
s-fredo a écrit:Pour ma part, je me pose exactement la même question, sachant que mes hésitations vont toujours entre un 1910, un 2910 et un S97, sachant que je n'y mettrai pas plus de brouzoufs que nécessaire. Et le seul que je n'ai pas vu en démo, c'est le S97... Et les CR à son sujet ne vont pas tous dans le même sens...
Fred
D'après ce que j'ai pu voir, le S97 est dans les 400 € alors que le 2910 vaut plus du double : est-ce que quelqu'un est en mesure de nous dire si ces deux lecteurs peuvent vraimment jouer dans la même cours ? (au moins pour la qualité d'image)
- coolpix33
- Inscription Forum: 22 Fév 2005 21:05
En YUV et à mon avis, oui...
En HDMI, je n'ai pas pu essayer en même temps dans les même conditions, donc je ne peux dire... (ca ne veux pas dire non )
--Patrice
--Patrice
- laric
Salut Laric,
Es-tu vraiment sûr en YUV ?? car j'hésite à changer contre un 2900 en promo, car l'image "upscalée" ne me convainc pas !! si le 2900 n'est pas mieux que le pana en YUV, je laisse tomber...même si en audio je serais surement gagnant ?
- 12singes
Retourner vers Lecteurs DVD / HD-DVD / Laser Disque
